floor mat/tray
Submitted: Wednesday, Aug 09, 2006 at 09:49
Gmouse
G’day all
I have seen front floor mat/tray…. plastic I think in a few 4x4’s
anyone know where they can be found?
Just trying to keep as much crap of the carpet as possible…yeah right…lol
Reply By: JJ - Wednesday, Aug 09, 2006 at 10:06
try Sand Grabba (QLD)(copy & paste).
I'm sure there's others. Will pass on when found.
188081
Follow Up By: JJ - Wednesday, Aug 09, 2006 at 10:40
Oops...musta done something wrong...
will try a different approach:
Sand Grabba (Qld based) www dot qmcc dot com dot au
or e-mail addy: info at qmcc dot com dot au
Will see if this works!
If not: April 2006 issue of 4WD Monthly page 224
445309
Reply By: Member - Stephen M (NSW) - Wednesday, Aug 09, 2006 at 10:15
Super cheap also sell them two types one are quit deep the other probably has about a 1cm edging all the way around, my mate has just picked up the deeper ones but finds them sliding down under his accelerator/clutch so is trying to work out how he will stop that from happening I think he paid about $60 for a set of four. Regards Steve M
188084
Follow Up By: JJ - Wednesday, Aug 09, 2006 at 10:45
What about placing a length of that non slip rubber matting we use in van cupboards? Also used under floor mats on slippery surface (in house).
Another alternative is self adhesive velcro, but that could disfigure the carpet.
445312
Follow Up By: Member - Stephen M (NSW) - Wednesday, Aug 09, 2006 at 11:01
Hi there JJ, yeah he has tried the velcro but wont work. The mats do have a pimple effct on the back of them but not enough to grip the carpet but wont allow the velcro tabs to stick to the back of them. Maybe as you said a rubber mat underneath might be the answer. Thanks for that will let him know. Regards Steve M
445319
Reply By: Gmouse - Wednesday, Aug 09, 2006 at 10:47
Yep, that's what I'm after...
Thanks for the replies...a great help
188093
Reply By: Grizzle - Wednesday, Aug 09, 2006 at 12:09
Kmart have them. I bought them for my patrol
188112
Reply By: blown4by - Wednesday, Aug 09, 2006 at 20:34
Got
mine at Repco & they are Roadgear brand to suit large 4x4's & cost $12 front pair on special & normally about 20 bucks I think & same approx for rear pair. The sides of the tray are about 40mm deep & there are little "pimples" on the reverse so they won't slip & they are more of a stiff rubber than a plastic. They are used by the outback hire car Companies and are referred to colloquially as "Snow Mats" because apparently when you get in with snow on your boots and it melts these trays catch & hold the
water. I looked at quite a few and many have sides that are too floppy, were too small, not deep enough & some of the really expensive ones (Michelin about $75/Pr) weren't any better than the ones I got. The front pair I got fit the GU as if they were tailor made with one edge resting against the tranny tunnel and the other rests against the doors when closed. The back section rests against that raised part of the footwell & they are long enough to reach up the angled section of the firewall. Only trouble is they stink of rubber a bit but I can live with that and hopefully a few more trips and subsequent washes will fix that. You just lift them out carefully and the vacuuming is reduced greatly which is great because I am not fully trained nor passed out on it's use:-)
188222
Reply By: otrom - Wednesday, Aug 09, 2006 at 23:30
I can vouch for the Sand Grabba mats.
They are moulded to fit your vehicle exactly. They look good, fit perfect.
I think they are the best thing you can buy, particularly if you do a lot of beach work. Just let the sand dry and it easily vacuums out. Best thing is, you don't get any sand in your carpet.
I paid $313 (12months ago) for front, rear and cargo area of my Pajero. Worth every cent in my opinion.
188272
