solar recharging
Submitted: Tuesday, Jul 25, 2006 at 13:30
ThreadID: 36145 Views:3790 Replies:11 FollowUps:29
I'm looking at buying a solar setup to help recharge a deep cycle battery while camping. I need somthing to keep a fridge going for 3-4 days when the 4x4 isn't begin used and not run the battery down to much to damage it. I saw a unit in K-mart a few weeks ago for around $90 which had a cigarette lighter plug on the end of the cable. Not sure how well they work or how you are surpost to wire them up, but for $90 I wouldn't expect much. Not looking at spending a huge amount of money.
Cheers.
Reply By: brian - Tuesday, Jul 25, 2006 at 13:37
A $90 unit from kmart might just recharge your phone wont go anywhere near what you require sorry....
AnswerID: 185225
Reply By: GeeVee - Tuesday, Jul 25, 2006 at 14:13
TAS PAJ
An effective solar system is not cheap. A mathmatical calculation will tell you what size solar panel(s) you need, anything less will flatten your battery over time. (Even then you are guesstimating hours of sunshine per day). For example:
If your fridge _Affordable_Storage_Drawers.aspx 2.5 amps per hour and the compressor runs a total of 10 hours per day your need is 25 amp hours per day (2.5 X 10)
If your solar panel delivers 4 amps per hour and you average 5 hours good sunlight per day, you are returning 20 amp hours per day to your battery. (4 amps X 5 hours)
Your nett battery discharge is about 5 amp hours per day. (You will get your few days out of the battery) How long depends on what size (AmpHour) your auxillary battery is.
There are a number of variables to consider to get a system to work. If you don't go through the exercise you can spend a lot of money and not get the result you want or need.
Hope this helps!
Regards,
AnswerID: 185226
Reply By: 3F62 - Tuesday, Jul 25, 2006 at 14:55
Solar is a great option for charging batts, but if you have the average Waeco or Engel fridge you not going to get a solar panel that will keep up with the current draw of your fridge until you spend at least $600 on a new panel or maybe $400 second hand in the trading post........ If your camping where a bit of noise is not an issue to you or more importantly others you might be able to go down the "cheap" generator path....... $149 2-stroke & use a 5 amp or bigger 240v battery charger from home........
AnswerID: 185235
Reply By: Alloy c/t - Tuesday, Jul 25, 2006 at 16:41
TAS PAJ ,with a solar setup , maths is a critical component , IE: total amps draw by fridge/lights ect over a 24hr period ,then how many amp hrs is your battery good for and then how many amps the solar panel can produce on an average day ,,,
so as an example say your fridge is a 40 lt Engle and you use 1 versalite for 3hrs per nlght , :fridge =1.9 amps per hr x24= 45.6 amps +3x1amps for the light ,,total
of 48.6 amps used per 24hrs ,,now you have to replace those amps in 6/8 hrs of sunshine + an extra 1.9amps per hr that the fridge is Concurrently using , divide the 48.6 deficit by 6 = 8.1 or if realy optimistic by 8hrs of full sunshine = 6.07 amps perhr +the 1.9amps perhr currently using =7.97 amps required PER HR and then u could sit in the scrub pretty much indefinitly ,,, 2x 64watt Unisolar panels would just about cover it ,,say round $1200.
AnswerID: 185253
Follow Up By: TAS PAJ - Tuesday, Jul 25, 2006 at 17:12
Thanks for all the replies. Some really good info there. So it looks like you need to spend a bit to get the result i'm after. So it looks like it's not worth buying cheap panels that just won't do the job. I think i might have to invest in a new fridge that doen't draw as much power. the fridge i have at the moment is just a cheap one with a cooling fan and no themostat so it _Affordable_Storage_Drawers.aspx a fair bit more than your better quality units.
Cheers.
FollowupID: 442030
Follow Up By: Member - Andrew (QLD) - Tuesday, Jul 25, 2006 at 17:23
or more batteries :-)
FollowupID: 442033
Follow Up By: Alloy c/t - Tuesday, Jul 25, 2006 at 17:45
Andrew [Qld] or more batteries , only 1 problem with that [ I run a 6 battery system now already] you still have to have the means to recharge them , amps used = amps required to be replaced or sooner than later the batts are flat and the beer hot ,LOL.
FollowupID: 442040
Follow Up By: Scrubcat - Tuesday, Jul 25, 2006 at 20:34
Solar Panels ? There are a couple of other things to consider, some for, some against, apart from the cost which has already been mentioned.
1. once you have got it all set up the way you want it they are nearly maintenance free, no on going expence untill you need new batteries.
2.If you have them fixed to the roof of whatever outfit you have it probably meens you park it in the full sun for maximum effect, thus hot c/van camper etc.
3. If you have them portable so you can park in the shade and move the panels about to get most effect from the sun you then have a security issue.
4. You may have to pack them away if you are going to leave your camp unattended, so no recharging while packed away.
5. 65 w / 80 w panels are a fair size you may have a transportation problem.
One time I asked a bloke with an imported $150,000 5th wheeler camper why he had set up in the full sun . He said he needed to have the solar panels (which were on the roof) in the sun to charge the battery bank enough to run the airconditioner to keep the camper cool.
Didn`t make sense to me when there was ample places in good shade.
Good luck with which ever way you go.
FollowupID: 442077
Follow Up By: Sand Man (SA) - Wednesday, Jul 26, 2006 at 01:36
Alloy c/t,
As you stated, "with a solar setup , maths is a critical component"
I believe your calcs are flawed slightly by the assumption that a 40 litre Engel will draw 1.9 amps per hour for 24 hours (=48.6 Amps)
I am of the opinion that this is excessive as the fridge would generally cycle on and off according to the thermostat setting and therefore the draw is somewhat less, especially at night.
I have exactly what you have used as an example.
A 40 litre Engel, usually set to 1 on the dial and also a versalite which I use for 3 or 4 hours in the evening, to keep the bogyman away.
This equipment is connected to a 75 A/H Thumper portable battery system and supported by a 40 watt BP Solar panel to put "something" back in.
The longest I have run this apparatus "continuously" is three days and the battery indicator lights still showed "charged" on the thumper's battery test display. (starting off with a fully charged supply)
This indicates to me that the Solar panel must be putting back in, about what is taken out and is exactly what the salesperson indicated to me when I bought the solar panel. If I need to, I can purchase another 40 watt panel and connect it to the regulator on the existing panel, but indications so far, is that I don't require it.
This was sound advice given to me by the manufacturer of the Thumper, who also retail the BP Solar panels.
So, I would say quite confidently, that a 40 watt solar panel, which outputs about 2.4 amps would be enough to maintain a battery supporting a 40 litre Engel, or Waeco and a "Versalite" given average sunlight conditions and the use of the fridge (as a fridge rather than a freezer) "indefinitely".
Of course, I have a "plan B" where I can connect the fridge to the auxiliary battery in the vehicle and also recharge the Thumper from the vehicle alternator, if necessary.
That is my personal experience anyway.
Bill
FollowupID: 442123
Follow Up By: Alloy c/t - Wednesday, Jul 26, 2006 at 14:08
SandMan SA , my calculations were to be used as an example only ,not the be all and end all , dont know how you measure your amp hr usage but I run my fridges thru a Steca solar regulator ,tells me how many amps in and out in any given time frame of my choosing , can say that your average Engle in a 24hr period will use 1.9amps per hr which equates to 45.6 amps per 24 hrs ,,, next time you test your fridge put your multi meter or amp guage inline ,you may just be suprised to find that the Engle actually uses round 3.2 / 3.5amps while in the "on" part of the cycle ,,thats why even the Engle specs state 1.9amp draw per hr.
FollowupID: 442202
Follow Up By: Sand Man (SA) - Wednesday, Jul 26, 2006 at 16:17
Calculations used as an example only! What sort of factual information is that?
Perhaps you should have better "qualified" your example so that people are not misled?
That is why I contributed my personal experience to the thread. To give the Originator some real life facts to consider.
The Engel specs state a maximum draw of 2.7 amps. (at least for the model I have)
Oh and I have no need to "test my fridge" with a multimeter every time I use it. I'm out in the bush to enjoy myself, not practice paranoia measuring "amp hour usage".
As long as the contents are cold enough and the 12 volt supply is healthy, I'm happy.
As I have stated, I have a "growth path" available for solar charging should I find I need it. I just haven't found the need.
Bill
FollowupID: 442228
Follow Up By: Alloy c/t - Wednesday, Jul 26, 2006 at 16:28
Sandman , as I stated earlier , an AVERAGE of 1.9amps per hr which is a reasonable and feasable amp usage which equates to 45.6 amps per 24hrs ,you are the one who brought up fridge "cycling" and get your figures a about t
FollowupID: 442230
Reply By: Pajeroman - Tuesday, Jul 25, 2006 at 19:19
Don't waste your time or money on a solar unit. Think of how much fuel you will use if you want to charge you battery using the car. At idle and that is all that is needed you use very littel fuel.
Say you have an 80 AH alternator then an hour will fully charge a batttery.
AnswerID: 185281
Follow Up By: Member - John R (NSW) - Tuesday, Jul 25, 2006 at 19:31
Not at idle it's not. It depends on the RPM the alternator puts out the rated current. That's normally in the rev range in which the vehicle is driven.
FollowupID: 442060
Follow Up By: Member - John R (NSW) - Tuesday, Jul 25, 2006 at 19:33
I should have written over a couple of thousand (engine) RPM.
FollowupID: 442062
Follow Up By: Alloy c/t - Tuesday, Jul 25, 2006 at 19:53
And pigs fly , ,,, as a backup yes use your car sitting and running at a FAST idle ,long term power source ?? no way , why would you want to use a $50000.00+ vehicle in a detrimental way [to the vehicle] when a couple of thou$ gives you an unbreakable/ cheap[perkw] /clean power source that no one can complain about and you can use anywhere that the sun shines..
FollowupID: 442066
Follow Up By: Muzzgit (WA) - Tuesday, Jul 25, 2006 at 23:18
Even when My batteries are charged, if I start my car and put my Low beam on, the alternator doesn't put out enough charge to keep the battery isolator "on" until I increase the revs.
You would need at to run the engine at least a "fast idle" [1000rpm] if not more.
Remember that the alternator is designed to run at optimum when over 2000 RPM
FollowupID: 442113
Follow Up By: Member - Mike DID - Tuesday, Jul 25, 2006 at 23:43
a. You can't charge ANY lead-acid battery in an hour - and certainly not from an Alternator.
b. My 3.2 DiD Pajero charges at 25 amps at idle. The Alternator is rated at 125 amps.
Mike
FollowupID: 442117
Follow Up By: Mainey (WA) - Friday, Jul 28, 2006 at 22:52
An alternator, via the regulator supplies variable amps to the Battery system on an as required situation, to explain a bit more, a battery that is fairly flat will be charged at a far higher rate than a battery that is nearly fully charged.
A fully charged battery will at times effectively recieve none to miniscule amps from the alternator/regulator because it's fully charged and the opposite applies, a heavily discharged battery will recieve heaps of charge from the reg till it is fully charged.
The 125 amp alternator does not supply 25 amps all the time, the alternator would still supply 25 amps to the battery at 3,000 revs, because the amp output to the battery from the regulater depends on the condition of the battery, you can't put 125 amps into any battery - not without a big bang.
all the above is said without any attempt to denigrate the original poster...
but to clarify the charging situation with batteries in various states of charge.
FollowupID: 442872
Follow Up By: Mainey (WA) - Saturday, Jul 29, 2006 at 10:45
"edit" and before I'm 'told' the regulater does not regulate amps, the referance to the regulater in the line starting, The 125 amp alternater.... should have read "alternater/regulater' as was previously refered to in the parragraph above it.
Another good example would be my own Aux battery system, I have an in-line amp guage in fridge power cable, as well as LCD display in solar reg, at night both show ~8.2 amps negative when fridge is running, however when in direct sun can show 2 to 5 amps positive, still with fridge running, due to the fact that the solar system is putting into the Aux battery system more power than the fridge is using when running, when in direct sun.
If in direct sun and the fridge stops cycling the Aux batteries can be seen to be charged at ~12 amp and shortly after as the Aux batteries are reaching fully charged the 'solar' regulater is only putting O.2 amps into the charged Aux batteries.
FollowupID: 442903
Follow Up By: Member - Mike DID - Saturday, Jul 29, 2006 at 10:55
"My 3.2 DiD Pajero charges at 25 amps at idle. The Alternator is rated at 125 amps.
To clarify -
1. Some charging systems are capable of putting out useful current when the engine is at idle.
2. In my vehicle at idle, it can put out 20% of the Alternator's peak current capability into the battery.
3. Diesel engines are more likely to have higher output current at idle because their peak engine revs are around 4000 whereas petrol engine peak revs will be closer to 6000.
FollowupID: 442906
Reply By: Member - Andy Q (VIC) - Tuesday, Jul 25, 2006 at 23:07
G'day TAS PAJ, After reading your post + answers= suggestions, it all must be quite clear for you.
If like me, you want a simple solution, just go ahead buy a aluminium framed 60watt panel( had mine for 18years now) and a decent sized solar deep cycle battery. As well make sure you, either, buy dual battery set up, fitted to your vehicle or set one up yourself. Make sure that while you are traveling you are charging both deep cycle batteries so you'll always have full powered batteries when you set up camp. Rig up your charging wiring for the solar panel to battery with snap on connectors. If you don't want to spend a huge amount of money.......well forget it
AnswerID: 185330
Reply By: Motherhen - Tuesday, Jul 25, 2006 at 23:37
With our previous camper, we purchased one solar panel and made a stand for it. We'd stop in the afternoon, place it where the sun was, go for a walk and return to find it in the shade, but it had charged the battery. We'd face it east ready for the dawn and at first light, the charge would trickle in. If it was cold, we'd turn the fridge off overnight; it kept the fridge going and a couple of lights. If parked during the day, we could put it up on the roof. Easy and cheap to run and totally silent in the bush. Left the genny behind and never needed it.
AnswerID: 185337
Reply By: Grungle - Wednesday, Jul 26, 2006 at 10:11
Hi TAS PAJ,
I went through the same scenareo as yourself a couple of years ago. After a lot of research I came up with a system that suited my needs exactly but also wrote about what I did and how I went about it so others could see my thoughts (whether right or wrong) on my system.
If interested you can read about at my website http://members.mcs.net.au/~grungle/solar.html
David
AnswerID: 185379
Follow Up By: TAS PAJ - Wednesday, Jul 26, 2006 at 10:56
Nice rig you have there Grungle very nice setup. Some really good ideas from everyone, but it looks like the duel battery setup will have to do for a while unless the tax man wants to give me a large tax return.
FollowupID: 442170
Follow Up By: Grungle - Wednesday, Jul 26, 2006 at 13:17
Cheers TAS PAJ. Whatever you do, it is step in the right direction and you can build on it from there. Good luck with everything.
David
FollowupID: 442189
Reply By: madmax - Wednesday, Jul 26, 2006 at 15:26
Hi TAS PAJ,
A decent fridge will use about 30AMPS a day. An 80W solar panel will produce about this under optimal conditions. You can either size your batteries to last 3-4 days or get a combo of solar and batteries.
We have delevoped a calculator to help you determine your solar and battery needs:
Solar Calculator and battery sizing
Try the DC calculator for a dc fridge, or AC or RAPS calculator for AC applications.
Regards,
Max
Information Manager
Energy Matters
1300 727 151
AnswerID: 185411
Follow Up By: Alloy c/t - Wednesday, Jul 26, 2006 at 15:38
Would you like to tell all and sundry what "decent" fridge uses 30amps per day ,,factory specs from the two major fridge compressors used in 12v all state figures way more than 30amps per day [24hrs].
FollowupID: 442221
Follow Up By: madmax - Wednesday, Jul 26, 2006 at 17:09
It would be my pleasure to tell all and sundry, Alloy.
The engle fridges use between, 0.5 to 2.5 AMPS Maximum
look here:
Site Link
they do not run 24 hours a day (it depends how often you open the door and ambient temperature)
So we have a maximum range of between: 12Ah (0.5A x 24h) and 60Ah (2.5A x 24h), assuming the fridges are running 24 hours a day.
If it makes you happy Alloy, we both can be right.
Max
Information Manager
Energy Matters
1300 727 151
FollowupID: 442237
Follow Up By: Alloy c/t - Wednesday, Jul 26, 2006 at 18:07
No way ,real world use shows that a 40lt Engle _Affordable_Storage_Drawers.aspx over 3amps on kick in and settles to 2.7amp with an average of 1.9amps total draw per hr ,used as fridge ,setting 1.5 / 2 on the dial temp internal 2c / 4c ambient average over 24hr = 27c. fridge full /opened 6times.
FollowupID: 442256
Follow Up By: madmax - Thursday, Jul 27, 2006 at 10:19
Hi Alloy,
I'll have to admit I have never used the fridge, i was just working off the specs I read. I guess it would depend on system voltage. If it works at 24V (as opposed to 12V) it would probably use half the amps, but you would need twice as many batteries.
If you're only going away for a few days, then you could get away with the 80W panel and 100+Ah of batteries. A popular configuration that we sell is 2 x 6V Trojan T105 Batteries (250Ah) and an 80W panel. The panel puts in between 20-30 Ah a day under optimal conditions, so the batteries won't get discharged more than 50% (which you do not want to do for deep cycle batteries) over a few days out in the bush.
Regards,
Max
FollowupID: 442390
Reply By: Derek from Affordable Batteries & Radiators - Wednesday, Jul 26, 2006 at 19:53
Hi Taz
We did a few tests before we manufactured our Bi-fold units.
Most suppliers are making an 80W unit but we found under test conditions this was not good enough and settled on 100W using 2x BP 50W panels and a high quality float charging regulator.
Fuel is expensive and you would need to run the car for 2 hours a day to stay ahead in summer. You also have the added wear an tear on the vehicle.
Regards Derek.
AnswerID: 185452
Reply By: Mainey (WA) - Friday, Jul 28, 2006 at 23:25
have read the Engal web site -> " Variable from 0.5 to 2.5 AMPS Maximum " is the terminology used, I believe these numbers would be amps USED, as they are expressed as amps MAXIMUM, and NOT 'amp hours'.
Assuming a 50% runtime that equates to 1.25 a/h average for 24 hours which calculates to 30 amps per 24 hours, in the far North that number would be far higher as I've personally seen fridges that run constantly during the day due to the high ambient temperatures and the numbers would be in excess of 40 amps per day.
As they say numbers don't lie, it's just the way they are interpreted by humans that makes them different.
A basic solar panel of 80 watts puts out about 4.8 amps x 6 hours = 28.8 Amps
Remember these numbers are at "best Performance" and not available every day with-out constant shifting the panel to chase the sun to get optimum performance from the panel.
An 80 watt panel laid 'flat' on the roof of a vehicle will put out a consistant 3.4 to 4.2 amps on a GOOD day, multiply by 6 hours and you have 22.8 amps average per day.
However a quality panel will start working earlier and finish working later in the day and you will get in excess of 30 amps, but you pay more money for the better technology than you get in the elcheapo panels.
AnswerID: 185922
Follow Up By: Alloy c/t - Saturday, Jul 29, 2006 at 17:57
Mainey ,where have you been hiding for the last couple of months ,"they" finaly let you out of goal eh ?? lol.
FollowupID: 442961
Follow Up By: Member - Mike DID - Saturday, Jul 29, 2006 at 19:39
"4.8 amps x 6 hours = 28.8 Amps "
- you can't multiply amps by hours and get amps. Cumulative current is amphours (not amp/hours).
This should read
"4.8 amps x 6 hours = 28.8 Amphours "
FollowupID: 442981
Follow Up By: Mainey (WA) - Monday, Jul 31, 2006 at 11:45
Alloy, been away up north for a while, back in Perth only for a week then returing back to the far North West for the rest of winter.
Mike, what I did is multiply the number of amps produced by a 80watt solar panel (~4.8 amps is specified on most 80watt panels) by the number of hours (full sun hours per day) to get an answer which is relative to the total number of amps produced in the day, nothing more nothing less!! the answer is 28.8 amps (total) remember the original statement was the number of amps available in a day!!!
There is 28.8 amps (total) produced by the solar panel in a 24 hour day using this equasion.
FollowupID: 443276
Follow Up By: Member - Mike DID - Monday, Jul 31, 2006 at 16:08
If you draw fuel from a tank at 2 litres per hour for 24 hours, then you will have drained a total of 48 litres, the total is NOT 48 litres per hour. i.e you multiply litres per hour (2) by hours (24) you end up with (litres per hour) x hours = litres.
Similarly amps x hours = amphours, NOT amps.
Amps = an instantaneous rate of flow
Amphours = cumulative amps over a period of time. If measured over one hour, then the number of amphours will be the same as the AVERAGE amps over one hour, even though the amps at any one may vary e.g. 4 amps or zero amps as the thermostat cycles on and off.
If you are reading values off your Steca note that "A" indicates it is displaying Amps and "Ah" indicates it is displaying Amphours.
FollowupID: 443325
Follow Up By: Member - big bo (NSW) - Tuesday, Aug 01, 2006 at 12:54
Panel rated at say 5 amps/hour used for 6 hours gives you 30amps.
(5amps/hrs x hrs =amps)
FollowupID: 443545
Follow Up By: Member - Mike DID - Tuesday, Aug 01, 2006 at 13:01
The output of a panel in amps, not amps/hour.
FollowupID: 443549
Follow Up By: Member - Mike DID - Tuesday, Aug 01, 2006 at 13:12
Maybe it would be easier if you thought of the instantaneous "flow" of current as "amphours per hour". This is still a technically correct unit, just a bit wordy ( since the two hours cancel each other out anyway).
Then a panel putting out 2 amphours per hour for 6 hours would put 12 amphours into your battery.
2 "amphours per hour" x 6 hours = 12 amphours.
The units used to measure electricity have not changed in the last hundred years.
FollowupID: 443552
