dif locker
Submitted: Tuesday, Jul 25, 2006 at 01:12
ThreadID: 36134 Views:2109 Replies:7 FollowUps:5
Hi all, Im looking at fitting a locker to front dif in a GU cab chassis with manual hubs and seeking advice as to which is a better unit i.e Detroit or air locker or maybe better suited to my rig
Reply By: Member - Troll 81 (QLD) - Tuesday, Jul 25, 2006 at 04:04
Hi Brian
I have front and rear ARB lockers in mine and they have never let me down and I love them. I can't comment on the other brands as I have only had experience with the ARB one but they make a big difference
AnswerID: 185146
Follow Up By: Member - Roachie (SA) - Tuesday, Jul 25, 2006 at 10:32
Ditto............ (except I only have the front air locker; not the rear ;-(()
FollowupID: 441933
Follow Up By: Trevor R (QLD) - Tuesday, Jul 25, 2006 at 21:12
I was with you Roachie, thinking that the front would be enough in our Patrol's but after seeing Troll's Patrol in action up at Landcruiser park it is tempting to opt for both when I finally get around to fitting them.
Cheers, Trevor.
FollowupID: 442083
Reply By: Dave from P7OFFROAD Accredited Driver Training - Tuesday, Jul 25, 2006 at 07:26
Out Troopy has front and rear Lock rights. they have been in for more than 5 years and travelled well over 200 000 kms without a hint of problem.
Our GU has just had a TJM Prolocker fitted in the last month. It works! (bit too early to give a long term opinion...)
AnswerID: 185149
Reply By: Truckster (Vic) - Tuesday, Jul 25, 2006 at 07:49
This has been done on just about every 4wd forum 20398230489230498230498203948230498203948023948230948 times this year alone..
do a bit of searching around, you will find so many threads, hints, tips, complaints, questions, queries that you will easily make your own mind up.
AnswerID: 185153
Reply By: Robin - Tuesday, Jul 25, 2006 at 09:06
Hi Brian
An often asked question with lots of opinions.
Do you mean Detroit or just an auto unlocker in general ?
As series IV detroit are about the same cost of Airlocker and
both are around twice the price of the Lockright type of unlocker.
The detroit is a lot smoother in its action and its harder to
make a decision between detroit/airlocker than Lockright/airlocker.
If general the airlocker wins because you can have it on or off
and hence avoid the unlockers understeer effects that are prone to
causing loss of traction on slippery surfaces.
Robin Miller
AnswerID: 185168
Reply By: Bonz (Vic) - Tuesday, Jul 25, 2006 at 09:26
Brian, I have a lockright in the front of our Patrol and its great, a little heavier than the normal steering when its in but not a problem. If you have the moola go for the airlocker, its the bees knees I reckon. The LSD in the back should do the trick there in a Patrol at least. Tojo's not so good.
GWBonz
AnswerID: 185175
Follow Up By: Trevor R (QLD) - Tuesday, Jul 25, 2006 at 21:09
Now all we got to do is wait for member Lucy to take the bait and we can all have a laugh !!!
FollowupID: 442082
Reply By: brian - Tuesday, Jul 25, 2006 at 21:29
Hi guys
thanks to all for your input , and have made a decision as to what will suit me best and in future will have a look at archives before I post. Last night I posted the question and then looked at archives '' sorry''. I will go for the ARB air locker as already have the compressor to suit
AnswerID: 185310
Follow Up By: Trevor R (QLD) - Tuesday, Jul 25, 2006 at 21:37
Not everybody is worried about answering the same question more than once as many people's opinion changes on a particular product as they get more use out of it or the product completely fails after a certain amount of time or whatever.
I look at the archives too but still like "up to date info" on a lot of things and to do this, it means asking the same questions more than once.
Cheers, Trevor.
FollowupID: 442089
Follow Up By: Bonz (Vic) - Tuesday, Jul 25, 2006 at 21:42
I agree Trev, theres never a silly question just silly mistales
FollowupID: 442091
Reply By: Gu_Patrol - Wednesday, Jul 26, 2006 at 08:25
I have a Lokka on the front of my GU and it's fantastic, One thing I found is i also have traction when I turn corners, I know a few guys that have the ARB airlocker andthere sometimes get stuck or loose traction when they turn the air locker off. both are great and of course it all depends on the car and driver. I still have the auto front hubs but I will change that one day.
If you can drive the same type of car with different lockers.
AnswerID: 185361
