detroit truetrac LSD
Submitted: Wednesday, Jul 19, 2006 at 13:56
friar
G/Day All
Getting my rear diff rebuilt at the moment,
water caused the problem. I have been talked in to putting a detroit truetrac lsd,instead of toyota one,any one running one of these & hw do they compare with normal toyota lsd, also do they run lsd oil .
Reply By: BILL from Fitch Fuel Catalyst Australia Pty Ltd - Wednesday, Jul 19, 2006 at 14:50
Hi Friar,Have removed a couple over the years where owners have complained about noise emitted during operation ie on turning etc ,but strong diff.
Regards BILLS
184280
Reply By: Exploder - Wednesday, Jul 19, 2006 at 16:10
From what I have head they are very good and are
miles better than the Toyota unit or any Clutch type LSD for that matter and they will never wear out.
Probably the best thing you can have next to a locker.
184296
Reply By: Ozrunner - Thursday, Jul 20, 2006 at 13:27
You CANNOT get a better LSD than the Truetrac. I used one in my V8 4Runner for several years and have now upgraded to the Electrac, which is a Truetrac that can also be fully locked.
It cost me a fortune but I wanted to retain the brillance of the normal Truetrac LSD for normal useage.
I beg to question Bills comments re noisy when turning and I suspect he actually is referring to the semi lockers such as Lok rites, lokka diffs etc.
The Truetrac is a "LSD" and noise when turning is utter crap.
If you only require a good LSD then its the best.
184465
Reply By: mickjp - Thursday, Jul 20, 2006 at 14:50
I agree with OZrunner, i had one in my last hilux and one in this hilux. They are great, NO NOISE at all and they use normal gear oil. Not LSD oil, but you can use that if you want i suppose.Normal toyota lsd's are useless. TRuetrac are the way to go. Ive had it for 4 years now and not a problem with it.
184479
Reply By: friar - Thursday, Jul 20, 2006 at 16:25
Thanks for the reply,s in paticular Exploder,Ozromer,Mickjp,just what i wanted to hear,always a little sus when going to something i no nothing about,it has cost me abou t $400 more to have it fitted instead of the toyota Lsd.
Friar
184503
