Convert map feature to waypoint in Oziexplorer
Submitted: Thursday, Aug 17, 2006 at 13:54
tdv
Hi all
One for the technos out there. When i first played with ozi a long time ago I created a whole set of map features instead of waypoints (dumb i know now!). Anyway is there any easy way to convert these to waypoints? I have tried right click -> properties -> create a waypoint but nothing seems to happen. If I save waypoint file it creates one but they don't show when loaded....
Might be a case of manually creating a couple of hundred waypoints!!!
Any help appreciated.
Tez
Reply By: Frank_Troopy - Thursday, Aug 17, 2006 at 14:22
Hi Tez,
It says in HELP that the waypoints created from Features can't be seen in waypoint lists and so
forth, however they can be loaded to a GPS. It's a bit of a fudge, but you could tick the boxes and then send them to a GPS and then load them back from the GPS to get them as normal waypoints.
Cheers Frank.
189492
Follow Up By: Troop-a-dour - Thursday, Aug 17, 2006 at 14:26
Hey..now that's thinking outside the square..
I'll be interested to see if Tez sorts it out!!
446990
Follow Up By: tdv - Thursday, Aug 17, 2006 at 15:06
In the process of searching for the cable now! Thanks for that!
446998
