80 series hand brake
Submitted: Sunday, Aug 06, 2006 at 20:45
ThreadID: 36518 Views:2280 Replies:4 FollowUps:2
just got home 2 weeks ago been to the cape got to bamaga 05 june no trouble exprct LOST USE OF HANDBRAKE by the time we got back to cairns lever operates ok but does not hold. about to strip rear wheels to inspect,any help please and how to stop it happing again thanks mal b
Reply By: 120scruiser (NSW) - Sunday, Aug 06, 2006 at 21:07
Only way to do Landcruiser handbrakes is to start at the rear.
Back off the adjustment at the handle and then remove rear wheels.
Adjust rear shoes until they lock and then back them off 3 clicks of the adjuster.
You can then adjust the handle height.
For a quality built car they have a crap handbrake.
Lets hope the new Landcruiser next year is a better designed system.
Hope this helps
120cruiser
AnswerID: 187494
Follow Up By: Member - Mal B - Sunday, Aug 06, 2006 at 21:40
thanks 120 but more interested in what caused it i think when i strip it will be full of mud thanks mal b
FollowupID: 444787
Reply By: ellmcg - Monday, Aug 07, 2006 at 05:58
The process may have been sped up by mud, but 80 series handbrakes do tend to 'soften'? rather quickly, regardless of the conditions they're in.
AnswerID: 187537
Reply By: Member - Steve (ACT) - Monday, Aug 07, 2006 at 16:04
We just got back from the Cape, three 100 series and two prados all returned with no handbrake, we started having trouble around the same time! Did you do the OTL? Maybe all the mud and water through there!!
Steve
AnswerID: 187652
Follow Up By: Member - Mal B - Monday, Aug 07, 2006 at 19:29
yes on the way back did the 2 creeks north of fruit bat falls ,then tried cockatoo creek but the water was flowing too fast,looked at gunshot from the bramwell junction side no hope .also tried to get from musgrave roadhouse into lakefield national park but rd closed [i beleave its still closed] we were back into cairns about the 18 june let you know results when i strip my cruiser thanks mal.
FollowupID: 444969
Reply By: Member - Davoe (Nullagine) - Tuesday, Aug 08, 2006 at 14:27
Wasting your money on the handbrake with any toyota, They will go out of adjustment within weeks again if you are lucky.
Just make sure you have it in 1st or preferably reverse when you park it (well for a manual at least) and they hold just fine on compression
AnswerID: 187851
