5th gear towing
Submitted: Wednesday, Jul 19, 2006 at 08:12
Old Nick
This has probably been digested hundreds of times. I drive a 80 series (1997) multivalve turbo diesel (genuine 66000 kms) and have just purchased a new Jayco Hawk Outback camper which weighs about 1200 kgs. loaded.Is it OK to tow on the road in 5th gear, have heard many opinions and nearly all saying not to. Can all you experienced forumites give me some proven advice, regards Nick
Reply By: Member - Karl - Wednesday, Jul 19, 2006 at 08:22
Old Nick,
I tow in 5th gear - I have a '91 GXL 80 Series Diesel with an aftermarket turbo. I have a large off road trailer which I use to carry all my
camping gear both on and off road and I have never had a problem. I drop down a gear or two depending on conditions etc.
I know that there are others who will tell you not to, but I have yet to see any real evidence as why I shouldn't. I will shortly be getting a new campertrailer and I will tow that in 5th gear.
Karl
184218
Follow Up By: Old Nick - Wednesday, Jul 19, 2006 at 08:41
Thanks Karl, Just out of curiousity how many kms do you roughly estimate you have towed in 5th ? Thanks Nick.
440858
Follow Up By: Member - Karl - Friday, Jul 21, 2006 at 08:47
Nick,
Exact kilometers I couldn't say but the following is a rough guide:
1.
Sydney to
Brisbane and return - Twice
2.
Canberra to
Perth - one way
3.
Perth to
Shark Bay and return
4. Many weekend
camping trips
I have had the cruiser for 5 years now and it hasn't missed a beat
441318
Reply By: Member - Stephen M (NSW) - Wednesday, Jul 19, 2006 at 08:50
Hi there Nick I dont think you will have a problem if you drive to the conditions eg, see a rise ahead drop back to fourth, any hills or crests, or if driving into a strong head wind, you will generally know yourself if you start having to put the boot down to keep it up to speed then I would be dropping back in other words dont let the motor labour, there is too much proof on this
forum that towing in 5th gear labouring the motor or relying on the turbo to drag you over the top of a
hill that it will eventually stuff 5th gear either in a patrol or landcruiser. Search the
forum and you will read the proof. Up to you, yes there is probably plenty of people out there that do tow all the time in 5th but maybe only do it once a year and eventually it will happen, Id go by the majority, not the minority. Regards Steve M
184223
Reply By: Trevor R (QLD) - Wednesday, Jul 19, 2006 at 09:07
Experience on two fronts, regarding the 5th gear problem. 1st hand experience with my old 100 series cruiser 4.2 N/A. rebuilt that gearbox twice in 18 months and I'm sure it was on it's way out when I sold it.
2nd hand experience with my uncle having to rebuild his 4.2 T Patrol (GU) gearbox in
Norseman last year after stripping the spline shaft. All this after he was told by me repeatedly not to tow in 5th gear. Needless to say he is a convert now and tows in 4th.
As people will testify you can get away with it depending on your driving style and km towing in 5th, but if in doubt keep it out.
I am a definate 4th gear tower.
Trevor.
184227
Follow Up By: hl - Wednesday, Jul 19, 2006 at 09:44
Those Patrol gearboxes stripped the splines whether you towed or not.
Mine started to go a 50,000k and the vehicle had only ever towed a small box trailer for about 3000k.
440870
Follow Up By: Member - Pezza (QLD) - Wednesday, Jul 19, 2006 at 10:23
"if in doubt keep it out."
Occurs to me that this could also be a great slogan for safe sex mate! Hahaha
Avagoodn
Pezza
440876
Follow Up By: Trevor R (QLD) - Wednesday, Jul 19, 2006 at 10:41
hl,
I now have one of the suggested models with the dodgey splines but unlike my uncle's
mine has rarely been in 5th gear and it has towed alot of heavy loads for lots of km's. With 270 000km on
mine, I would have thought the boxes were dependant on how they were used. Maybe I have been lucky or maybe it does have something to do with towing in 5th????
Pezza,
2 rugrats in 17months seems to suggest you wouldn't know about this subject. HAHAHAHA.
Cheers to you both,
Trevor.
440878
Follow Up By: hl - Wednesday, Jul 19, 2006 at 11:05
Sure, if you don't use it, you're not likely to break it!
Mine had not completely gone at the time. It was just hard to shift out of 5th after using it for a while. As I was aware of the issue and my truck was still under warranty, I phoned Nissan and the chap I talked to was very helpful. He told me to check the colour of the gearbox oil and if it has gone dark brown in colour, the spline problem is likely to exist.
When the dealer pulled the box apart, one could see where the splines were starting to twist. They reckoned there were other components that were affected and ended up replacing the whole box. This was at 50,000km. The truck had done little towing, albeit a lot of it in 5th gear on a trip to
Innamincka towing a 6x4 Box trailer full of
camping gear. About 500Kg weight.
440885
Follow Up By: Member - Pezza (QLD) - Wednesday, Jul 19, 2006 at 11:18
Seeing as I have now finally figured out what caused these 2 rugrats, you can be damn sure I intend to live by this new slogan to prevent it from happening again:-))
Avagoodn
Pezza
440888
Reply By: Member - John R (NSW) - Wednesday, Jul 19, 2006 at 09:44
Nick, I'd read the owner's manual for your car and follow its recommendations :-)
184234
Follow Up By: Old Nick - Wednesday, Jul 19, 2006 at 12:23
John, Ive looked in owners manual, can not see anything about it or no warnings.My son inlaw who operates machinery in the bush for a logging contractor told me not to toww in 5th in my cruiser as over the years they have towed fuel trailers and firefighting trailers behind Landcruisers,Patrols,Tritons,Rodeos,Navaras and they have all had 5TH gear problems from towing. They are now using several F250s. I must admit they all drive vehicles hard as though they hate them, and do drag some heavy loads.Nick
440900
Reply By: Member - Mike DID - Wednesday, Jul 19, 2006 at 10:06
OK, this is for a different engine and an Auto gearbox and not towing - but it shows what an Auto gearbox will select - so obviously is considered good by the manufacturer.
The F3 at Hawkesbury River is quite steep - the Pajero 4 spd auto petrol quickly changed to 4th.
The pajero Did Auto goes up this
hill at 110km/h (120 indicated) with no problems in 5th gear. The engine loading going up this
hill at this speed would have to be more than towing a van on level ground.
Mike
184236
Follow Up By: Wizard1 - Wednesday, Jul 19, 2006 at 14:55
You have to be joking...you consider the gradient of a
hill on a freeway would provide the same resistance by way of weight and wind as say a 1500 kg caravan. If you do then I strongly suggest you hitch one up and see if they are the same.
I tow such a van with a Prado Td manual. I could fly up most hills, including the F3 in 5th gear generally due to the lack of rolling resistance and effect on my momentum.
I could tow on a flat highway in strong head winds and wouldn't use 5th.
I've also towed a boat passed road trains up hills at 120 KPH (NT) in 5th. But the weight difference of the boat and caravan was around 600 kg with much less wind resistence than a van.
Please compare apples with apples.
440930
Follow Up By: Member - Mike DID - Wednesday, Jul 19, 2006 at 15:40
The original question related to a Camper - you must be joking, comparing the drag of a camper to that of a Caravan.
On level ground it doesn't matter how heavy the van is, all you are doing is overcoming wind resistance. You certainly don't have to have much more accelerator pressure to tow a camper ON LEVEL GROUND - I have done it for 19,000km in a petrol Pajero.
Mike
440941
Reply By: Gronk - Wednesday, Jul 19, 2006 at 10:29
I had a T/D Jackaroo, but now have a Terracan crdi, and have towed my camper trailer everywhere in 5th. ( they rev too high at 115km/h )
Always have used the throttle and gears to keep the engine in the sweet zone ( 1500-3000rpm ) but maybe because my two 4wd's had strong gearboxes as
well??
184241
Follow Up By: Trevor R (QLD) - Wednesday, Jul 19, 2006 at 10:46
Do both these vehicles you mention run at greater than 3000rpm when towing in 4th at 115kph?
440880
Follow Up By: Gronk - Wednesday, Jul 19, 2006 at 13:11
Yes both 4wds run at approx 3000rpm at 120km/h in 5th gear.
Couldn't think of anything more annoying (other than breaking a gearbox !! ) than travelling for hundreds of klm's revving hard in 4th gear.
Pity that you can't use a car for what it was intended for , that is 4wd ing and towing.
Especially the Nissans, their boxes are huge? Gearboxes that is !!!
Good thing about the Terracan, its a 5yr warranty ( unlimited klm's ) so haven't got a worry about that sort of thing for a while .
440912
Follow Up By: Trevor R (QLD) - Wednesday, Jul 19, 2006 at 18:05
Definately agree with Terracan 5yr warranty it is a beauty.
I run at about 3000rpm in 4th at 110kph and up 3200rpm at 125kph Towing a big load. Funny the different gearing of different cars. Works fine for me at these revs.
Cheers. Trevor.
440964
Reply By: ian - Wednesday, Jul 19, 2006 at 12:25
Nick,
getting back to your original question.
I have an 80 and tow an off-road trailer.
After I had the gearbox repaired I stopped 5th gear towing most of the times when I would have in the past when it seemed OK, i.e gentle hills, flat.
Now it is pretty much 4th unless I know it is down
hill.
Ian
184262
Reply By: Wizard1 - Wednesday, Jul 19, 2006 at 15:01
I have a Prado TD. Have towed my van (1500 -1600 kg) and a boat (950kg) for the last 4 years. On and off I've used 5th when the conditions are right. Never below 90 kph, up
hill or strong winds and ensure my revs stay above 2000 rpm. On most flat roads in light winds it has been fine.
The car has done around 95000 km and I have never (touch wood) had a drama with the gear box.
184283
Reply By: Member - Lindsay- Wednesday, Jul 19, 2006 at 15:02
G'day Old Nick
My series 1997 model 80 series ("The Bear") has just clocked over 180,000km. I only use it as an expedition vehicle & tow a 3 tonne off road caravan genarally 6 months each year. I have had no gearbox trouble and am still running the original clutch.
I tow in 5th gear often but not all the time.
As soon as it starts to lug I change back to 4th.
If I am under 90km/hr I change back to 4th.
If I am into a head wind I change back to 4th.
I think it is all about commonsense. 5th gear is overdrive (I think?) so that is what I use it for. It is no use having the vehicle struggling to maintain a particular speed when 4th gear will do it easliy.
Go the 80s!!!!!!!!!!
184284
Reply By: Barnesy - Wednesday, Jul 19, 2006 at 17:09
Sounds like most agree Nick, use 4th for most situations and leave 5th as an overdrive gear when the conditions are perfect. Not only will labouring away in 5th strain the gearbox but it will increase fuel consumption too.
184306
Reply By: Member - Brian (Gold Coast) - Wednesday, Jul 19, 2006 at 18:18
Barnesy has it right Nick....
my way is to keep it in 4th till I can comfortably drop it into 5th without lugging the engine. Remember, lugging in ANY gear will cause problems!
184316
Reply By: Old Nick - Wednesday, Jul 19, 2006 at 19:05
Thanks to all who answered my query. As I thought I would be OK to tow in 5th in the cruiser as long as she was not working ie. hills, head winds etc. I do know one thing -the turbo diesel does not even know the camper is hitched up. Thanks again all Nick
184320
Reply By: Motherhen - Wednesday, Jul 19, 2006 at 23:00
Nick, We won't tow heavy loads with Cruiser or Patrol in 5th (or overdrive with the auto). Not in the manual, but it is a golden rule. Then again, you have a lightish camper, just borderline. Up to you to decide if it is a risk and assess the pros and cons of the forumites here. What you would gain by towing in 5th? (just a little less fuel), and where do you go? Will you be
miles from anywhere if you did lose the gears? We tow a heavy caravan, and is isn't worth the risk for us.
We did have a gearbox go on the Cruiser - even though i never did heavy towing in 5th (maybe my husband did sometimes when i wasn't there?), not towing at the time. Several hours from home, but luckily we were able to reach our son, who drove all night, firstly to hire a trailer, then to come and collect us, then next day it was more hours to take the Cruiser to the gearbox re builder. Then later another trip back to pick up the ram we'd bought, which we had to take back to the farm. Cost quite a few grand all up.
184377
Reply By: Gronk - Thursday, Jul 20, 2006 at 09:13
While not wanting to knock anybody on their decision to tow or not to tow in 5th I think some have lost the point, towing in 5th may be no good for some gearboxes(get a 4wd that will tow in 5th!!! ), but towing down to lowish revs ie; 1500rpm, shouldn't have any bearing on the gearbox, you have less power and torque at those revs so would be harder to damage the gearbox I would think.
Lugging an engine would be down around the 1000rpm or less range and I don't think anyone drives let alone tows at these rpm's.
But please shoot me down in flames if you think I deserve it.
184420
Follow Up By: hl - Friday, Jul 21, 2006 at 15:54
Totally agree. If there is an issue, then the owners manual should point it out.
My theory on the Patrol's failing 5th is that the box is quite an old design that has been around for many years. The original 4.2D engine had only about half the torque the current 3.0 and 4.2 engine can do and I think that's where the problem is. The gearbox had not been updated to cope with this increased torque.
441370
Follow Up By: ross - Friday, Jul 21, 2006 at 17:38
There is a lot of things not mentioned in a owners manual that shouldnt be done.
Of course it ll depends on how much of a load you are putting on 5th.
If you ever have a chance to look inside a 5 sp gearbox take note of how tiny 5th is compared to the other gears.
The smaller circumference means it ony has a very small amount of teeth and surface area to absorb the heat from the friction.
It is the most fragile gear in the gearbox.
The big torquey diesel engines on todays 4x4 dont bog down at higher speeds like the diesels of of old and they give the impression they will pull forever but all this power is being transferred through that tiny 5th gear in gearboxes that havent changed much from the old deisels that use to power them.
441395
Reply By: Alloy c/t - Friday, Jul 21, 2006 at 18:00
The beauty of an 80 series factory turbo diesel Automatic , turn the key , put big lever into D and of you go , towing or not the box does the work.
184692
