Nissan Patrol
Submitted: Monday, Aug 14, 2006 at 12:38
ThreadID: 36757 Views:2370 Replies:12 FollowUps:15
Question: Has anyone experienced trouble with the intercooler leaking on 3.0lt GU Patrols?
Reply By: cam_champion - Monday, Aug 14, 2006 at 12:48
batman, do you have idea where it is leaking from?
AnswerID: 188910
Reply By: Batman69 - Monday, Aug 14, 2006 at 12:59
Cam, It's leaking from the front left hand side at the join between the coil and the outlet chamber.....
AnswerID: 188913
Reply By: Notso - Monday, Aug 14, 2006 at 13:07
Mine has always had a bit of a weep of oil from that area, hasn't got any worse. Up to 180,000ks now.
AnswerID: 188914
Reply By: hl - Monday, Aug 14, 2006 at 13:08
Allow me to correct your post.
"Has anyone heard of the Intercooler NOT leaking"
AnswerID: 188915
Reply By: Batman69 - Monday, Aug 14, 2006 at 13:12
OK so I can gauge by the replies that it is not uncommon, is there a way to get it repaired? Would a radiator repair shop be able to do a fix? I don't fancy spending $1k to get a new one and they don't exist second hand...
AnswerID: 188916
Follow Up By: hl - Monday, Aug 14, 2006 at 13:14
If it is just weeping a bit of oil from the PVC blowby, I would not really worry about it. Unless you can hear it hissing........
FollowupID: 446203
Reply By: Batman69 - Monday, Aug 14, 2006 at 13:16
Hl, what is the PVC blowby?
AnswerID: 188917
Follow Up By: Notso - Monday, Aug 14, 2006 at 13:23
The Positive Crankcase Ventilation system that sucks the vapours out of the engine and feeds it into the air intake.
FollowupID: 446207
Follow Up By: Batman69 - Monday, Aug 14, 2006 at 13:34
Notso,
thanks for that, no doubt explains the weeping oil but the hissing means loss of pressure, not sure I've noticed a drop in power since the intercooler started leaking, but then again I don't know when it started leaking do I?
FollowupID: 446211
Reply By: Redeye - Monday, Aug 14, 2006 at 13:23
Yep mine is hissing. I am looking at a second hand unit so I can install. They go at the front in the first three veins closest the inlet.
Interesting thing is the hiss is only there 1000 to 2000 rpm and when the outside air is very cool <10 deg C. When the ambient air temp rises the hiss (whistle) disappears. It does not matter at what temperature the vehicle is (hot or cold).
Very interesting but annoying.
Garry
AnswerID: 188919
Follow Up By: Notso - Monday, Aug 14, 2006 at 13:24
A fellow on this forum had his welded by a radiator repair shop a while back. Seemed happy.
FollowupID: 446208
Follow Up By: Batman69 - Monday, Aug 14, 2006 at 13:32
Yeah, mine was hissing a bit too, might give a local radiator repair shop a try and I'll let you know what happens...
FollowupID: 446210
Follow Up By: Redeye - Monday, Aug 14, 2006 at 16:30
Thanks,
I took mine to an alloy radiator chap who would not weld for some reason.
Interesting to see what your results are
Thanks in advance
Garry
FollowupID: 446247
Reply By: Truckster (Vic) - Monday, Aug 14, 2006 at 13:43
Why not take the opportunity to go with a custom made one for a bit better cooling, and performance, you can get em for less than the Genurine nissan ones
AnswerID: 188921
Reply By: Leroy - Monday, Aug 14, 2006 at 13:51
BIL had his replaced a while back becasue it was leaking. Gues what the replacement has now started to leak also. I would consider the oportunity to possibly look at a custom made aftermarket job.
Leroy
AnswerID: 188923
Follow Up By: Batman69 - Monday, Aug 14, 2006 at 14:08
Do you guys know of any particular people that custom make that sort of stuff? Preferably in Victoria
FollowupID: 446220
Follow Up By: Leroy - Monday, Aug 14, 2006 at 14:13
do a search for AWILL4X4. I have seen some nice pics of radiators/intercoolers he's built.
Leroy
FollowupID: 446222
Follow Up By: Member - Roachie (SA) - Monday, Aug 14, 2006 at 15:38
Looking through past posts on here, it seems these motors are supposed to run boost of up to 30psi (for short periods of time I gather). I would imagine that those kinds of pressures would be enough to cause an intercooler to develop a small leak with resultant hissing.
However, what would worry me even more would be the amount of oil that blokes are reporting is leaking from such a crack! Okay, so there may be "some" oil/vapour from the PCV set-up, but it shouldn't be enough to show up as an actual oil "leak"; should it? Or, is it possible that this all tied up with the EGR valve (people have reported "gunk" inside the tube when they have removed that valve to either check or to blank it off altogether) and also the MAS? You get those 2 things combining with false readings and the turbo's variable vanes wind themselves up to push more boost into the donk......something's gotta give. It'll either blow an intercooler hose off altogether or blow a crack into the intercooler itself.
FollowupID: 446237
Follow Up By: Truckster (Vic) - Monday, Aug 14, 2006 at 16:36
very much Andrew's (awill4x4) the man here. Hes in Aster Ave Carrum Downs.
FollowupID: 446248
Follow Up By: Member - John - Monday, Aug 14, 2006 at 19:05
awill4x4 made my I/C for 4.2, excellent workmanship, great person to work with, just hates finding a cat stuck in the engine bay as he was fitting it, LOL
John and Jan
FollowupID: 446276
Follow Up By: awill4x4 - Monday, Aug 14, 2006 at 20:10
Yep, that was one hell of a day John. For those that don't know we had been working on the car for half the day before we even noticed the damn cat was stuck in there. I still haven't figured out how a large cat could possibly get into such a small area, it must have been the alternator pulley rubbing on it's tail that gave it the added incentive I guess.
Regards Andrew.
FollowupID: 446292
Follow Up By: Muzzgit (WA) - Monday, Aug 14, 2006 at 22:35
Roachie, luckily the MAS is up near the airfilter, otherwise yes, it would all be a big chit heap!
FollowupID: 446351
Follow Up By: Truckster (Vic) - Monday, Aug 14, 2006 at 22:38
Come on Andy, that pussy would have come from the brothel next door...
FollowupID: 446353
Reply By: Member - Craig D (SA) - Monday, Aug 14, 2006 at 15:22
I had my 3.0L Patrol for about six years and I and my trustworthy mechanics consider this weeping to be quite normal.
AnswerID: 188932
Reply By: On Patrol - Monday, Aug 14, 2006 at 20:07
Hi guys
mine has seeped oil as long as I have had it and as yet my boost is perfect, the oil is easily cleaned away every 20,000 km or so as to prevent any chance of cooler blockage that MIGHT occur in dusty contitions. This is a negligable seepage NOT a leak as such. Yes the boost can peak at 30psi so it would be an exeptional core that could contain everything at that kind of boost.
I might add that my 3.0 has proved to be powerful and reliable so far (150000km). I spoke to a nissan mechanic about failures and his reply was "Off record" "these engines CAN (not all) use oil at 100-120kph and the ones that have failed have seemed to be on units driven at high speed for long periods without checking the oil. Also they mostly (if not all) occur on pre 2002 without the larger sump (2002 on has a 8.5ltr sump as opposed to the earlier 6-6.5 ltr sump)"
The clue to longevity seems to be that people understand they need to check oil everytime they put in fuel or every day when touring. We have forgotten these precautions today due to selfserve stations and cars becoming more reliable over the years.
Never forget you have a machine that needs oil as much as we need blood.
I love my 3.0ltr Turbo, more importantly I respect my 3.0ltr Turbo.
On Patrol.
AnswerID: 189005
Follow Up By: 3.0turbob - Tuesday, Aug 15, 2006 at 09:41
Interesting, Iwas told a similar thing by Nissan in western Sydney. Very reliant on oil level. He said the few that have failed they have found the oil level to be too low. Many towing caravans around the country.
Rob
FollowupID: 446421
Reply By: brian - Tuesday, Aug 15, 2006 at 08:17
My three litre had the same oil weep and the dealer replaced the intercooler under warrenty,the new one has the same oil weep but no apparent negative effects other than a distinctive audible whine particularly when cold.
AnswerID: 189069
