NOISY LEAKY GEARBOX, '02 TD HILUX
Submitted: Friday, Aug 11, 2006 at 19:05
ThreadID: 36696 Views:2620 Replies:4 FollowUps:4
G'DAY GUYS, I HAVE A 2002, 3.0TD DUAL CAB SR5 HILUX GEARBOX COVERED WITH OIL (SEEMS TO BE FLOWING OUT FROM THE TOP OF THE BOX AND COVERING BOX AND CROSSMEMBER). GEARBOX OIL LEVEL CAN STILL BE FELT FROM THE FILL POINT AND TRANSFER CASE LEVEL IS GOOD. THE OIL OVER THE GEARBOX IS DEFINITELY GEAR OIL. WHEN COLD THERE IS A NOISE THAT SOUNDS HALF WAY BETWEEN A GRINDING/WHINING WHEN UNDER POWER (IN GEAR OR NEUTRAL, CLUTCH IN OR OUT). WHEN GEARBOX HAS WARMED UP THE NOISE DISAPPEARS (THE NOISE IS STILL THERE EVEN WHEN THE ENGINE IS WARM BUT THE GEARBOX IS COLD). ARE THE TWO PROBLEMS LINKED?
HAS ANYONE ENCOUNTERED THIS PROBLEM BEFORE OR HAVE ANY SUGGESTIONS? ANY HELP MUCH APPRECIATED.
CHEERS GUYS
Reply By: age - Friday, Aug 11, 2006 at 20:10
Have you had the gearbox oil changed lately ?. The threads on the bungs are slightly tapered and being cast material if the get overtightened they split along the thread. Oil spews everwhere.
Just a thought as had a similar issue with my old 80 Series - same symptoms. Luckily those that overtightened admitted fault and fixed.
AnswerID: 188581
Follow Up By: Heefers - Friday, Aug 11, 2006 at 20:39
Changed the oil myself, definetely didn't overtighten bungs (nipped them up about "tap tight"). Oil over entire box, (both sides and bottom). Many thanks for your reply age.
FollowupID: 445841
Reply By: Peter 2 - Friday, Aug 11, 2006 at 20:52
Didn't put too much in and it is being forced out the gearstick hole when hot?
AnswerID: 188592
Follow Up By: Heefers - Friday, Aug 11, 2006 at 20:59
1.1L, just as the doctor prescribed. Was always under the idea that the filler hole was positioned at the optimal fill level so as that you can not overfill the box? Is this correct?
FollowupID: 445847
Reply By: TerraFirma - Friday, Aug 11, 2006 at 22:48
Hummmmm, Sounds like human error..?? Are the 2 problems linked.? Possibly.?? Get it in for a look at somewhere, sounds like a pressure issue.
AnswerID: 188615
Follow Up By: Heefers - Friday, Aug 11, 2006 at 23:19
Possible for a breather blockage to cause these symptoms?
FollowupID: 445878
Reply By: Spike me - Monday, Aug 14, 2006 at 15:14
The noise sounds like the main bearing or (bearings)is on the way out in the Gbox. This will need replacement and a gearbox dismantle. This should be treated ASAP.
The oil leakage could be a blocked breather, or the seal in between the gearbox and transfer case leaking oil between them and then coming out the breather. The excess would leak out in this case. I suggest that you re check the oil levels to firstly see where it is coming from. If the in-between seal is cactus it will need replacement (gearbox out).
The grinding or whining sounds like it is caused by the damage done by lack of oil. I would go and see a gearbox specialist. Do not take it to a mechanic as they usually take them out and send them on anyway.
AnswerID: 188930
Follow Up By: Heefers - Tuesday, Aug 15, 2006 at 07:47
G'day Spike Me,
Many thanks for your reply, have taken your suggestion and she's booked in to see the specialist.
Heefers
FollowupID: 446387
