79 bench to bucket conversion
Submitted: Wednesday, Jul 26, 2006 at 09:02
Jack79TD
G'day all, Has anyone done, or got any info on if it is possible to replace the passenger bench
seat in a standard 79 series with the bukcet
seat out of a RV 79 ute. Does it bolt straight up, require engineering etc. SWMBO would be much happier!
Not interested in going down the path of SAAS etc.
Any info would be appreciated.
Jack
Reply By: Member - John L G - Wednesday, Jul 26, 2006 at 11:49
Jack,
I fitted Aerotech to
mine but a mate of
mine simply took his truck to a good upholstery mob who trimmed the original passenger
seat back to a bucket and looks and feels like a factory
seat in my opinion. While he was at it they also put slightly deeper side padding to hold the passenger more firmly.
The base mount fitting for the driver and passenger seats are a bit different so simply trying to instal a drivers
seat into the passenger side probably won't work.
185386
Reply By: Member - Phil G (SA) - Wednesday, Jul 26, 2006 at 12:02
Hi Jack,
The drivers
seat changes straight over.
Not so simple on the passengers side. The middle runner has the hole at the front, but not at the back. So you'll have to get a captured nut installed. (They will need to cut a hole because there is no accessibility from below). Secondly, the seatbelt mounts are a problem. The rigid stalk for the middle belt will not hook up to the passenger side lap/sash. So you'll either have to use the floppy stalk or make it rigid with a plastic surround. Also you'll have to get a second captured bolt installed for that
seat belt.
This is what I had to do to install Recaros in
mine - had the engineering stuff done by Willshires in
Adelaide.
phil
185387
Reply By: Member - Bware (Tweed Valley) - Wednesday, Jul 26, 2006 at 12:06
G'day Jack,
I've got a standard 80series and replaced
the bench seat with a GXL passenger bucket and it bolted straight into the existing holes easy as. I don't see why the 79 would be any different to the RV.
185389
Follow Up By: Member - Bware (Tweed Valley) - Wednesday, Jul 26, 2006 at 12:10
Well, except for the stuff that Phil G mentioned LOL
442179
Follow Up By: Member - Phil G (SA) - Wednesday, Jul 26, 2006 at 14:03
hehehe
Just glad I got in 4 minutes before you!!!
442201
Follow Up By: traveller2 - Wednesday, Jul 26, 2006 at 15:14
I was able on two 75 series, with careful measuring, to drill a hole which 'found' the centre of the captive nut already on the underside of the floor. Don't know whether it is possible on a 79 as the floorpan is different.
442214
Follow Up By: Member - Phil G (SA) - Wednesday, Jul 26, 2006 at 23:57
traveller2,
I looked hard for any
sign of that on the 79series - no
sign - reckon they've changed things a bit on the later standard models. Willshires drilled a round hole and fed a plate and nut underneath.
442335
Follow Up By: traveller2 - Thursday, Jul 27, 2006 at 08:07
The other way to do it is run a bar between the existing mount and the centre
seat belt mount (the one in the centre of the cushion on the 1 1/2
seat) and then use that to provide a corner mount for the single
seat. You could also pick up the other
seat belt mount as
442356
Reply By: Member - Chris R (NSW) - Wednesday, Jul 26, 2006 at 19:14
My 78 series troopie gave all the probs as stated by Phil - no rear runner hole. No alternative
seat belt hole. I had hoped there would be a captive nut but drilled exactly where it should be felt around with a probe - and voila! nothing.
If you want the risk you could fit new heavy mounting plate (12cm!!) on the floor plate using the existing and no longer used
seat runner anchor point, the old
seat belt anchor point and the left hand rear
seat runner anchor point. This plate is 12 cm thick so it can be tapped to take the new
seat belt anchor point and the new
seat runner anchor point. This would raise the
seat rear by 12cm.
I have an idea
seat converters do this conversion using an above floor plate.
Chris
185445
Reply By: Member - Phil G (SA) - Thursday, Jul 27, 2006 at 00:03
The other option is to buy the base that is sold by Aerotech for the 78/79series. Saw one in a
shop a few years ago for a bit under $200. It used 5x40mm steel flat to make up an adapter that ran between the rear holes, and the
seat belt mount came off that.
185497
Follow Up By: Jack79TD - Thursday, Jul 27, 2006 at 09:59
Thanks for all your replies.
Phill, I am interested in the Goughs
water tanks that you have listed under your rig profile. Where can i find more info on it?
Jack
442383
Follow Up By: Member - Phil G (SA) - Thursday, Jul 27, 2006 at 13:30
Hi Jack,
They would be the best undertray
tank going around, being very thick plastic, have built in baffles, are simply attached to the undertray with angle iron and captured nuts, so no straps are required. Three outlets, plus filler and breather. The supplied clear hoses all have a plastic taste, so I ditched them all and used Nylex blue
drinking water hose. And they supply a nice tap that I've mounted to the back of the cab. And only 115mm deep, so clears the muffler
well. You'll probably have to remake a tray support to slip it in.
But they cost a heap - about $500-600. But I would still buy the same again. I purchased
mine from Opposite Lock in
Adelaide.
Gough Plastics Website has all their tanks listed.
442436
Reply By: Member - Craig D (SA) - Thursday, Jul 27, 2006 at 11:06
Jack, Opposite Lock sell the under tray tanks now, too, and Goughs Link is
www.goughs.com.au
Best Regards,
185562
Follow Up By: Member - Craig D (SA) - Thursday, Jul 27, 2006 at 11:07
Bugga...that should be www.gough.com.au with no 's' in goughs!
Sorry mate.
442399
Follow Up By: Member - Phil G (SA) - Thursday, Jul 27, 2006 at 13:49
Craig,
What brand was yours again - looked a very good bit of gear.
phil
442442
Follow Up By: Member - Craig D (SA) - Thursday, Jul 27, 2006 at 13:53
Afternoon Phil.
Mine came from Opposite Lock at Mile End. I was having a look at their web site yesterday when I noticed the under tray
tank. Thanks for the favourable comment - I hope to have it finally installed very soon (just finalising the battery stowage underneath as the ruddy hold down clamps didn't fit!).
442444
