Hilux SR5 Cold Start Button
Submitted: Friday, Aug 18, 2006 at 10:29
ThreadID: 36883 Views:5350 Replies:5 FollowUps:2
Could anyone tell me if the Cold Start Button on the SR5 Hilux turns off automatically. Mine stays on for the entire trip unless I remember to turn it off myself.
Reply By: TerraFirma - Friday, Aug 18, 2006 at 10:35
Cold Start button..?? Where are they..? I haven't seen one in mine..
AnswerID: 189632
Reply By: wato35 - Friday, Aug 18, 2006 at 11:16
The cold start button is down near the elect mirror switch.
SR5 Hilux 2006.
AnswerID: 189644
Follow Up By: D-Jack - Friday, Aug 18, 2006 at 11:51
Diesel I take it?
FollowupID: 447116
Reply By: Brett_B - Friday, Aug 18, 2006 at 13:12
If you keep the heat button in the on position the engine will run fast when cold, once warm it will come back to normal RPM.
If you start it warm, the RPM should be normal even if button is on.
It should only run fast when cold, the sensors work it out.
Well this is what mine does anyway :-)
Maybe we should read the user manual :-)
AnswerID: 189655
Follow Up By: TerraFirma - Friday, Aug 18, 2006 at 13:46
RTM (Read the bleep in Manual). No haven't done that yet.
FollowupID: 447130
Reply By: TerraFirma - Friday, Aug 18, 2006 at 13:45
Ahh yes the Powerheater Switch..! Thanks..
AnswerID: 189658
Reply By: Peter 2 - Friday, Aug 18, 2006 at 18:55
Might be worthwhile reading the manual although it may not give any technical info other than "increases engine revs at idle until engine is warmed to X temp".
On the 6.2 in the humvee it automatically advances the timing a few degrees when the engine is cold to aid cold starting, the timing returns to normal as soon as the temp gauge starts to move.
Quite obvious when it is on as the engine has a deeper 'diesel knock' and pulls better low down.
AnswerID: 189693
