TX 4400
Submitted: Tuesday, Jul 18, 2006 at 20:51
ThreadID: 35949 Views:4240 Replies:3 FollowUps:6
I was going to program my local fire brigade (I am a member) into my GME TX 4400 radio but when I was reading the instructions it states users can only program in receive only frequencies from 465.00 and up.
My frequency I require is 463.650.
My question is can it be programed in by a dealer even though me the user can't do it from the front panel?
Any help would be appreciated.
Thanks in advance.
120scruiser
Reply By: Joombi - Tuesday, Jul 18, 2006 at 21:12
your local GME dealer should be able to do this for you, they plug it in to their computer, its amazing what your radio is capable of but does not come programmed standard with..
hope this helps you some...
Joombi
AnswerID: 184154
Reply By: Marn - Tuesday, Jul 18, 2006 at 21:40
Also if you are keen, I have seen programming leads for sale on ebay for various tx radios. Usually the seller also has links to sites where you can download the programs required to re pergram the radio. You can also make the "Extra receive only" channels transmit. Cheers gerard
AnswerID: 184164
Reply By: Hacksaw - Wednesday, Jul 19, 2006 at 08:12
How old is it. The newer models were able to be programmed by the user through the front panel. By newer I mean mine is abit over six years old and has the user programmable feature. I just can't remember how it's done, but try: http://www.gme.net.au/land/PDFs/tx4400_prog.pdf
If the link works for you, it opens up a PDF with the programming instructions. Also from the GME site, the feature is available on units with a serial number higher than 10803340.
Hope this helps.
AnswerID: 184216
Follow Up By: 120scruiser (NSW) - Wednesday, Jul 19, 2006 at 08:35
Thanks Hacksaw.
I bought mine on 28 December 2005 and does have the user programable function from the front panel however it will only let you program receive only from 465.000 up to I think 468.000.
No probs.
I will go and see my local dealers as they have the contract for our area fire trucks anyway.
Thanks for you reply.
120scruiser
FollowupID: 440855
Follow Up By: SteveL - Wednesday, Jul 19, 2006 at 11:35
The 4400 is a good rig,but i'd flog it and get yourself an Icom 400pro.It will TX and RX on the frequency you want without modification and will do it at 25 watts instead of 5.-Steve
FollowupID: 440892
Follow Up By: Hacksaw - Wednesday, Jul 19, 2006 at 17:11
Cruiser,
Sorry about that. If I'd read your initial query a little more carefully, I would have realised that my carefully crafted and well researched answer was of absolutely no use to you!!!
As much as a fan I am of GME, I've only heard good things about the Icom and if it will do as Steve says, that might be the way to go. As far as I'm aware, there is no way to extend the RX capabilities of the 4400 to the frequency you require.
Just a note on boosting the Icom though, apart from the very small legality issue of transmitting at more than 5watts on UHF, it'll certainly push your transmissions a fair distance further, but it won't help you hear the poor souls you're now reaching, who are still limited to 5watts.
Of course that would only apply to the UHF CB frequencies. If you're TX and RX on the fire frequencies, it's a different matter.
FollowupID: 440954
Follow Up By: 120scruiser (NSW) - Thursday, Jul 20, 2006 at 07:55
Thanks steve and hacksaw.
I am not interested in being illegal and txing at 25 watts as I have a GRN radio for the firies but I try not to have it on just for listening as when I need it on the fire ground the battery always goes flat, its a portable, so I thought I would try and put the frequency in my 4400 for receive only to save my batteries.
I will ring my local coms store and see what they say.
Thanks again
120scruiser
FollowupID: 441056
Follow Up By: SteveL - Thursday, Jul 20, 2006 at 08:42
I wasn't aware that TXing at 25 watts on the firies frequency was illegal and it can be set at 5 watts or TX inhibited if thats what you want.-Steve
FollowupID: 441086
Follow Up By: 120scruiser (NSW) - Thursday, Jul 20, 2006 at 17:08
Any thing over 5 watts tx and you need to be licenced. Thats all.
FollowupID: 441207
