Endless Air in TD6 GU
Submitted: Sunday, Aug 20, 2006 at 20:51
ThreadID: 36937 Views:1911 Replies:4 FollowUps:13
anyone fitted one? I got one for a GQ here :D and wanna know how hard it will be to fit..
Reply By: Member - John - Sunday, Aug 20, 2006 at 21:38
Truckster, I have one fitted, if you would like a look at the brackets give me a bell. I am in Cranbourne, 59955982
John and Jan
AnswerID: 189966
Follow Up By: Truckster (Vic) - Monday, Aug 21, 2006 at 11:20
beers at my place one night, im only in Langy
FollowupID: 447638
Follow Up By: junior - Tuesday, Aug 22, 2006 at 01:15
Hey John,
I've got one fitted too, but haven't fit my tank yet- I am concerned by the amount of grease this thing spits out!- do you run a tank and filter on the outlet of that tank- if so, does the tank seem to collect most of the grease- do you have any similar problems/concerns?
FollowupID: 447820
Follow Up By: Member - John - Tuesday, Aug 22, 2006 at 19:55
Junior, I have a modified A/C drier, filled with S/S wool, small orifice in the bottom, takes the oil I use out of the air stream. This is fitted on the discharge side and the oil that is removed is returned to the suction side. I also have the suction side plumbed into the PCV hose, supplies a little bit of extra oil, no need for grease. Hope this makes sense. John
John and Jan
FollowupID: 447997
Reply By: ADM - Monday, Aug 21, 2006 at 09:10
I fitted the Sandon 508 to a 03 cab chassis using the E/A brackets.
The main problem with the TD6 is the cross member near the radiator. This has to modified with a hammer a little heat to clear the pulley. The vacuum line that runs under the sump to the injector pump also needs to be replaced to re route it.
I have basic instructions and a contact number to someone who regularly fits them if that helps.
AnswerID: 189991
Follow Up By: Truckster (Vic) - Monday, Aug 21, 2006 at 21:38
Got any photos of your setup?
FollowupID: 447780
Follow Up By: ADM - Tuesday, Aug 22, 2006 at 08:04
Will take some tonight and post up tomorrow.
Have you got the brackets for I can supply some at a cheap price.
FollowupID: 447837
Follow Up By: Truckster (Vic) - Tuesday, Aug 22, 2006 at 09:00
Yup got the brackets and all..
FollowupID: 447850
Follow Up By: Aussieducker - Sunday, Aug 27, 2006 at 20:47
With regards to brakets, can you supply for a GQ??
FollowupID: 449078
Reply By: GUPatrol - Monday, Aug 21, 2006 at 10:15
Would anyone with this setup be able to post a photo?
AnswerID: 190004
Follow Up By: Truckster (Vic) - Monday, Aug 21, 2006 at 11:17
once mines fitted, I'll up some photos.
FollowupID: 447637
Follow Up By: Member - Roachie (SA) - Sunday, Aug 27, 2006 at 21:15
didya get it fitted yet?
FollowupID: 449089
Reply By: Member - John - Monday, Aug 21, 2006 at 12:22
Truckster, in Sydney tonight, back in Melbourne tomorrow night and then away for a week from Wednesday. If you want to have a look Tuesday, give me a bell 0400197550, John
John and Jan
AnswerID: 190020
Follow Up By: Truckster (Vic) - Monday, Aug 21, 2006 at 12:41
ok, will work something out.
0400425296
FollowupID: 447657
Follow Up By: Truckster (Vic) - Monday, Aug 21, 2006 at 21:02
have to wait till next week, shti happening tomorrow night :(
FollowupID: 447768
Follow Up By: Member - Miles P (VIC) - Wednesday, Aug 23, 2006 at 23:48
Hi, would like to fit one to my td6 as well, love to have a gander, I'm in franga 0421022266
FollowupID: 448290
Follow Up By: Truckster (Vic) - Thursday, Sep 07, 2006 at 11:02
how did your photos turn out? Mine were poo :'(
Thanks for your time that evening John, Im calling MTQ :)
FollowupID: 451152
