UHF & CB aerials
Submitted: Saturday, Jul 29, 2006 at 15:37
Member - Peter A (VIC)
Helo everyone, I have a sahara bar on my 120 prado and wondering where else people have mounted there aerials other than the outside edge, or where on the back of the vehicle can you mount them where they will be practical.
thanks Peter
Reply By: Notso - Saturday, Jul 29, 2006 at 16:12
Dunno much about positions bu t they should be kept a metre or so apart.
Actually I have a combination UHF/CB antenna with a splitter system that I use on my UHF/CB in a single unit "Uniden". It seems to work OK and saves a spot on the bull bar
185992
Reply By: Gu_Patrol - Saturday, Jul 29, 2006 at 17:24
How you thought about Glass mount, not as good as the others, or Z bracket on the bonnet
185999
Reply By: Member - Andrew W (SA) - Saturday, Jul 29, 2006 at 17:28
My ARB Sahara bar (admittedly an older one on a 100 Series) has a mounting point on both sides -
well on the flat part in front of the headlight that is.
186001
Follow Up By: Member - Peter A (VIC) - Saturday, Jul 29, 2006 at 17:40
Andrew does it interfere with your headlights,
Cheers Peter
442956
Follow Up By: Member - Andrew W (SA) - Sunday, Jul 30, 2006 at 00:35
I mount my UHF aerial on the roof rack :-) and HF if I have to on the rear spares
I've never needed to know ;-)
443029
Reply By: 3F62 - Saturday, Jul 29, 2006 at 21:16
"Z" brackets seem like your most obvious option, unless you only use radios out of town if you are in a city, what about magnetic base & lead, lots of antenna options for UHF.......
186021
