Savage 340 Gull tinnie. Anyone used one?
Submitted: Saturday, Aug 12, 2006 at 19:26
ThreadID: 36721 Views:16738 Replies:5 FollowUps:12
I'm looking to buy a good tinnie for 'car topping'. As always for car topping, I'm looking for the most boat for the least WEIGHT. This boat is much lighter than most others of similar size (62 KG, v 70 to 80 kg). They do this by using slighter lighter aluminium in the sides. Most similar size boats use 1.6 mm ali all over. This one uses 1.6 mm in the bottom and 1.3 mm in the sides.
Anyone with any experience with this boat and whether the lighter ali sides has any discernable effect (other than reduced weight).
I'll probably be manually loading onto racks on the Hilux, so weight is important, but not as important as safety and servicability.
Reply By: friar - Saturday, Aug 12, 2006 at 20:03
G/Day Norm I have a 3.45 allycraft 62kg,s 2 seats which gives you more room when standing throwing lures,had it about 5yrs no problems.I made a boat winch that drops on bull bar which i winch the boat up on top of xtracab hilux,jut stand the boat up leaning on rear bar & winch on.I also take a little bulldog collapseable trailer sometimes,depending where i am going.
AnswerID: 188708
Follow Up By: Member - Norm C (QLD) - Saturday, Aug 12, 2006 at 22:21
Friar, I've got the current (I think) Allycraft booklet and I don't see the 3.45 in it.
They have a 3.5 that weighs 71 KG, but is only 600mm deep (I am looking for 700mm or more if possible). Their 3.55 weighs 78 KG and is 650 mm deep.
Your winch idea is good, but I'm trying to KISS for the moment.
FollowupID: 445995
Follow Up By: gav99x - Monday, Aug 14, 2006 at 09:31
Hi NormC, just thought I'd put my two cents worth in re the 700mm depth measurement you mention as an ideal for your tinnie. All I wanted to say was don't take the quoted brochure measurements as gospel, they are widely varying to say the least. When I bought my boat (4.1m Allycraft Rhino) I physically went round and measured the keel/gunwale depth on the main contenders and many were not what was quoted in the catalogues. Some manufacturers measure the internal depth from keel to gunwale, and some measure the external measurement (by sitting the boat on flat ground and simply measuring from the gunwale down to the ground (this takes into consideration the thickness of the keel and adds around 50mm but doesn't add to actual hull depth).
Another thing to look for (and actually measure) is the depth of the transom (where the sides meet the transom). You'll find some manufacturers (Quintrex is one) on some of their models, have a nice deep keel to gunwale measurement, but a low freeboard measurement at the transom. To my mind with outboard/ etc. plus operator at the rear of the boat (tiller steer), having as much freeboard in this area is very important.
Anyway, as I said just my two cents. Bottom line - actually take the time to go and measure each vessel that falls into you're length range as you may find that all is not as it seems. (one well known manufacturer I measured took into consideration the bow rail in they're depth measurement!).
Gavin
FollowupID: 446159
Follow Up By: Member - Norm C (QLD) - Monday, Aug 14, 2006 at 10:22
You are right there Gavin. I recognized this when I took a tape measure to a boat shop a few days ago. A particular boat was listed as .88 deep. Took me a few minutes to find a .88 measurement. It was there; boottom keel to top of gunwale at the deepest point. Usable depth inside floor to top of gunwale at deepest point was around .82.
Another key difference between manufacturers is welding or riveting in seats. On boats below 3.9, some of the big manufacturers still rivet in seats, while others weld them.
All else being equal, I'd have though welding woud be much stronger. Any thoughts on whether riveting is OK?
FollowupID: 446164
Follow Up By: gav99x - Monday, Aug 14, 2006 at 10:47
G'day Norm,
Yeah in my opinion welding is much stronger and is my preference, however I think one of the major issues with rivets in the hull to fasten the seating is corrosion. Over time you can get a small amount of electrolosis around the hull surface that surrounds the rivet. You only need a little bit to form a gap. Albeit the area's affected aren't permanently submersed and therefore won't sink the boat, however once it happens you'll have to drill out and replace with larger rivets or similar etc.
In saying that though, there are still a fair few old dehavilands getting around out there on the water and these used a lot of rivets (not just for the seats either!) - comes down to how well they are looked after with respect to washing down etc.
Personally, for corrosion resistance and strength I think welding is the way to go. You may sacrifice a little with weight but I think negligible.
Another thing to look out for in my opinion is number of ribs in the floor (and to a lesser extent the sides), and also how they are fixed to the hull. The more ribs the more rigid - assuming they're welded to the hull well. They should be welded at both the keel and the chine with good stong welds.
The shape of the hull is important too, you need to get a good compromise between stability and ride comfort. You may have noticed when you look around that some manufactures lean one way or the other. Seajay and Horizon in my opinion go for the stability factor with a relatively low deadrise at the transom (flatter V) but higher sides to compensate. i.e. out of say a 700mm depth measurement the sides account for (say) 550mm of that, but the hull only 150mm. Another manufacturer will lean towards the ride comfort corner, with that 700mm being made up of say 500mm sides and 200mm hull - resulting in a deeper V which rides better but is slightly more tender at rest. Optimally in my opinion you want to find something in between - with a relatively fine forefoot to cut the waves, then a nice shapely bottom that flattens out somewhat towards the rear to retain some stability at rest. I find my Allycraft leans a little towards the ride comfort side with a very deep V when compared to others, it's a little tender at rest but I'm used to it now and appreciate the ride in rougher water. The smaller the boat the more important the stability at rest factor is though.
FollowupID: 446167
Follow Up By: Member - Norm C (QLD) - Monday, Aug 14, 2006 at 11:04
Good advise there, thanks Gavin. I've owned a number of boats before, but none this small.
All boats are a compromise, but none more so than a car topper I am rapidly finding.
FollowupID: 446169
Follow Up By: gav99x - Monday, Aug 14, 2006 at 11:16
Yep absolutely true Norm.
As a reference have a look at this site
www.seamedia.com.au/sea_library/boats.php
scroll down to the articles on the Horizon 3.0 and 3.5m rooftoppers that they have put together. One article is free and the other $5, they take a good in depth look at what makes a good small boat and what to consider, including weight etc. Might give you some good ideas.
Good luck
FollowupID: 446179
Reply By: Member - uncle - Saturday, Aug 12, 2006 at 20:12
Hi Norm, we've got the Stacer 3.4mtr , not sure how much it weighs but reasonably easy for Jodie and I to lift it onto the CT if we need to.Wouldn't go much bigger though in size as it's borderline to lift for a male female combo, go bigger you'd need two males.
AnswerID: 188709
Follow Up By: Member - Norm C (QLD) - Saturday, Aug 12, 2006 at 22:27
Uncle, Stacer makes good boats. I recently sold my 5.25 Easy Rider with 125 HP (a bit big to carry on the 'Lux). The only 3.4m in their current range seems to be the Proline, which is only 500mm deep. I'm after something a bit deeper if I can.
I have their 350 Seasprite on my list, which is 760mm deep and weighs 76 KG.
My initial loading plan will be to tip the nose up onto the rear bars on the 4B, then slide it forward (on rollers) to get it on the vehicle.
FollowupID: 445998
Reply By: Bundybear - Saturday, Aug 12, 2006 at 21:01
Norm,
I suggest that you seriously look at
Site Link
I know quintrex can be a bit more expensive but they are worth the money when it come to a superior ride and quality. I would think twice about a savage. There is talk in the boating industry, "Savage by name savage by nature".
The lighter sides has little effect if the vessel has two bench seats, especially if there is bracing on the floor.
Another brand that also maybe worth a look is Seajay, although not as a comfortable ride as quintrex, quality workmanship is evident.
AnswerID: 188717
Follow Up By: Member - Norm C (QLD) - Saturday, Aug 12, 2006 at 22:14
Thanks Bundy,
The Quintrex Dart 355 is on my list, but weighs 78 KG. Other than the Dart, I reckon most of the other Quintrex range are a bit low at the sides.
I also have two from the Sea Jay range on the list. The Angler 3.55 weighs 76 KG and the Nomad 3.5 weighs 68 KG.
I've had a number of boats before, but this will be my first 'car topper'. I'm after something with reasonable depth, around 3.4 to 3.5M, strong, but not too heavy.
FollowupID: 445992
Follow Up By: mattie - Sunday, Aug 13, 2006 at 12:30
Hi Norm
looking at a similar set up myself but i think i will go to a 3.9m as age is still on my side and will only go on the ct most of the time.
A mate of mine sells boats in Adelaide and he got me looking at Horizon Boats i had them send a catalog and the 3.55m is 1.65m wide, .85m deep, 70kg and a max 15hp but only 3 people but i suppose all boats this size are only rated to this. I think they are sold as Quicksilver boats as a package by Mercury dealers.
If u go to the 3.75m it is 1m deep, 1.8m wide but weight is an issue at 95kg this and the 3.95m are the same other than weight and length.
Mattie
FollowupID: 446026
Follow Up By: Member - Norm C (QLD) - Sunday, Aug 13, 2006 at 14:35
Thanks mattie, hadn't looked at these. The 3.55 you refer to is actually 85 KG. Not surprising as it is a touch wider and deeper than most in this length. Sounds like a good boat, but a touch heavy and possibly a bit wide for me to carry on the 'Lux. My bars will be 1.8 long, but the feet are only about .95 apart.
The 70 KG one is only .65 deep, a bit shallow. Got the info from their web site.
It is all a compromise. Just a matter of finding the best compromise for my needs.
FollowupID: 446045
Follow Up By: mattie - Sunday, Aug 13, 2006 at 16:57
Hi Norm
I wrote the figures in as the web site may not have been updated for while as the catalog i was sent from Horizon boats last week are as i wrote above but it may be worth a phone call to check.
Mattie
FollowupID: 446060
Reply By: baza - Monday, Aug 14, 2006 at 16:48
These look interesting, although I don't really know much about boats: www.flatoutboats.com.au - caught a glimpse of them on the new inventors on ABC.
AnswerID: 188940
Follow Up By: Member - Norm C (QLD) - Monday, Aug 14, 2006 at 16:53
Thanks baza. I'm familiar with the folding boats and have been in a portaboat (similar to the Australian one you posted on). For me, a bit of a pain to set up all the time, and I just wouldn't feel safe enough in croc country in one (although my couple of runs in one was in Bullock Creek in Darwin!!).
I've just posted another thread that I lashed out and bought a Stacer tinnie today.
FollowupID: 446249
Reply By: Bundybear - Monday, Aug 14, 2006 at 22:17
Norm,
A mate of mine just bought a 3.75m Venom Inflatable from Swift marine on the Gold Coast.
www.swiftmarine.com.au/redback1001.htm
Give them a call and talk to Scott Wilson. If you want most boat "bang" for your bucks it is not able to go past these vessels. I use a 6m version of this vessel and a 4.7m version at work and their ride and weight is far superior to any alloy boat you will ever use. Price could be an issue though.
Bundy
AnswerID: 189030
