fullriver batts
Submitted: Monday, Aug 14, 2006 at 18:11
ThreadID: 36769 Views:5655 Replies:6 FollowUps:3
Can anyone tell me who sells fullriver batteries in Perth WA
Jason
Reply By: ozdragon - Monday, Aug 14, 2006 at 18:20
Hi Jason
I dont think anyone does. Ive rung every battery supplier in Perth and most give the answer full who.
Im thinking of getting mine from Fridge and Solar in Qld.
AnswerID: 188967
Reply By: pilbaradisco - Monday, Aug 14, 2006 at 18:44
W.A. Solar in Perth are the agents and can probably get them in for you. I was talked out of the Fullriver and bought the better quality Lifeline Sun X-tender that BP solar promote. Much better cycle life.
Glen.
AnswerID: 188976
Reply By: Derek from Affordable Batteries & Radiators - Monday, Aug 14, 2006 at 22:34
Batteries Plus in Perth has AGM's at very good prices.
Their price works out the same as mine when you add freight.
Here is the link. Batteries Plus
Regards Derek.
AnswerID: 189035
Reply By: Lorne - Tuesday, Aug 15, 2006 at 05:51
My father just bought a HAZE agm which is suspose to be able to have 100% discharge. They are rated for high temp under bonnet use, $300 which was cheaper than the fullriver 120Ah they might be worth a look at. Their web is at www.haze.com and go to the USA flag that site is quicker for info.
Lorne
AnswerID: 189058
Follow Up By: Member - Norm C (QLD) - Tuesday, Aug 15, 2006 at 08:27
If $300 is cheaper than the Fullriver 120AH; you were quoted a VERY high price for that battery. As far as I know they are readily available at $300 and below. Fridge and Solar's list price (before any bargaining) was recently $300 and they are not really a discounter.
FollowupID: 446396
Follow Up By: Member - Mike DID - Tuesday, Aug 15, 2006 at 09:24
www.haze.com links to dating and music downloads etc - I'd be concerned about picking up a Trojan virus from the popups on it.
FollowupID: 446414
Follow Up By: Member - Mike DID - Tuesday, Aug 15, 2006 at 09:32
Here is the link to an N70 size AGM battery
http://www.hazebattery.com/usa/DataSheets/UPS/UPS310.pdf
FollowupID: 446418
Reply By: TerraFirma - Tuesday, Aug 15, 2006 at 09:14
I paid $235.00 Inc GST for a Fullriver 120AH HGL-120B from geetek in newtown , Geelong, they even shipped it to Melbourne for free. (Otherwise it's $60) By the way this model battery also has around 750cca in case of emergency. No need to spend the extra on the Lifeline , there is no proof yet that these batteries warrant the extra money imho.
If you look after a Fullriver or Remco etc with a 3 stage charger you should be getting close on 8-10 years.
AnswerID: 189087
Reply By: sastra - Tuesday, Aug 15, 2006 at 12:09
Hi Jason,
Go to Challenge Batteries WA at 1 Burgay Court, Osborne Park, 6017. Ph 08 9446 6122. I dealt with Chris who was very clued up re 240V charging and also solar. I bought 2 DC100 Fullriver AGMs at about $240 each.
Good luck,drive safe
AnswerID: 189109
