Mike Harding, your help please.
Submitted: Tuesday, Aug 15, 2006 at 16:33
ThreadID: 36796 Views:2727 Replies:3 FollowUps:11
Mike,
Can you have a look at post 36765 regarding the current load/draw/amp acceptance of an AGM battery.
Thanks,
Jim.
Reply By: Derek from Affordable Batteries & Radiators - Tuesday, Aug 15, 2006 at 20:50
Hi Jim
You are right.
The battery will accept what is available and charge at the rate you give it. A starter motor or inverter will draw current and blow fuses if not rated to the current needed.
You must just keep in mind that a battery needs X amount of amps to charge it up fully. Rule of thumb is 10% minimum of the battery capacity. Many people use charger rated too low and the batteries fail.
Regards Derek.
AnswerID: 189192
Follow Up By: Jimbo - Tuesday, Aug 15, 2006 at 21:09
So Derek,
If one was to hook up a well discharged, 80 or 100 amp AGM Battery to a cig socket, would it blow a fuse or not?
Sorry to have to put it into basic terms.
Jim.
PS. Sorry I gave you a serve a few weeks back, sometimes late at night after a bad week at work, and a few glasses too many, we say things we shouldn't. No excuse really. I wish this forum had an edit function at times. Tact is not my strong suit.
FollowupID: 446621
Follow Up By: Derek from Affordable Batteries & Radiators - Tuesday, Aug 15, 2006 at 21:18
Up to 15 amps is OK. Less could blow the fuse.
FollowupID: 446624
Follow Up By: Mad Dog - Vic - Tuesday, Aug 15, 2006 at 21:26
Get that did ya Jim :)
FollowupID: 446625
Follow Up By: Jimbo - Tuesday, Aug 15, 2006 at 21:31
Am I missing something Ray?
FollowupID: 446628
Follow Up By: Derek from Affordable Batteries & Radiators - Tuesday, Aug 15, 2006 at 21:52
Do you need some more info.
I have seen 10 amp chargers over heat and trip the heat protection on a flat 100 a/h battery but the 15 amp chargers don't.
You need to wire up as required. Lighter sockets were never designed to charge batteries, especially one bigger than the cars starting battery.
FollowupID: 446636
Follow Up By: Member - JohnR (Vic)&Moses - Tuesday, Aug 15, 2006 at 21:58
Is Ray saying it takes less than that to blow your fuse Jimbo?
FollowupID: 446637
Follow Up By: Mad Dog - Vic - Tuesday, Aug 15, 2006 at 22:49
I dunno Jim, I think Derek is saying a 15 amp fuse or larger would not blow before the wiring released smoke. The cig sockets are generally 10 amps I think, not wise to increase the fuse value.
The fuse will blow unless there's enough resistance in the wiring to limit current to a safe value.
FollowupID: 446661
Follow Up By: Derek from Affordable Batteries & Radiators - Tuesday, Aug 15, 2006 at 23:00
No, I think Derek is saying you guys must listen.
Lighter sockets are not designed for charging batteries.
FollowupID: 446669
Follow Up By: Mad Dog - Vic - Tuesday, Aug 15, 2006 at 23:11
They were designed to heat an element that lights ya cig but as long as it's used within spec the purpose doesn't matter.
FollowupID: 446675
Follow Up By: Derek from Affordable Batteries & Radiators - Tuesday, Aug 15, 2006 at 23:14
Quite right, 10 seconds load.
FollowupID: 446679
Follow Up By: Member - Garth J (NSW) - Wednesday, Aug 16, 2006 at 21:41
Guys,
I feel some clarification is needed.
A fuse is designed for short circuit protection. ie if you short the power supply to earth the current flow will be infinite(theoretically) because you have no resistance.
Thats why it's called a short circuit. The fuse will blow instantaneuosly.
When a circuit is designed you calculate what the maximum demand will be.
The maximum demand is how much current you can expect to draw.
The current is calculated by using the equation for power(p) in watts = voltage(E) in volts * current (I) in amps.
Once you know how much current you will draw by virtue of what you plug in and its power rating you say my maximum demand is x amps.
Therefore I need a cable from the power supply to the outlet that will carry x amps.
The outlet itself must also have a rating of x amps or more.
Now we need to protect the cable with a fuse that is rated at x amps or lower.
Once the current flow is x amps plus the fuse will blow and not damage the supply cable.
It is possible to carry more than the x amps for a period of time and then what may happen is that heat developes and over time the cable insulation deteriotes and maybe melts and cracks and then a short circuit developes and wulla the fuse blows.
In domestic situations when cables are in conduit or buried or not in free air the current carrying capacity needs to be derated as per the wiring rules.
This is based on a cable of a particular cross sectional area and a particular insulation type having a rated current carrying capacity.
In all cases the fuse is designed to protect the length of cable it is installed in.
It does this by melting or blowing before the wire of the cable does and thus stops the current flow.
Hope I've cleared the air and not fogged it!!!!
Garth
FollowupID: 446883
Reply By: Member - Mike DID - Thursday, Aug 17, 2006 at 10:45
No doubt you've noticed that when you first plug in a Cigarette Lighter it's hard to pull out - that's because there's a spring in the socket that clamps the Lighter (until it heats up and pops).
Now when you plug in most accessory plugs, there's no click as the springs latch - so the plug falls out easily, but worse - there's no pressure to hold in the centre contact in place. No wonder high-current appliances overheat - contact between two metals is only low-resistance if there's pressure holding them together.
To make things worse, some "Accessory " sockets don't even have the retaining springs you see inside proper Cigarette Lighter Sockets.
AnswerID: 189453
Reply By: MartyB - Thursday, Aug 17, 2006 at 17:52
Jimbo,
No-one seems to have answered your question, so yes if you connect a well discharged 100ah battery to your cig lighter yes the fuse will blow.
Marty
AnswerID: 189536
