Exhaust system question?
Submitted: Tuesday, Jul 25, 2006 at 19:56
RodeoRay
Is there any beneifits on fitting a larger exhaust system with mandral bends to a 2.8L turbo diesel rodeo. i.e power and fuel consumption?
Reply By: Member - JohnR (Vic)&Moses - Tuesday, Jul 25, 2006 at 20:44
If other vehicles give the indication, Ray, you will improve the power, but when you have it will you drive it harder and wreck the economy?
185302
Reply By: Member - Bruce and Anne - Wednesday, Jul 26, 2006 at 08:20
Put a 3 inch mandrel bent exhaust system on it will give 10 to 15% more power and up to 1 to 1.5 kilometers to the litre. Add an intercooler and put it on a dyno have the fuel rate played with and you will be surprised how much grunt those 2.8s will put out.
Cheers Bruce.
185359
Reply By: Kiwi Kia - Wednesday, Jul 26, 2006 at 15:06
Basic rule of internal combustion engine - improving it's breathing is
well worth while (this means both in and out).
185408
Follow Up By: sandmanvanman - Thursday, Jul 27, 2006 at 23:06
i had a jap import mu with the same engine as the rodeo. i had a 65 mm (not mandrel bent) system with free flowing muffler and the injector pump was tweaked, gained 7 hp at the
wheels and extended my fuel range about 50 km per
tank. make sure you replace the system all the way back to the turbo and invest in a new flexy joint the same diamater. i paid $380 for the complete system all stainles steel. made a huge difference with overtaking. ate all other diesels for dinner.
442610
