Gu Series 4 new tyres & dtronic
Submitted: Monday, Jul 17, 2006 at 12:30
ThreadID: 35896 Views:3236 Replies:6 FollowUps:7
I am interested in replacing the standard tyres on the new vehicle wity BFg's At 285 70 r17 has anybody put these on and i have a 2" lift these should not scrub?
Also has anybody put on a dtronic on a series 4 and is there a big differance.
Dave T
Reply By: Rokkitt - Monday, Jul 17, 2006 at 13:39
Just picked up a set of 285/75/16's BFG muddies (from Bob Jane T-Mart @ $2100 + rims) - have a 2" lift, the front wheel is very close to the guard when it is on lock. I had to remove the mudflap to allow the tyre to fit.
Rod
AnswerID: 183901
Reply By: Katoom - Monday, Jul 17, 2006 at 14:39
I'm looking to do the same tire wise at some stage. I have a steinbauer p-box on mine (3.0l). Makes a big difference to driveability. More power and torque than the dtronic and easy to fit.
Rgards,
Katoom
AnswerID: 183922
Follow Up By: brian - Monday, Jul 17, 2006 at 15:29
Katoom what is steinbauer p-box,any details,price availability please...????
FollowupID: 440552
Follow Up By: Leroy - Monday, Jul 17, 2006 at 16:18
On a GU4?
Leroy
FollowupID: 440558
Follow Up By: Katoom - Monday, Jul 17, 2006 at 17:19
Power goes from 118 kw to 142kw
Torque from 380NM to 456NM
$1305
Available from :
Diesel Care Australia Pty Ltd.
9 Loudoun Road (PO Box 107)
AU 4405 DALBY QLD
T: 0061/7 466 99 159
F: 0061/7 466 99 105
E: info@steinbauer.com.au
Site Link
Mine has a slight glitch at the moment in that the engine light stays on until the engine warms up slightly, and restarted. This doesn't worry me a great deal. They are sending me another shortly to see if that fixes the problem. This is on a 2006 3.0l TD. May be slightly different from previous models, hence the glitch. Their follow-up to the problem has been very good.
Katoom
FollowupID: 440567
Follow Up By: Farside - Tuesday, Jul 18, 2006 at 07:50
Katoom,
I am thinking quite seriously about getting a p-box for my GU. What does the fitment involve and can one easly remove it in the even of getting the vehicle serviced?
Thanks,
Angus
FollowupID: 440676
Follow Up By: Katoom - Tuesday, Jul 18, 2006 at 16:16
It sits under the bonnet and plugs into the back of the fuel pump. The p-box cabling has 3 plugs:- 1 to the pump, 1 to the original plug removed from the pump, and one to the p-box itself. The pump connecter is a little difficult to get at, but I can remove it all in about 5-10 minutes. I remove the 2 bolts on the fuel filter and move it slightly to get better access for my hand to get down there. It becomes a lot easier after you have done it once. I made a little bracket for the box itself as it was hard to find a flat spot (I have an extra fuse box and other stuff in the way) for it in the engine bay (size about 10x10x3cm). I recently removed mine for a service and couldn't wait to put it back on. Inside the box, all the electronics are totally encased in epoxy. Should be no water worries what so ever. Plugs are high quality units.
Katoom
FollowupID: 440745
Reply By: Member - The Crow (QLD) - Monday, Jul 17, 2006 at 16:22
Hi check out my post 31845. I have just returned from a 20,000 k trip towing a van and, still stand by what I said in that post. My Patrol is performing faultlessly and is still great to drive. Towing the van I was able to sit on the posted speeds with ease.
200 Series V8 Diesel
Thanks for the Rest Flying West and Flying Very Low along the track not coming back. The Crow
AnswerID: 183936
Reply By: rod69 - Monday, Jul 17, 2006 at 17:15
hi DavidT,I have fitted a Dtrnic to a 2003 GU. about 12 mths now and have not had any trouble with it , am more than happy with performance and if remember Australian made with a 3 year warranty Gotta be happy with that Regards Rod69
AnswerID: 183944
Reply By: Member - Alan (WA) - Tuesday, Jul 18, 2006 at 09:09
ARB told me when putting in dtronic to my Series 3 - that could not use in Series 4.
Didn't go into it in more detail as it did not apply to me - but may be worth contacting dtronic directly.
AnswerID: 184044
Reply By: Member - Coyote (SA) - Tuesday, Jul 18, 2006 at 10:40
Not sure exactly about your BFG's, but I have a 2" lift and fitted Cooper STT's 285/75/R17 and yes they did scrub on full lock. But it is a very simple operaton to remove the mudgards and cut away a small plastic protrusion insude the front arch that the tyre hits. ( I Have my Coopers on a set of 17" steelies for off road) so when I'm back on my standard alloys/tyres I fit the mudguards back on. (Thr protrusion had no relevance to the mudguards and seemed to be nothing more than decorative to keep the visiula flow of the mudgurd. being inside the wheel arch, I had no hesitation in cutting the corner off as it can't bee seen unless you have your head inside the wheel arch...
Voxson on this site has the same tryes on his GU4 but with a 4" lift and no probs at all even with mud guards apparently. (is in Cape yorke now so will be able to give 100% assurance upon his return in the next couple of weeks.
AnswerID: 184059
Follow Up By: Voxson (Adelaide) - Tuesday, Jul 18, 2006 at 16:59
Hi Dude...
Yes i have a 3inch lift with 30mm spacers and on the standard alloy rims they fit well...
The different offset on your steel wheels seemed to make matters a little scrapier but with that mod you did worked out well...
I didnt scrape tyres on guards whatsoever anywhere on my trip which officially ended today... *sobbing*....
Some of the things we had to climb was a good test of articulation,,,, no contest with anything of hi-end mods but good for a standard Patrol with lift and lockers etc...
Over 3 hrs hours of dvd recorded....
The trip was great,,,, i wouldnt have wanted it to be any dryer when we went up the OTL...
Nolans brook was about 1.3metres deep on the way up and had dropped about 150mm in only a week on our way back...
Catch you soon..
FollowupID: 440753
Follow Up By: Member - Coyote (SA) - Tuesday, Jul 18, 2006 at 19:23
Hey mate.. back in one piece hey.. great to hear.. can't wait to see that DVD.. and hear the stories..
FollowupID: 440780
