AnswerID: 14300 Submitted: Sunday, Mar 02, 2003 at 14:36
Jan
replied:
I have the same
fridge, and couldn't be happier with it. Can't add to the other comments, just endorse them. I also have one of those two way thermometers from Dick Smith, but I place the remote probe at the bottom of the main compartment, because that's where the coldest point is going to be. Running the
fridge with three lights on is about right; two lights is generally not
cold enough for meat etc., and four tends to freeze things. With three, be sure to keep vegies, salad stuff etc. in the side compartment, which does not get as
cold. The thermometer generally shows the temperature at the bottom of the
fridge varying between about -1 to +3, as the
fridge cycles on and off, and of course, if you place the main thermometer unit somewhere useful then you get the current ambient temperature as well. (In Central Aust. last July, it was amusing to get up in the morning to see that it was colder outside the
fridge than in.) And do get the insulated cover. It doesn't make the
fridge run any colder, but protects the case, and the outside ambient temperature is not so important so the
fridge will cycle a lot less often, thereby saving your battery. Another point to note - we recently had a prolonged power failure at the house, with danger of the freezer contents melting, so they all went into the
Waeco, turned up high. It was running inside the house on an old, spare battery which we brought inside, and even when the battery was down to 9 volts, the
fridge was still running! Not good for the battery, but great for the frozen food. You can turn the
fridge down overnight, but it doesn't make a lot of difference with the cover on and the
fridge not being opened - it hardly cycles at all, even on a warm night.
Reply 7 of 9
