Canvas or Plastic floor in swag
Submitted: Thursday, Jul 27, 2006 at 22:09
Gu_Patrol
I'm looking at buying a swag but not sure if I brought one with a plastic bottom or Canvas, Someone said to me that the plastic ones leek at the seams
Reply By: ro-dah-o (WA) - Thursday, Jul 27, 2006 at 22:36
Each or either. I have 2 canvas bottoms and a plastic bottom swag. When using the canvas bottoms, I make sure that I use some form of ground sheet. $2 blue tarps do the trick, and it saves having to clean dirt off the botom of the swag before packing away. I find I sleep better in the canvas bottom swag. Dont know why, just do. Perhaps because it 'breathes', I dont really know. As for leaking, I guess because they are one peice of canvas, so no joins except for where the zips are, less chance of leaking.
The plastic bottom swag is just as good.
Mine has high sides, so less chance of it leaking. The only downside is that it seems to collect alot of moisture on the underside, thus attracting plenty of dirt/sticks/leaves as the temptation is to use it without a ground sheet.
If it was my choice, go with what suits your budget and your needs. pay attention to the mattresses as this I beleive is the most important factor. I lived in my swag for three months straight once, I was only able to do it because of the mattress. We have the two canvas bottom swags as they can be joined together to make a double bed, they were the right price, good sized mattress, and nothing looks better than dragging a dusty canvas swag off the back of the ute. Bit of an ozzie icon I reckon.
good luck
185721
Reply By: Dave from P7OFFROAD Accredited Driver Training - Thursday, Jul 27, 2006 at 23:35
Personally I chose to go with an all canvas swag as I reckon they breathe much better. (had the opportunity to 'road test' a few before I purchased
mine).
I carry a piece of shadecloth to put under the swag (when I bother) to keep it a bit cleaner, works better than a tarp because rain can not pool on it.
There is such a rich variety of swags available nowadys, that i think that it will really come down to which of the 'other' features you need/want most...
185730
Reply By: Barnesy - Friday, Jul 28, 2006 at 00:27
Haven't had any problems with my swag with a plastic bottom. I haven't ever used one with a canvas bottom, but the canvas top on
mine does collect dew on the inside on cold nights. I'm not sure if the canvas bottomed ones would let moisture seep through.
185738
Follow Up By: Mazdan - Friday, Jul 28, 2006 at 08:04
That dew you talk about is in fact condensation. Its from your breathing.
Just open the end flaps a bit more to allow more air flow.
442649
Reply By: bucky - Friday, Jul 28, 2006 at 04:55
Its like this !
Dosen't matter what you get , as long as you put a ground sheet underneath it..
Personally, I use a roll of hi_density ( sky Blue ) foam rubber ,.. Clark Rubber stores sell it,,and I think its pool matting type, , and its a good 25-30 mm thick,, and fits perfectly inderneath the swag, is
water proof, and if you are a big fellar, like me, its an extra ( waterproof ) mattress
Bucky
email me for more details if you want ,, bloh@aapt.net.au
185744
Reply By: Mike Harding - Friday, Jul 28, 2006 at 07:55
I use my canvas bottom swag directly on the ground and have no problems at all with it.
185749
Follow Up By: Mazdan - Friday, Jul 28, 2006 at 08:07
Hi mike, long time no talkies.
I use the tarp underneath because it stops the swag getting wet on the bottom from condensation and means that I can rollit up next day and not have to bother unpacking it again to dry it when I get home. Thats the only reason for me.
The small tarp gets packed seperately.......almost always wet on one side and its easier to dry when i get home.
442652
Reply By: Gu_Patrol - Friday, Jul 28, 2006 at 08:21
Thanks guys, Looks like the canvas floor wins. I still don' understand how
water gets inbetween the seams/stitching. he must be on drugs. :-)
185757
Follow Up By: Grizzle - Friday, Jul 28, 2006 at 11:11
I bought a swag for myself (Burke & Wills) with a plastic floor. The I had to get one quickly for my son, we bought the same type of swag but could only get one with a canvas floor. It doesn't seem to make any difference between the two. We also use small tarps under the swags. The truth of the matter is if it's wet enough to soak through the bottom you would be flooded anyway.
Good luck
442707
Reply By: Member - Andrew W (SA) - Friday, Jul 28, 2006 at 08:36
I think I understand how stitching in the seams in plastic is more prone to leaking than in canvas, but practically it is not a problem in my experience.
I do find that the plastic bottom is easier to clean, especially if the roll is sitting on the roof-rack exposed to dust or mud.
Just another thought ...
Ciao for now
Andrew happy to roll out his swag anywhere ;-)
185760
Reply By: Hairy - Friday, Jul 28, 2006 at 09:49
Go the plastic (PVC) bottom.
1. They stop the rising moisture.
2. If you
camp in the centre bindis don't stick to them.
3. When rolled up on the roof or back of a truck they stay a lot drier if it rains.
4. You don't need to carry a ground sheet.
5. If you need to take them inside for any reason (motel room, friends house, work accommodation ,etc.)you can wipe them down with a wet rag and not drag dirt and crap inside.
As far as leaking at the seams, It would depend on the quality and design. Buy one off someone who has been making and using swags for years ( not mass producing them for the cities) and you wont have a problem. You can always use a wax stick on the seams.
I have 2 swags with PVC and 2 without and honestly cant see any reason why you would buy a swag without a PVC bottom anymore.
185779
Reply By: sandmanvanman - Friday, Jul 28, 2006 at 10:40
i spend too much time in a swag to put up with a moldy smell from canvas bottom. the plastic bottom is the way to go, the darche dome swags do not leak in torential down poors i should now the army allways picks the wet season to go bush. as they say if its not raining its not training.
185800
Reply By: derraux - Friday, Jul 28, 2006 at 15:30
Canvas Bottom is the best for a swag a pvc botttom does not allow the mattress to breath, as a person sleeps they sweat this sweat goes through your mattress and and in pvc based swag collect under the mattress so if you are using the swag for long periods of time you need to air the mattress or it will go mouldy,
Also a in a pvc based swag when you sew it you need to treat the stitching as it will leak pvc does not swell like canvas and take up the holes the needle leaves behind, yes pvc is good in muddy situations but it may mean picking a better place to put it or carying a cheap poly tarp.
Having said that there is also difference in the canvas themselves some canvas breathes better than others as there is a fine line when making a canvas to get the canvas to be waterproof and breath, talk to your local
camping store ask them the questions and see what sort of answers you get, there will be for and agianst both products, niether is wrong some things just work better than others in certain situations.
Make sure you get one with a good breathable fabric it will slow the condensation down.
Derraux
185855
Reply By: bucky - Sunday, Jul 30, 2006 at 07:12
About the PVC floor swags and sweeting ?
I make sure my swag is aired every day when
camping, thats the key to stopping mould ect, only takes 1/2 hr in the morning and you can do the same in the afternoon, when making
camp,
I have slept in some major storms, and with my waterproof PVC base and my hi_density foam ground sheet, have never been wet,
Mind you its a bit tricky getting in and out during a storm, but still managed to remain reasonably dry,,, but thats a different story
Cheers Bucky
186044
