GPS/COMPUTERS
Submitted: Friday, Jul 28, 2006 at 17:55
Member - andrew B (Kununurra)
Ok, one for all of those out there who use Maps etc on the go....
I currently have a Garmin gps76 that has been to hell and back and still works perfectly. I use it both on the dash and in the boat, mainly for basic waypoints for crabpots/rocks I dont want to hit etc in the boat, along with tracks to find my way home in the dark. In the car it gets used a little for plotting turnoffs etc to tracks I want to look at I've found on maps or google earth.
I also have a fairly new laptop worth about 4k, which I don't want to take in the bush. Looking at maps etc while driving is not that important to me, but the old '76 has a small brain so can't have maps.
The company I work for has finally introduced salary pckageing (always happens after you spend 4 grand on a laptop). I am tossing up between another smaller laptop and a PDA of some description.
The adv. of the PDA is the obvious size etc, and could be used quit a bi outside the car, but a second laptop has bigger screens etc.
Looking to spend about a grand, give or take.....What, in your opinion, should I get?
Please let me know your experiences and setups....
Thanks Andrew
PS, I don't think it will spend any time in the boat, but if I go PDA it may once or twice if I go on a big expedition....the laptop wouldn't ever come.
Reply By: Member - Mike DID - Friday, Jul 28, 2006 at 18:06
Have a look at PDAs with VGA (640x480) resolution screens.
Maps and aerial photos in OziExplorer look great. But so do photos and movies.
185881
Follow Up By: Member - andrew B (Kununurra) - Saturday, Jul 29, 2006 at 09:24
Thanks Mike, thte screens are generally where the $$ are, but also what you need to see the detail! We generally carry a digital camera with a 2 g card, so we dnn't need the storage, but the viewing would be much better than the camera.
Thanks Andrew
442897
Reply By: Graham56 - Friday, Jul 28, 2006 at 20:01
Hi Andrew,
I have both Laptop and PDA.
The PDA is great, compact, easy to hide from bad people.
The unit is a HP iPAQ hx 2190. Cost about $500 new
Some specs as follows
- Intel PXA 270 processor 312MHz
- Integrated Bluetooth (v1.2)
- Secure Digital expansion slot (supports SDIO/MCC cards)
- CompactFlash Type II expansion slot
- 3.5 inch transflective TFT display with 64K colours
- 64 MB RAM
- 128 MB ROM (up to 80 MB user available)
GPSOZ can supply cables or purchase a compactflash GPSR it plugs straight in (no cables)
OziExplorer CE, and I use a 512MB SD card to stor maps and data
It's a top set up and cheaper than a laptop.
Regards Graham
185897
Follow Up By: Member - andrew B (Kununurra) - Saturday, Jul 29, 2006 at 09:40
Gday Graham
From memory, It was the iPAQ that the IT guy from work recommended. I can get a subltantal discount on a Dell, but a friend hs one and isnt 100% happy with it. Having said that, The Dell desktop I use at work is a monster, 2 flat screens and runs 3d software, video etc very
I'll have to learn more about Bluetooth tc, as the cords running around in thet Patrol are starting to add up
Thans Andrew
442899
Follow Up By: Graham56 - Saturday, Jul 29, 2006 at 13:30
Andrew, I uase a Arkon GPSR PDA mount it plugs into the bottom of said PDA the mount plugs into lighter socket and away you go. on which PDA to use be careful some units have issues with GPRS, the iPAC are just plug and play as they are allready capable.
Graham
442918
Reply By: bardenboy - Friday, Jul 28, 2006 at 20:07
I have a garmin V which has 19mb storeage for down loaded maps which allows me to load approx 30% of Aust, It works great but its black & white and has a small screen.
I was lucky enough to get an HP4700 which has a large 4" colour screen, it has a SD and Compact Flash slot, so you can load maps on the SD card and use the Compact Flash slot for a plug in GPS card if you wish.
Since you need power to power the unit in the car, I connected my unit to the GPS, which is also connected to the 12volt supply.
Very happy with it, I run Oziexplorer CE and mainly Nat Maps (cheap at $100.00)
Also have Desinator on it which gives me street level maps and Voice turn by turn instructions.
At work we have just got a new large Plan Printer which also scans colour, I am playing around, scanned a High Country map, calabrated and down loaded into the PDA, looks good, only thing is the map started out at 7mb at 200dpi and ended up at 13mb when converted to work on the PDA, but not a problem when you use 1 or 2GB SD cards.
Happy shopping
Dennis
Where are you Based ? I am in
Sydney.
185900
Follow Up By: Member - andrew B (Kununurra) - Saturday, Jul 29, 2006 at 09:50
Gday Dennis
I'm up in
Kununurra. The scanning would be interesting, they've just updated Google earth for the coast up here. Also, we have v.good printers at work for printing maps and photo's, up to A0 I tink.
Thanks Andrew
442900
Reply By: phenders88 - Friday, Jul 28, 2006 at 20:49
Andrew B
Wouldn't be without my moving maps - lots of fun, and informative too.
I am using an iPaq 4700, 640 x 480 screen (I think), 624 Mhz processor, about 96 Mb memory, with 1 gb SD card and 1 gb CF, for maps. I am using it with a Magellan Sportrack for the GPS, and running power and data via cable from cig lighter, supplied by GPSOz. If I was starting again, I'd have a blue tooth GPS, but I have had the Magellan for a few years, so made sense to use it. I have both on the dash in suitable brackets, and use the Magellan while I am driving as a digital speedo and altimeter.
I also recently bought a reradiating antenna (also from GPSOz) which has improved wet/tree/poor conditions markedly. It is mounted on the bullbar. I run the lot from a double cig adapter wired directly to the second battery, so it is ignition independent.
Using Oziexplorere CE - works great. Also TOMTOM for street level directions. Have the full version of Ozi on a lapto, so that is where I do pretrip planning, map conversion etc.
Thought about a laptop, but the bride would have to manage, and the ergonomics/crash worthiness, mounting issues etc, eliminated it from consideration.
Been using this set up for about a year, works very
well. Screen size obviously smaller, but you still know where you are, and the display on the 4700 is the largest of the PDAs (no longer available, I understand), and the iPaq is used for many other things as a digital diary etc in its other life.
Hendo
185904
Follow Up By: Member - andrew B (Kununurra) - Saturday, Jul 29, 2006 at 09:54
Gday Hendo
Looks like its a resounding victory for the PDA's (watch the laptop reply's flood in now!) I think we are on the right track, Pretrip planning etc on the laptop at home, thn download what we want ontoo the PDA.
Thanks Andrew
442901
Reply By: Muddy doe (SA) - Saturday, Jul 29, 2006 at 13:35
Guys,
Check out the new Sony Ultra Portable PC - the UX series. Runs a full version of XP Pro and is only mabigger than a PDA. Saw one at the Sony
shop the other day and even as a bit of a tech head I must say I was VERY impressed.
Muddy
185973
