Glow Plug system troubles
Submitted: Monday, Aug 14, 2006 at 01:39
garb
Having serious problems with my 2H engine starting system. It is burning out the fusible link for the glow plug system. The insulator on the small bar that connects to the longer heater bar is in poor condition. Was wondering if a short here would cause the fusible link to burn out.
Reply By: Member - Oldplodder (QLD) - Monday, Aug 14, 2006 at 08:00
Could be.
Had a similar proble on my paj last year.
Could be a glow plug shorting.
Ended up last year doing some TLC on the whole glow plug system and carefully checking all connections right from the battery (the main bus bar connection was pretty poor) and checking all of the glow plugs. Had to replace two.
188870
Reply By: michael42 - Monday, Aug 14, 2006 at 10:23
Just had the same issue with my Hilux, the local mechanic had the wire around the wrong way with the insulator, blew the 80 amp fuse for the glow plugs. Swapped the wire around, hey presto!!
Also replaced the glow plugs, as 2 of them were shot.
Regards,
Michael
188891
Reply By: Footloose - Monday, Aug 14, 2006 at 10:47
Yep :)
188896
