Importing maps into oziexplorer
Submitted: Sunday, Aug 06, 2006 at 12:07
ThreadID: 36500 Views:2624 Replies:4 FollowUps:1
Have purchased a copy of the Holland Track with way points etc.... It has a copy of trial version of Oziexplorer on the CD also. The only map loaded is Hyden. All other maps required when highlighted come up as not loaded.I have tried to import the relevant maps from NATMAP but each map is too large.
Any Ideas on how to import maps from NATMAP into Oziexplorer?
Reply By: Sarg - Sunday, Aug 06, 2006 at 12:28
"It has a copy of trial version of Oziexplorer on the CD"
You will need a "purchased" (registed) copy of Ozi to import maps. The trial is to have a look & play with it before deciding if you want it.
AnswerID: 187410
Reply By: bgreeni - Sunday, Aug 06, 2006 at 13:07
If you download both the demo version and the trial version from
www.oziexplorer.com/ you should be able to perform most function of Ozi with one or the other
Bruce
AnswerID: 187418
Follow Up By: Member - Andrew (QLD) - Sunday, Aug 06, 2006 at 14:03
However the problem is that the OP wants to use more than one feature at once eg Load Waypoints AND view maps in other formats. Best to just buy Oziexplorer or use another program that will recognise the file formats supplied.
Buick, taken from the Oziexplorer website, the features of each version are:
The Shareware/Demo version is missing many features that you get in the full purchased version:
- Full communication with the GPS for upload/download and moving map
- Only allows maps in BMP image format to be loaded
- Only loads maps in WGS84 datum
The Trial Version has almost all the features of the full version (works will all supported image formats and datums) but with these limitations:
- No communication with the GPS for upload/download
- No saving or loading of Waypoints, Events, Tracks etc
- No saving of map as an image file
- Will close down after 1 hour of running (must be restarted)
FollowupID: 444716
Reply By: buick - Sunday, Aug 06, 2006 at 15:02
Thanks All,
I have just ordered oziexplorer from the shop.
Should get it in a couple of days and then I should be right.
AnswerID: 187436
Reply By: Pajman Pete (SA) - Tuesday, Aug 08, 2006 at 08:16
Great program - you will enjoy it.
AnswerID: 187787
