Service due light
Submitted: Wednesday, Aug 23, 2006 at 00:06
Dave ....Adelaide
Hello all , just wondring if anyone knows how to turn off the service due light on a 2003 VY Commodre ...my son has just bought one , and prefers to do his own
services.......Cheers ...Dave
Reply By: Member - Doug T (W.A) - Wednesday, Aug 23, 2006 at 00:36
SNIPS
Can't really help but maybe ask an Auto Electrician and more than likely it will be controlled by computer
Doug
190444
Follow Up By: sudsy - Wednesday, Aug 23, 2006 at 00:43
It can be cancelled by anyone with a Tech 2 analyser. Just plugs in to the On Board Diagnostics (OBD) connector, usually located under the dash.
I suspect there are other ways though.
448076
Reply By: Des Lexic - Wednesday, Aug 23, 2006 at 09:16
When you turn the ignition switch on, the dash flashes a message service engine check. I think if you go into mode, you can switch off the service light there.
190479
Reply By: Member No 1- Wednesday, Aug 23, 2006 at 11:21
black PVC tape
190505
Follow Up By: Member - Andrew (QLD) - Wednesday, Aug 23, 2006 at 12:32
great idea, wise one ;-)
448151
Follow Up By: Brian B (QLD) - Wednesday, Aug 23, 2006 at 15:02
Numero Uno,
That is possibly your most high tech solution to date.
As Andrew has said - wise one
448175
Follow Up By: Member No 1- Wednesday, Aug 23, 2006 at 18:07
look what rubbish Leroy and Phantom (their reply below) tell him do...for goodness sake who reads manuals, and the method is too darn hard anyhow!
448218
Reply By: Leroy - Wednesday, Aug 23, 2006 at 12:13
look in the manual. there is a proceedure for the VT to stop the 'service 120,000km' flashing.
Leroy
190511
Reply By: Member - Phantom (WA) - Wednesday, Aug 23, 2006 at 13:10
Hi Dave,
This is my first response as a new Member.
You hold down the two arrow buttons on the mode switch and turn the ignition on whislt holding them down. It will chime after a couple of seconds. After the chime hold down the set button and it will chime again. Service light off.
Hope it works for you!
190517
Follow Up By: Dave ....Adelaide - Sunday, Aug 27, 2006 at 23:22
Hi Phantom
Just thought id let you know ,tried what you said and worked a treat ...thanks mate ............Cheers .....Dave
449123
Reply By: Dave ....Adelaide - Wednesday, Aug 23, 2006 at 22:33
Thanks for the responses everyone, Oh and you to member No 1....he's going to give it a go tomorrow...oh and btw there's nothing in the manual about it .....Cheers ....Dave
190643
Follow Up By: DMH122 - Sunday, Aug 27, 2006 at 09:44
Yes there is
448942
Follow Up By: Dave ....Adelaide - Sunday, Aug 27, 2006 at 23:23
Hi DMH122
Yur a bit slow with the rsponse mate ....but yeah yur right did actually find it in there later ........Cheers ......Dave
449124
