Broken Panhard Rod
Submitted: Monday, Aug 07, 2006 at 11:58
Member - Geordie C (WA)
Has anyone found a supplier for an adjustable rear panhard rod that will fit a 1992 Pathfinder as
mine is busted.
On a recent trip through the Pilbarra in WA, I managed to snap the rear panhard rod. I thought that there would be lots of other
suspension components that I would break before the panhard rod. After about 3,500km on this trip towing a camper and over 1000km on very corrugated roads, I was glad that the final break occurred at low speed only 5km from the highway.
I did a trackside repair (really nice) with four strong tent pegs tied around the offending panhard rod with heaps of nylon chord then Gaffa taped for added security ( I couldn't find any fencing wire). This got me over 150 km back to
Carnarvon where I had it welded as
well as they could at 4:30 on a Friday arvo (beer O clock).
Anyway I got the Pathy and family back home 900km to
Perth the following day.
Has anyone got an adjustable rear panhard rod on their WD21 Pathfinder or Terrano. The wreckers over here want so much (shi#@ $180 for a second-hand one) that I could buy a new one from 4way or the like if they make one.
I have been to almost every 4WD
shop in
Perth. A GQ Patrol unit has the same diameter bush housing on both ends (as the Pathy) but is only 970mm long. My Pathfinder with 2.5in lift needs a panhard rod of 1015mm (centre to centre).
Any ideas would be appreciated.
Geordie
Reply By: Member - Jeff M (WA) - Monday, Aug 07, 2006 at 14:52
Surley you could get the adjustable type for the GQ then? I know there are some monster lifted GQ's around
perth that would require longer adjustable rods than standard... I know guys with GQ's that have huge lifts.
It seems to be a common problem with lifted GQ's too, I know too guys personally that have either snapped or bent panhard rod's in reasonably easy terrain...
187631
Follow Up By: Member - Geordie C (WA) - Tuesday, Aug 08, 2006 at 14:21
Yes I think some of the GQ ones might extend far enough. However I have measured one on a 5" lifted GQ and it is still only 990mm long (20mm over standard), I need 1015mm.
445104
Reply By: kev.h - Monday, Aug 07, 2006 at 17:29
Hi Geordie
Can't be a lot of help with the panhard but curious what lift kit did you fit to the front and are there any tyre wear issues?
Regards Kev
187669
Follow Up By: Member - Geordie C (WA) - Tuesday, Aug 08, 2006 at 14:39
Kev,
No tyre wear problems at the moment.
I have used the Superlift brand upper control arms at the front. I have also replaced all the bushes, ball joints and fitted lower profile bump rubbers to get better articulation (be careful with this as there is a safe limit). I have also heard bad things about fitting ball joint spacers to the top. HD torsion bars are from Japan NISMO I think. Tyre wear has been an issue but only when the alignment is out from worn ball joints and when the tie-rod ends or drag link are loose. The steering linkages, pitman are, drag link and tie-rods in these things are notorious for movement then scrubbing tyres on one side. I am currently working on a new steering setup, when the panhard rod is fixed.
At the rear I have Lovells HD springs which give about 2.5" empty and 2" when lightly loaded. I have rubber coil spring spacers top and bottom (
conveyor belt rubber). Poly air-bags help to keep it level when fully loaded and towing a trailer.
Shocks are ARB all round. they give a good ride and articulation.
445109
Reply By: Grandpa joe - Monday, Aug 07, 2006 at 17:32
Ferdie at 3rd,s Productions Blacktown NSW can wip one up for ou ina flash, or you could try Simon at 4Way
suspension across the road. I am sure they would be willing to help you out with a postal delivery to your door.
187671
Follow Up By: Eddy - Monday, Aug 07, 2006 at 19:28
Grandpa joe.
100%
you were the only one to answer the question with an real answer.
ps: You do should spell your name with a capital J for sure.
Top answer Joe.
444968
Follow Up By: Member - Geordie C (WA) - Tuesday, Aug 08, 2006 at 14:18
Thanks Joe,
I see that 3rd's has been recomended by a few people, they might be the way to go.
445103
Reply By: Andrew-rodeo - Monday, Aug 07, 2006 at 19:35
Have you tried Pedders
Suspension?
187701
Follow Up By: Member - Jerry C (WA) - Tuesday, Aug 08, 2006 at 00:05
How about K&N 4WD in Canning Vale ?
445035
Follow Up By: Member - Geordie C (WA) - Tuesday, Aug 08, 2006 at 14:25
Yes tried Pedders and WA Suspensions but have not tried K&N yet.
445106
Reply By: Member - Ian W (NSW) - Monday, Aug 07, 2006 at 20:29
Contact Ferdi at Blacktown, he probably won't even to whip you one up, he will just pull it off the shelf.
My son has a GU with full 4" lift and sourced his panhard from Ferdi, the rest of the components come from Simon at 4Way who are across the road from Ferdi.
If you need more info send me a member messsage and I will be happy to chase up contact details
Ian
187716
Follow Up By: Grandpa joe - Monday, Aug 07, 2006 at 20:55
Your on the ball Dad!
444990
Follow Up By: Member - Geordie C (WA) - Tuesday, Aug 08, 2006 at 14:24
Thanks Ian,
Yes I would like a direct number, Will send you a message.
Geordie
445105
Follow Up By: Member - Geordie C (WA) - Tuesday, Aug 08, 2006 at 16:02
Thanks Ian and Joe,
I have found 3rds productions contact details on the web site.
445116
Reply By: Member - Geordie C (WA) - Tuesday, Aug 08, 2006 at 19:39
Thanks to all of you that replied,
I have now got contact details from Snake Racing, 3rds productions and Superior Engineering.
Snake have replied that their GQ rod will extend that far so I may have a winner.
Here are some photos of the damage
[IMG] Site Link
The repair that got me 150km back to
Carnarvon
[IMG] Site Link
and the track that was probably the cause
[IMG] Site Link
187922
Reply By: Member - Geordie C (WA) - Tuesday, Aug 08, 2006 at 19:44
Oops the photo link didn't work.
Here are some photos of:
the damage
[URL= Site Link
Carnarvon
[URL= Site Link
[URL= Site Link
187925
Follow Up By: Member - Geordie C (WA) - Tuesday, Aug 08, 2006 at 20:02
sorry about the photos
445166
Follow Up By: Member - Geordie C (WA) - Thursday, Aug 17, 2006 at 19:03
Here is the track that helped bust the rod
My bush repair
447030
Reply By: desray - Tuesday, Aug 08, 2006 at 22:42
Wilkinsons suspensions in Bayswater should have what you want or will know were to get it.
188000
Follow Up By: Member - Geordie C (WA) - Wednesday, Aug 09, 2006 at 11:19
Thanks desray,
I will give them a call.
445321
Follow Up By: Member - Geordie C (WA) - Thursday, Aug 17, 2006 at 19:01
Yes Wilkinsons had a panhard rod from a 80 to 100 series Landcruiser that was adjustable to about the correct length and only needed some modifications to the bushes to fit.
Geordie
447029
