3rd Battery Tray LC 100 TD
Submitted: Friday, Aug 11, 2006 at 21:32
ThreadID: 36703 Views:2915 Replies:7 FollowUps:4
This is in response to a follow up from Ozman and Andrew W (SA) I have some pictures of the tray fitted to my mates 100 TD but I don't know how to put them on to the forum can anyone help us out ??
Barry
Reply By: Barry 2 - Friday, Aug 11, 2006 at 21:44
Should have included it was post 35709
AnswerID: 188601
Reply By: Member - Andrew W (SA) - Friday, Aug 11, 2006 at 21:59
Thanks Barry - you can email me - andrew at vividadventures dotcomau and I'll post 'em.
AnswerID: 188605
Reply By: Derek from Affordable Batteries & Radiators - Friday, Aug 11, 2006 at 22:35
Our kits are now in production for the 3rd battery.
I would like to see the photo's to compare designs. We relocated the fuel filter and fitted a large 330mm tray to take a 100 a/h battery. We also had to fit a brace to the side guard for extra strength. I was not comfortable with the strength in the wheel arch.
We now have a very robust kit.
Regards Derek.
AnswerID: 188609
Reply By: Sam from Weipa Auto Electrics - Saturday, Aug 12, 2006 at 09:41
I Still dont understand the need to fit a 3 battery to the 100 series why not use a high capacity n70zz in one side and a trojan deep cycle in the other with a redarc controller?? I have done this conversion about three or four times and the owners have been rapt with it?
AnswerID: 188641
Follow Up By: Barry 2 - Saturday, Aug 12, 2006 at 12:45
Hi Sam
I'm sure the owners of the conversions you have done are happy
The one thing I have learnt in all the years of trying different set ups is there is no right or wrong set up it all depends on individual use and expectations
Two n70z batteries wired in parallel as aux and third one as main start, run via Redarc is a set up that I am happy with, it runs my 85 ltr Weaco very well
When camped for extended time I find a Cristies 50amp Battery charger, charges my set up very quickly
Different set ups for different folks
Barry
FollowupID: 445934
Follow Up By: Sam from Weipa Auto Electrics - Monday, Aug 14, 2006 at 06:55
You are correct I just dont see the need to take up anymore room in the engine bay.
FollowupID: 446137
Reply By: Derek from Affordable Batteries & Radiators - Saturday, Aug 12, 2006 at 13:06
Picture as requested.
AnswerID: 188663
Reply By: Member - Andrew W (SA) - Saturday, Aug 12, 2006 at 14:11
Here's Barry's pics:
Thanks Barry.
AnswerID: 188666
Follow Up By: Spike me - Monday, Aug 14, 2006 at 17:38
Wow they are great pix
FollowupID: 446258
Reply By: Ozman - Sunday, Aug 13, 2006 at 13:53
Thanks for all the piccies and details.
I have looked at the ARB 3rd battery setup which only allows for a smaller (50ah) battery in a powder coated battery tray. The apparent reason is that a larger battery (70 - 100ah) wont fit in the ARB tray and is heavier and the guard that supports it all may fail under all the weight. (sounds possible)
I have been advised many times not to change the 2 factory fitted battery wiring setup as this may void my warranty with toyota.?? (lso possible)
I think the safest option is the smaller third battery and to be careful if staying put for too long without a reacharge..... or the christies charger sounds great, but a bit dear in $$$.
dave
AnswerID: 188772
Follow Up By: Sam from Weipa Auto Electrics - Monday, Aug 14, 2006 at 07:01
I cant see any reason why it would void you're warranty with toyota but I'm sure they will try and tell you it will It doesnt void youre warranty if you fit a nice new n70zz to you're 79 series (well it will void the warranty on the battery). So basicaly thats all you're doing you just have to make sure you have a battery that matchs the capacity of the 2 stanadard ones.
FollowupID: 446139
