Pajero V8 Conversion
Submitted: Monday, Aug 21, 2006 at 17:57
ThreadID: 36965 Views:24958 Replies:5 FollowUps:4
Has anyone put a V8 in an NG Pajero? (Gen 1). If so, can you please provide details of what you have done? Both in terms of parts needed and the process you went through.
Second, have you also done a dual battery setup in one? Can you provide details of where you put the second battery?
Reply By: TerraFirma - Monday, Aug 21, 2006 at 18:00
May I ask why you would want to put a V8 in a Pajero..?? If you want a 4WD with a V8 I would recommend buying one already converted. I don't believe the Pajero running gear would be compatible with a V8 conversion albeit possible.
AnswerID: 190084
Follow Up By: Kylie in the exy - Monday, Aug 21, 2006 at 18:14
The running gear is ok to take the load, its got 9" diffs from the factory. Crownwheel & pinion are ok in that regard as well.
Rest of the axles etc may need some hardening, but nothing of too much concern.
Have seen at least 2 of them with this conversion done. Guys in the USA have converted this model successfully running 4.3 litre or 5.4 litre engines. They also at times convert the transmission to a borg warner gearbox rather than the mitsu one.
FollowupID: 447732
Follow Up By: Exploder - Monday, Aug 21, 2006 at 18:35
Best bet would be Get on a U.S forum and try and find somebody with the conversion and get the details of what is involved, better yet next time you see one around have a chat to the owner.
Sometimes it will be cheaper to ship some item’s over from the U.S than buy them hear in Aus.
Cheers.
FollowupID: 447735
Follow Up By: AS/KS - Monday, Aug 21, 2006 at 18:41
Conversions never go as planned, cost a fortune, hurts resale value of your car
makes it pain work on/ service.............. And the list goes on.
What ever flicks your switch, i suppose........
FollowupID: 447736
Reply By: Member - andrew B (Kununurra) - Monday, Aug 21, 2006 at 18:15
A friend a while back put a mildly worked 253 in a SWB Pajero. An amazing car, but very expensive. I think the Diffs survived but everything else was trashed. From memory, toyota gearbox and transfer, and custom tailshafts etc. Cost him a small fortune, got very little in resale, and had a lot of fun. There was an auto parts shop and cylinder head place in Pambula, Southern NSW owned by Mick and Kezzie Nolan who did most of the work on the truck. They may be worth a call (I haven't been there for 7 years so they may not still be there), they should talk you out of it, but will most probably talk you into a bigger engine. In their spare time they got into doing tractor pulls, making all of there own gear. They had one with 2 350 chev's, and even had a 350 chev in the fergie tractor for slashing their block.
Cheers Andrew
AnswerID: 190086
Reply By: GaryInOz (Vic) - Monday, Aug 21, 2006 at 18:22
There is a Holden V6 conversion using an Ecotec 3.8.
You can also get a 4.2 litre botom end if you want from C.O.M.E. Racing in South Caulfield, Victoria.
I wouldn't think you would need to go much further than that. V8 will be too much weight over the front
AnswerID: 190088
Reply By: Member - Mike DID - Monday, Aug 21, 2006 at 21:48
For the V6 NG the second battery would fit just behind the left headlight.
I still have the battery tray for sale - I'm in Sydney.
AnswerID: 190142
Follow Up By: Pajman Pete (SA) - Tuesday, Aug 22, 2006 at 07:47
I asked the same question about a second battery in a V6 NG and was told you can make enough room on the LHS by moving the carbon canister to the driver's side.
Pete
FollowupID: 447835
Reply By: Member - Oldplodder (QLD) - Tuesday, Aug 22, 2006 at 08:02
If you just want horse power, why not supercharge or turbo a 3.5l V6?
One running around SE Qld with at least 200 kw, and at a guess more like 250kw.
I think they rolled it last year on a bitumen rally :-(.
If you want low down torque, why not drop in a 3.2DiD diesel, suitably modded?Friend does rechipping and massive torque is possible from this engine.
170/180kw is available from a 3.5l V6 with only a rechip and a new exhaust.
Only suggestions, seen so many different conversions in different vehicles, the detail always catches you out with something very different.
AnswerID: 190183
