Boat ,Bike and box trailer all in one
Submitted: Tuesday, Aug 08, 2006 at 20:11
Member - BBB
I want to build a 3in1 trailer.
It will be 8x5 single axil trailer for the most of the time it will carry a 3.55m tinny with motor and all the gear.
I don't want to carry the boat upside down as it is a pain to reload and I want the boat set up ready to go at a moments notice and the boat will be stored on the trailor most of the time.
It also needs to carry 3 full size trail bikes when needed their is time to load this on and get ready as these weekends I have to plan.
As
well it needs to be a box trailer for general use.
Have any of you come up with this idea and built or bought one if so could you send me a photo or plans or description of what you have.
Thank You
BBB
Reply By: hoyks - Tuesday, Aug 08, 2006 at 21:12
It might be a bit more work, but how about you build a trailer frame and weld on some square section to take all the rollers or rails.
Then you could build a box to drop on the top after you remove the rollers with pins to go into a few of the roller holes. Then you can toss up wether it is easier to make a set of rails to hold the bikes in a similar slide on slide off fashion, or tie the bikes down in the box.
187969
Reply By: frosty01 - Tuesday, Aug 08, 2006 at 23:24
Hi BBB,
I have just joined up as a visitor so this will be my first response. You could build your 8x5 box trailer as normal, then what I have done with
mine is to fit a removable frame to the inside of the box.Then to this I have fitted the bike runners,so therefore it is fully removable.You could also do this with boat rollers on a similar frame with wooden skids atached to the top of the sides.I hope this helps.
regards
Frosty01
188008
Reply By: _gmd_pps - Wednesday, Aug 09, 2006 at 02:05
www.belcocustomtrailers.com.au/landsea.htm
gmd
188023
Reply By: madcow - Wednesday, Aug 09, 2006 at 08:04
You only need to locate the front wheel of you bikes when in the trailer. I folded some sheet to a "u" section and bolted them onto the front inside wall of the trailer leaving a 50mm gap off the floor to allow easier cleaning. I made my own drop in assembly but found it a pain to store when not in use.
188040
Reply By: Davo - Wednesday, Aug 09, 2006 at 09:25
BBB,
ahhh - the ultimate all-round trailer search!
Considering your requirements, and that it's an 8x5 trailer, you have to make some compromises.
I have a similar issue when I sold my ute and upgraded to my Landcruiser T/D.
I had a 7x4 heavy duty box trailer custom-built by a
Perth Trailer manufacturer.
My budget was $1600. I had an extra-long drawbar fitted so that I could put a lockable & dust-proof toolbox with 2xjerrycan brackets on it for my riding gear and tools, and/or fishing/
camping gear.
Here is a good idea for when you want to transport multiple bikes. smart arse bike vice
I personally don't use one of these; I have never had the need to, and I have done a lot of driving with the bike(s) in the trailer.
A block of 4x2 wedged between the front guard and your front tyre will stabilise the front end - the rear tyre requires a ratchet strap/additional tie-down since it has a tendency to bounce around on corrugated/rough roads
Like other posters mentioned above and with the trailer's inherent restrictions, the removable cradle is your best option for the tinny; this will make launching it a bit stressful I think due to it's height off the ground.
In hindsight I think I should have ordered an offroad 8x5 trailer with a similar configuration (toolbox, etc).....but I recently bought a Trak Shak, and figured on getting one of these to be mounted to the back on the supplied reece-hitch
With a boat loader (to be yet fitted) and a folding bulldog trailer, I think I'll have all bases covered (it only carries one dirtbike though) ezimotow
Hope this helps.
Davo
188060
Reply By: Redback - Wednesday, Aug 09, 2006 at 09:55
There is this as
well
From this mob, Trailer Made Campers
Baz.
188075
Reply By: Wisey (NSW) - Wednesday, Aug 09, 2006 at 19:19
BBB
Haven't seen or built one but here are my thoughts for what its worth.
Do you mean 5' wide (tray) with wheels/gaurds outside or underneath?
Box Trl: With removable front and back board. Hinges and Lock corners same as tabletop tray set ups.
Boat trl: Remove fr /bk boards, Drop in rollers to required positions as per normal along boat trl, set to height/spacings. Hand winch mounted on post, with U bolts onto trl frame or removable with same drop in fitting type as rollers.
Bike trl: Drop in bike wheel retainer, "C" shape as someone decribed, made as a frame for the 3 bikes (which could also hook/bolt to top of front board) and maybe using same system/holes as boat rollers and of course tie down points for bikes and boat.
Trailer floor height (for offroad clearance) may make boat launching/retreiving difficult, but a tilt set up built in would help if you want to go that way.
I can send photos of roller set up that I am picturing to better explain what I'm on about.
188197
