Prado Deluxe Bull Bar Vibration - Shaking Problems
Submitted: Thursday, Aug 10, 2006 at 17:24
Hector
Has anyone had problems with an ARB deluxe bar on a current model Prado. I am looking to fit one to my Prado but have spoken to four owners so far that are unhappy with it due to shaking left and right an constant vibrations on corrugated roads. ARB have told them that its normal and not much can be done about it. The interesting issue is that I have found no one so far that is happy with their bars but two owners whom I have spoken to whom have Toyota OE alloy bars fitted and not a problem.
Reply By: Redeye - Thursday, Aug 10, 2006 at 17:49
Hi Hector,
I hired a new Prado in
Cairns last month. The Bull Bar constantly hit the body every time I went over corrugations. It smashed some plastic spacers (cosmetic) items between the bar and the front of the wheel arch.
The hire company said they had approached the manufacturer and there was a recall in progress.
The vibration was quiet severe.
Redeye
188393
Reply By: Peter 2 - Thursday, Aug 10, 2006 at 18:10
Mostly due to the 'lightness' of the front end of the chassis.
A known problem with late model Prado's developing front end body cracks due to the extra movement caused by the weight of the bullbar and accessories on the front.
188396
Follow Up By: Hector - Thursday, Aug 10, 2006 at 20:23
This weakness if correct concerns me as I also plan to install a Magnum Winch
445673
Reply By: Member - Stan (VIC) - Thursday, Aug 10, 2006 at 19:14
The bar is mounted to the chassis and body is separted from the chassis.
So when you drive the bar would vibrate with the chassis independent of the body ;)
I don't have a problem with
mine braking anything off and it had been throught severe corrigations.... It also could be that the way it was installed is
the problem...
188410
Reply By: Crackles - Thursday, Aug 10, 2006 at 19:17
Hector it's a common problem with the poor mounting on the Prado's due to the crumple zone. Can make
driving lights almost unusable due to the shaking on some roads. ATS in
Geelong have made a fix for it that includes secure tow points.
Cheers Craig...........
188412
Reply By: Member - Andrew W (SA) - Thursday, Aug 10, 2006 at 19:21
The Toyota OE Bars on the Prado are quite
well designed. Fitment rates initially were as high as 70% - I don't think ARB had theirs ready.
Not all OE bars are made by the same manufacturer.
In the case of the current model Prado, quite sophisticated design and manufacture went into the bar and new metal forming techniques were used - the result is a product with extremely low warranty issues.
Ciao for now
Andrew (no connection to the manufacturer - just have been told by someone who knows)
188414
Reply By: kimprado - Thursday, Aug 10, 2006 at 19:42
Hi Hector,
I have the Toyota OE alloy bar on a 2003 model (current shape). At the time there was no other choice.
Like many people, I didn't have a high regard for alloy bars. However, that has changed after a recent trip to WA.
At the end of the day, the measure of a bar is the punishment it can take. We travelled through 600kms of untracked country which was the worse I've been through in five decades of 4wdriving.
I had no mechanical problems with the car and, given the pounding the bar copped, came away surprised.
The car suffered $6500 damage, principally from body repair, severe scratching and plastic panels being ripped off.
On the latter point, this is a big problem with the Prado.
Under normal conditions the alloy OE bar will serve your needs
In closing, I was a bit perplexed by Peter's comment that the Prado's front end was weak.
Kim
188419
Follow Up By: traveller2 - Friday, Aug 11, 2006 at 08:10
Not weak as such but it is a known problem with the body cracking around the front panels where the radiator mounts to when the weight of a bullbar and /or winch is fitted to the front. The extra weight causes more chassis flex which twists the body past what it was designed to do and the cracks develop in the sheet metal.
Alloy bars and no winch might not cause any problem.
445712
