Where's everyone got their UHF mic mounted in 80 Series?
Submitted: Wednesday, Aug 09, 2006 at 08:32
ThreadID: 36613 Views:4902 Replies:8 FollowUps:6
Hi all, I have my UHF mounted in dash in the DIN pocket under the stereo. The dash is standard (ie no dash pods or console mods etc). I'm getting sick of the mic sitting loose next to the transfer lever and wondered where everyone else has theirs. I wanted to mount the clip thing that holds the mic onto a blank to save screw holes but I'm not that fussed. Only decent spot I could find was just below the instrument cluster on the left of the steering column but the mic cable dangles over my knees (long bloody legs). Any suggestions??? :-S
Scoey!
Reply By: Member - Cruiser (NSW) - Wednesday, Aug 09, 2006 at 09:18
I have the same setup and am also wondering where to put the mic holder without having to put holes in the dash, so if anyone has a solution, please post a picture or two.
AnswerID: 188058
Reply By: Joombi - Wednesday, Aug 09, 2006 at 11:39
Me three, thanks for asking the question scoey, I always think about it in the car but as soon as I get out, I forget about it...
AnswerID: 188105
Follow Up By: Scoey (QLD) - Wednesday, Aug 09, 2006 at 14:34
Hmmm, I'm starting to think that everyone with an 80 either has thier mic in the same spot we do or in a dash pod or overhead console! I thought we'd get at least one suggestion!!! :-S
Scoey!
FollowupID: 445372
Reply By: BenSpoon - Wednesday, Aug 09, 2006 at 15:01
I have a clip for the HF on the large square cutout cover behind the wiper stalk. Make sure you put the holder on a 45-degree angle though so it is easy to remove, but wont fall out when the car comes in for landing- sounds like where you mentioned scoey. At least here if you want to change spots later you go to a wreckers and get a new cutout cover, no need to stuff around with holes in the dash.
Another is infront of the handbrake on the side of the centre console unit. Just make sure you put it forward enough to still grab the handbrake button for your handbrake turns (if that useless handbrake cable hasnt stretched on you yet)
AnswerID: 188151
Follow Up By: Scoey (QLD) - Wednesday, Aug 09, 2006 at 16:29
That sounds exactly where I was talking about Ben, but I'll also check out down around the handbrake too!
Scoey
FollowupID: 445397
Reply By: phantom - Wednesday, Aug 09, 2006 at 15:10
I have a conglomeration of electronics surrounding my gear levers (80 auto) including sat phone with handset, gsm phone, cdma phone, UHF with handset, HF with handset. I originally was anti drilling holes in the console and in the main have avoided where possible. I have now changed my attitude slightly as I have seen the work that plastic repairers do thru work and they are brilliant. So now i am not so uncomfortable about it. I have my UHF Uniden 013 with detachable head and have the body hidden away in the front of the lift up console and just the face mounted under the dash. I have large bracket made to take the sat phone and have the handset pop rivetted onto the bracket which mounts through the floor (3 small holes in the carpet) and all mounted on the passengers side of the console. If interested I can get a photo or two and post them tomorrow.
AnswerID: 188155
Follow Up By: Scoey (QLD) - Wednesday, Aug 09, 2006 at 16:30
Yeah I'd be interested to see some pics Phantom! Cheers! Mines and 80 Auto as well.
Scoey!
FollowupID: 445400
Reply By: Mikee5 (QLD) - Wednesday, Aug 09, 2006 at 18:01
Mine is a 105 not an 80 but I have also put my UHF in the dash. I took out the double DIN standard radio and put in an aftermarket Radio CD in the bottom slot and the UHF in the top slot. I have a dash mat on the dash and under the centre of this I put a plastic/perspex plate about 300mm square. I heat moulded the perspex to fit the contours of the dash. Through this plate I have drilled holes and put countersunk bolts up through perspex, dash mat and GPS bracket to mount the GPS. On the side of the GPS bracket is the mic bracket. Simple, no holes and works a treat. I did put some extra double sided tape and velcro under the mat for extra security.
AnswerID: 188183
Follow Up By: Scoey (QLD) - Thursday, Aug 10, 2006 at 08:08
Sounds like a top idea but a lot of trouble just for a mic mount. I might wait till i have a few more toys! ;-)
Cheers Mikee5
Scoey!
FollowupID: 445536
Reply By: phantom - Wednesday, Aug 09, 2006 at 19:30
Hi Scoey,I just discovered that I either can't or it is difficlut to put pics on here. Can I just email them to you?
Phantom
AnswerID: 188202
Follow Up By: Scoey (QLD) - Thursday, Aug 10, 2006 at 08:07
Yeah sure Phantom - rosswright@aapt.net.au
Scoey!
FollowupID: 445535
Reply By: Kev M - Wednesday, Aug 09, 2006 at 20:19
Hi Scoey,
I have a dash mat and all I have done is zip tied the mic bracket to the dash mat. It works real well and you are able to put it where ever you like and no screw holes to worry about in the dash
AnswerID: 188217
Reply By: TUF80 - Wednesday, Aug 09, 2006 at 21:29
hi scoey remove the top center air vents get hold of a multifit car phone adaptor plate from a phone fitter or thin piece of 1 1/2' x 3' plate bend at 90deg place on inside of dash drivers with 1-2 screws refit vent mount mike pad to outer flat piece no visual holes in dash .works well for me .all up takes 15 mins & $1.50 regards glenn
AnswerID: 188246
Follow Up By: Scoey (QLD) - Thursday, Aug 10, 2006 at 08:11
Didn't think of there, the other option I thought of this morning on the way to work was a bit of plate bent at 90 deg but coming out of the ashtray or the actual DIN pocket under the uhf so that the mic would be mounted just in front of, and slightly below the UH088sx built in speaker. Thanks everyone for the input! :-D
Scoey!
FollowupID: 445538
