AnswerID: 936 Submitted: Tuesday, Aug 21, 2001 at 00:00
ron
replied:
David,
I tow a 14.6 Sunchaser poptop with the standard transmission features of an 2000 SE TD Auto
Jackaroo which does not include a transmission cooler. My local dealer tells me they have no external
transmission cooler, but the transmission oil is cooled by passing it through the raditor.
I can't understand how that works but I can say that on the one long trip of around 2000km
through the
Grampians, Portland, Mt Gambier and north to Renmark on roads that are generally
undulating I sensed no apparent heating of the transmission. That road had just a few long steep
climbs of around 1-2 km but nothing that placed the setup under any extended stress.
When conditions allow" Jack" will tow our unit along at 100 km right on 2000 revs on the flat and
I drive in power mode with the overdrive on and cruise control and it seems to just purr along.
Certainly does not work as hard nor appear to place anything like the load the same van did
on our FORMER 97 El Falcon. In that vehicle we covered over 35,000 km with the van in tow
in all conditions without any transmission problems other than to replace a 59 cent oil seal which
was poorly fitted during routine service. It had no extra transmission cooler fitted and you
could feel the transmission tunnel was warm but it never ever let us down. I doubt you need one
but ask your local dealer if the transmission is covered by warranty when towing below the
nominated maximum 2500kg weight. I understand it is and therefore assume right or wrong
that the transmission is built to do the job without an additional cooler - it defies reason for
a manufacturer to allow a tow weight of 2500 kg and then require an extra cooler to be fitted.
Perhaps others may have a more mechanically based opinion In all our travels I have not heard
of a single transmission problem from any Jackeroo towing weights with the designated limits and
this reinforces my opinion that you won't/don't need one. Regarding
tyres I certainly would not change
them until the factory fitted one wear out if you do as we do and only make the occasional sortie off road.
If you want to get into regular seriously tough ground you might need something stronger but unless
you tow a specifically built off road van you'll leave it parked some place anyway when you venture
onto the rougher stuff. My mate's Pathfinder had no trouble with standard
tyres travelling to Cape
Leveque or along the
Gibb River Road and the
Karratha- Karijini (Hammersley Iron Road) which are
probably as rough on
tyres as you might get - he didn't so much as get a puncture - maybe lucky
maybe the fact that he doesn't rip and tear along. I certainly wouldn't be changing
tyres as
long as they are sound and roadworthy. Hope this helps - go for it!
Reply 2 of 3
