Mounting NGT TX in Cab Chassis
Submitted: Wednesday, Aug 09, 2006 at 13:21
Member - Craig D (SA)
Hi forumites,
I have a GU Cab Chassis and was wondering if anyone can advise the best place to mount the transceiver unit? Easiest place would be under the driver or passenger seats, however, I would be a bit worried when it comes time for
water crossings (might have a trip up the Cape next year).
Thanking you all in advance,
Reply By: Member - Craig D (SA) - Wednesday, Aug 09, 2006 at 13:40
Sorry people....I think I have figured out that behind one of the seats will be best.
Regards,
188129
Follow Up By: Turist (The Original One) - Wednesday, Aug 09, 2006 at 16:49
I may have a bracket that I used for that job, screws to the rear panel and the TX unit fits to it.
I'll check the garage later, let you know.
445407
Follow Up By: Turist (The Original One) - Wednesday, Aug 09, 2006 at 17:05
Yep, still got it.
Member message me if you want it.
It is a folded aluminium plate drilled to accept the TX mounting and drilled to screw to the panel behind the
seat.
Trying to work out the best way to get a slab to
Sydney may be the biggest problem.
445411
Follow Up By: Member - Craig D (SA) - Thursday, Aug 10, 2006 at 08:43
Bob I have sent you a member msg.
445543
