LPG....PETROL
Submitted: Sunday, Aug 06, 2006 at 11:20
Member - BUNDY BOY (WA)
ok heres one i know weve covered before.....my 3 lt petrol patrol is as normal heavy on the juice.....now my Q:is should i replace standard fuel
tank with a long range...and add a lg gas
tank or...remove fuel
tank and mount it differently and go with the extra lg LPG
tank under the ass end....this way ill drive mainly with LPG but still have the 80 odd fuel
tank as a reserve for those times LPG isn't on offer..... but am a little worried were fuel
tank could b mounted safely ..
cheers Darren
Reply By: Jimbo - Sunday, Aug 06, 2006 at 11:26
Darren,
I had a 3L GQ a few years back. What they did was to remove the main
tank and put the LPG
tank there. They then fitted a 55 litre petrol
tank under the driver's
seat.
Jim
187406
Follow Up By: Jugs - Sunday, Aug 06, 2006 at 14:10
I have a Patrol GQ Ti 4.2 which I fitted LPG. removed the main Tk and fitted 90lt Usable LPG and 60lt Petrol where the long range
tank goes under the RH side.
I get ~ 300km on LPG
Sydney driving, better out of town. the only change I would make if doing it again is deciding exactly which
tank I would purchase for petrol. as the LPG kit only came with a 60lt petrol tk and with a bit more knowledge and experience I see you can get larger tanks that fit in the same place for pretty much what I paid.
The other bit of research I have come across is that there are now LPG kits that supply the LPG through the Petrol injector port EFI engine (duel petrol/LPG unit) I have not seen it personally but know a vehicle it is on and have been offered an inspection test. It cuts out all any back fire problem with LPG as there is not any flammable vapour in the air intake system only the cylinder.
love the whole set up I have. works
Jugs
444717
Follow Up By: Brew69(SA) - Sunday, Aug 06, 2006 at 19:13
My belly
tank on the drivers side holds 70 lt. But my lpg
tank has 115 lt usable and is good for 425-450kms city or country.Combined range of 700-800kms. I am sure diamond has a 3lt on gas and his used 23lt/100kms on lpg.
444750
Reply By: ian robbo - Monday, Aug 14, 2006 at 18:47
Question :
I have a NH Petrol 3000cc Pajero (92 model) that I am considering coverting to dual ULP/LPG if I can do so keeping my original petrol
tank and adding under the body a suitable LPG
tank , etc.
I heard today that Howard (PM) had announced a subsidy of $2000 to anyone who converts to LPG see au.news.yahoo.com/060803/2/100ce.html , apparently effective from today. Quote " The government will also provide a $2,000 grant to the cost of converting cars to LPG for private use. " , that sounds pretty good .
So my question is can my NH Pajero be converted (I live in
Newcastle) and how much would it cost ?
188977
Reply By: ian robbo - Monday, Aug 14, 2006 at 18:48
Question :
tank , etc.
I heard today that Howard (PM) had announced a subsidy of $2000 to anyone who converts to LPG , apparently effective from today. " The government will also provide a $2,000 grant to the cost of converting cars to LPG for private use. " , that sounds pretty good .
188979
