Plastic Drums and Boiling Water
Submitted: Wednesday, Aug 09, 2006 at 09:40
chump_boy
Morning all,
I'm looking at grabbing a few of those big blue plastic drums (205L ex chemical jobs) with a clamp on lid, but I was wondering if anyone knew what temperature liquid they would take?
It would be great if they could handle 130 degrees, good if they could handle 100 degrees, and OK if they handle 60 degrees. If they can only handle 60, I'll use steel drums instead.
Chump
Reply By: Gmouse - Wednesday, Aug 09, 2006 at 09:59
G’day Chump
I use 2 of them for cooling purposes (small hobby of
mine)
and generally pump hot
water into them around the 70-90C
and have found no problems with them at all...so far
Hope this helps
188078
Follow Up By: chump_boy - Wednesday, Aug 09, 2006 at 10:08
445298
Follow Up By: Hairy - Wednesday, Aug 09, 2006 at 12:47
Mmmm...
I think I know what your hobby is!
Hic..Hic
445346
Follow Up By: Gmouse - Wednesday, Aug 09, 2006 at 14:04
Good guess...
445362
Reply By: Member - uncle - Wednesday, Aug 09, 2006 at 10:05
Hi Chump, we use plastic black drums, and I'd say the blue ones are made from the same plastic, we dump our frying oil in them at around 150 deg and they are fine, we've put in at 180- 190 and still fine ,but wouldnt recommend it as we once had the plastic bung melt and had 30 litres of hot oil all over the
shop floor.Nice mess to clean up that one! 120 to 130 should be ok. Hope this helps.unc
188080
Follow Up By: chump_boy - Wednesday, Aug 09, 2006 at 10:09
Sounds good to me!
445299
Follow Up By: Member - Jeff M (WA) - Saturday, Aug 12, 2006 at 12:34
What kind of oil? :-)) Make some Biodiesel! If it's vegi oil and not tallow you could be selling it (if you are not already).
445933
Reply By: Member - Blue (VIC) - Wednesday, Aug 09, 2006 at 11:17
We use them at work and steam them out for re-use... High pressure steam at 130°C for several hours with no ill effects...
188098
Reply By: mfewster - Wednesday, Aug 09, 2006 at 11:20
I have been looking for a couple of those big blue drums (second hand). Anyone know where I can get them around
Adelaide?
188100
Follow Up By: Nick R - Wednesday, Aug 09, 2006 at 13:29
If you could use the ones with 2 inch bungs ask any dairyfarmer in the
adelaide hills or maybe a rural supply
shop, they sometimes have emptys. I had about 50 of them but I have a use for them and only have 20 left, then again I'm not near
adelaide.......
NickR
445354
Follow Up By: Des Lexic - Wednesday, Aug 09, 2006 at 13:41
Nick, I know of someone who lives near to you that doesn't need much of an excuse to go away for a week or two. I'm sure he'd deliver for a fellow forumite. LOL
445356
Follow Up By: mfewster - Wednesday, Aug 09, 2006 at 14:47
Thanks Nick, I will get out my phone directory. The 2 inch bung will be fine for what I have in mind.
Des, I'm not sure whether you are serious or whether this is an old joke between you and Nick?
445376
Follow Up By: Pajman Pete (SA) - Wednesday, Aug 09, 2006 at 17:16
I know a source in Adellaide for clean metal 205 drums with a 2 bung removable lid. They are used glue drums that have had a removable plastic liner in them. They wanted $15 each last time I was there.
445415
Follow Up By: mfewster - Wednesday, Aug 09, 2006 at 18:53
Hi Pete
That would do me. Where can I find them?
Many thanks
Mike
445430
Follow Up By: Member - JohnR (Vic)&Moses - Wednesday, Aug 09, 2006 at 19:23
Hey Mr Lexic, sorry Desmond, they would be good for your diesel to throw into the back as long as you have a good syphon. Nick may access a 1000 litre if you want one, plastic of course......... Cost a mint to fill it of course
mfewster, Nick may know some there in them thar hills. I think Des Lexic is having a go at me actually as not needing too much of an excuse but am locked at home at the moment
445442
Follow Up By: Des Lexic - Wednesday, Aug 09, 2006 at 20:00
mfewster, Nick has a paternal relationship with
John. It's been a couple of months since
John has had a holiday and he probably needs one by now.
445458
Follow Up By: Des Lexic - Wednesday, Aug 09, 2006 at 20:02
Hmmmmm
John, the 1000litre tank would be great but after paying the $1500 to fill it up, I can't afford to go anywhere. LOL
445459
Follow Up By: Pajman Pete (SA) - Thursday, Aug 10, 2006 at 07:19
Mike,
mail me at peter at nenke.info and I willl send you the details.
Pete
445524
Follow Up By: mfewster - Saturday, Aug 12, 2006 at 12:05
Pete, I tried the email but don't seem to have reached you.
Mike
445930
Follow Up By: Member - Andrew W (SA) - Saturday, Aug 12, 2006 at 12:33
Mike, I've seen them at Paramount Brown's at times. Sometimes $20. I think the price depends on how many pallets of them they have.
445932
Follow Up By: Pajman Pete (SA) - Monday, Aug 14, 2006 at 11:15
Mike,
I received your mail and replied with the details - do you have them yet?
Pete
446176
Follow Up By: mfewster - Monday, Aug 14, 2006 at 12:30
Hi Pete
No, I haven't received an email from you/ I just went and double checked.
I did receive a message from another forumite saying tha Paramount Brown stocked the 205l plastic drums however they don't have any in stock at the moment.
Mike
446189
Follow Up By: Pajman Pete (SA) - Monday, Aug 14, 2006 at 12:45
sent again to mike@fewster.org
If no luck, call me on O8 8I866327
Pete
446194
Reply By: Mr Fawlty - Wednesday, Aug 09, 2006 at 19:06
Well essentially this is a stupid response but hey, I enjoy living on the edge... Did you all know you can boil water in a paper cup? try it, the paper above the water will burn but the filled bit won't...Made lots of money in bets with that one. Another good one too is "who invented the steam engine?" James Watt I hear you all shout in unison but it was infact his wife, he just did some of the work for her. In those days women knew their place & were not allowed to hold patents let alone show intelligence of any type...So good old James helped Mary out & took out the patent in his own name. I have a copy if anyone is interested - all 700 odd pages of it. It is believed that Mary wanted the Watt (unit of power) called the Mary but this has never been substantiated. It is further alleged that James expended many, many watts trying to satisfy his wifes insatiable desire for "marital relations" & that she was having an affair with Jim's busness partner Matthew Bolton...
See the things you learn....
188192
Follow Up By: Member - JohnR (Vic)&Moses - Wednesday, Aug 09, 2006 at 19:27
hahahah, love to use your references as a good authority Mr Fawlty, until I give the reference name......
445444
Follow Up By: the outlaws - Thursday, Aug 10, 2006 at 09:44
your right about boiling water in a cup i showed my rug rats how to make hot chochlate in the bush they had choc milk cartons in the engel i lit a small fire dropped it to embers opened up the top of the cartons off milk sat them in the embers and it boiled away the look on there faces was priceless as they sat there drinking the hot chocky.
the look on mums face when they repeated this exercise at home in the back yard was even more priceless !!!!!
445556
Reply By: SA_Patrol - Thursday, Aug 10, 2006 at 08:43
Paramount browns in cavan sell them. They were very popular in Snowtown a few years ago.
188299
Follow Up By: mfewster - Saturday, Aug 12, 2006 at 12:13
Snowtown must have cleared Paramount Browns out.They don't have any at the moment. Any further suggestions?
445931
