timing belts
Submitted: Monday, Aug 21, 2006 at 10:48
wazab
Has any one had to replace a timing belt before 100 thousand kms.recomended in the service book. my ford dealer said they often go between 90-100 thou and because im at 92,000 it should be done now to be safe, ive never come across any one its happened to.
Reply By: Kiwi Kia - Monday, Aug 21, 2006 at 11:16
What vehicle do you have? Does it still have any warranty period left eg. 5 yrs etc.? If there is any likelyhood of a warrenty being compromised then get the belt changed by the recomended time.
Some engine models just coast to a stop if the belt breaks, others can make a VERY expensive noise before they stop - replacement pistons, valves, head etc.
If you treat your engine nicely and are not in the habit of over reving I don't think you need to do any maintenance before the recomended km's. Many people run out to 120,000 + km's with no problems at all. Make sure that when you do change the belt you also change any tensioning device and idlers at the same time. Most vehicle manufacturers and after market suppliers include the idlers and belt tensioner with a timing belt kit.
190011
Follow Up By: Member - Boo Boo (NSW) - Monday, Aug 21, 2006 at 17:39
I've got a triton 2001 tray top single cab. Timing belt let go at 94000km. I treat my vehicles nicely, hoping they will do the same to me. This bugger didn't.
Anyway the motor was replaced with a new long motor under warranty no questions asked. All I had to do was show the service book, even though it was serviced by a non Mitsubishi dealer.
When I bought my Troopy 18 months ago it had 78000 on the clock. Being a bit paranoid I had the belt changed at 90000km.
Regards Bob
447720
Reply By: Member - andrew B (Kununurra) - Monday, Aug 21, 2006 at 11:16
I'm not sure on the fords, but the Nissan 2.8 isn't very expensive, so I did
mine a little early as I was in the process of removint the radiator for a re - core, and replacing all of the belts and hoses on the front of the motor. Cheap insurance doing it early (on a diesel at least), very pricey if one fails.
Cheers Andrew
PS if the Book says to do it at 100,000; and it fails berforehand, wouldn't the motor company have to cover it under warrenty, as its service recommendations have been followed and their component didn't meet the requirement of the part?
190012
Reply By: longJohn - Monday, Aug 21, 2006 at 12:47
I just took the whole front of my engine apart (75 series landcruiser troopie 1995 model) just to get to the oil seal at the front of the block. Had to remove everything, and did the timing belt while i was at it. Thing I noticed was that when the engine is at rest the timing belt is loose, when its turning, the belt is tight. Something to do with the way the tensioner works. I checked the spring and it seemed right, even went back to it and took it out and checked it again. seemed ok. wierd.
Anyone else has any experience with this can say if thats right or not? I also double checked with the book how you install it.
190027
Follow Up By: kesh - Monday, Aug 21, 2006 at 17:03
long John. Am just about to install a new one on
mine ('97 -75series, 205k.) so when I read your post I started the job for a look see. I last replaced it at 102k. and by appearances it would do another 100k., but it will be done tomorrow. The important bit though is that running or stopped its as tight as a drum, no slack whatsoever. The timing marks are very nicely aligned too. Its easy to turn the motor slowly with a socket on the alternator pulley stud.
kesh
447713
Reply By: 120scruiser (NSW) - Monday, Aug 21, 2006 at 20:49
Astra's and Vectras need to be replaced at 60 000 km.
Mitsubishi express vans are set to be replaced at 100 000 km but I strongly advise you replace them at 90 000 km.
Mitsubishi Lancer, and Hyundai's are set for 90 000 km but would advise to do earlier.
Toyota's are set for 150 000 km and seem to last to then.
190118
Reply By: Sarg - Monday, Aug 21, 2006 at 20:52
The HZJ motor would have to be one of the easiest of all to change the belt on. Don't know why anyone that owns one of these hesitates to do it at the recommended intervalls or even before.
190119
Reply By: Andrew-rodeo - Monday, Aug 21, 2006 at 21:03
It all depends on how you use the vehicle. I have heard of many toyotas with a belt change due at 150,000 break belts
well before 100,000. Unfortunatly nobody told the farmers that purchased these cars that when your car is sitting in the paddock idling away happily things are still wearing out even though the odometer isn't moving.
So if yourvehicle sits for long periods idling i would certainlt get your belt changed before it id dure to be on the safe side.
Cheers Andrew
190124
Reply By: wazab - Monday, Aug 21, 2006 at 21:25
thanks to all who replyed, its booked in wednesday to be replaced its not very expensive for peace of mind. cheers every one
190129
