Land Cruiser live axle
Submitted: Wednesday, Aug 23, 2006 at 14:22
Twinkles
What is the most recent Land Cruiser that still had a live axle instead of IFS? Have any of the 100 series models had one?
Reply By: Michael ( Moss Vale NSW) - Wednesday, Aug 23, 2006 at 14:36
I think you can still get one in the hose out model.... But being a Patrol guy, i dont really know for sure. Michael
190524
Follow Up By: Member - Andrew W (SA) - Wednesday, Aug 23, 2006 at 14:50
Standard and normally aspirated diesel GXL both come as Live Axle.
448173
Reply By: Frank_Troopy - Wednesday, Aug 23, 2006 at 14:37
Live front end LC
190525
Follow Up By: Member - Andrew W (SA) - Wednesday, Aug 23, 2006 at 14:49
or Site Link
448172
Reply By: Member - bushfix - Wednesday, Aug 23, 2006 at 14:41
105 series standard as far as i know (HZJ105)
190526
Reply By: Twinkles - Wednesday, Aug 23, 2006 at 14:53
Thanks. Expensive, aren't they?
190528
Reply By: Twinkles - Wednesday, Aug 23, 2006 at 14:55
Have there been any models with turbo diesel and live axle in 100 series? Better still turbo and intercooled with live axle front end.
190529
Follow Up By: GaryInOz (Vic) - Wednesday, Aug 23, 2006 at 15:04
4.2 litre turbo intercooled live axle
448176
Follow Up By: Twinkles - Wednesday, Aug 23, 2006 at 15:13
I know the Nissan has. I was interested in the turbo Toyota 'cos it may get better fuel consumption.
448177
Follow Up By: Truckster (Vic) - Wednesday, Aug 23, 2006 at 15:17
lol.. here we go again.
448178
Follow Up By: GaryInOz (Vic) - Wednesday, Aug 23, 2006 at 15:21
"...I was interested in the turbo Toyota 'cos it may get better fuel consumption...."
I can guarantee the Toyota will get good fuel consumption, about the same as a Corolla in fact...(being the loan car that you will learn to love while the LC is in for more broken parts to be repaired)
448181
Follow Up By: Truckster (Vic) - Wednesday, Aug 23, 2006 at 15:23
you wouldnt be implying that 100 series front diffs are soft would you Gary? lmao
448182
Follow Up By: GaryInOz (Vic) - Wednesday, Aug 23, 2006 at 15:25
About as soft as Kia front diffs..............
448183
Follow Up By: joc45 - Wednesday, Aug 23, 2006 at 15:43
Re consumption, I did a trip
Perth to the
Pilbara about 3 years ago with my Patrol 4.2TD-T travelling in convoy with a 4.2 turbo Toyota LC GXL and a Rodeo petrol.
Both wagons were equally loaded, similar roof racks, neither towing. The LC consistently got about 2mpg better consumption than my Patrol at 110km/h.
Can't say what the Rodeo got, but we had to stop frequently to refill it.
Gerry.
448188
Follow Up By: Twinkles - Wednesday, Aug 23, 2006 at 17:56
What have I started!
I like Patrols, but the Toyota's engine is a bit more modern and should be more efficient.
2mpg, should that be kpg? Still significant.
thanks everyone for the info.
448216
Follow Up By: GaryInOz (Vic) - Wednesday, Aug 23, 2006 at 18:22
Twinkles,
The fuel is only a small part of the TCO (Total Cost of Ownership) equation. What you need to do is factor in all the things you can see that you may be needing, whather it be regular maintanance, through to an educated guess at parts that have a known "use by" date such as the front diffs on your beloved LC's, and prices of panels, insurance. The other thing to look at is the overall reliability of what you will purchase, would you really want to be stuck in Woop-Woop West with a dead diff? Needing a tow some hundreds of km to the nearest service center? Too many remote actuators on the LC's to go FUBAR.
GQ/GU Patrol have issues too, but they are
well known and relatively easy to get around (extra cooling of the radiator, etc), and not necessarily going to stop you outright. Notable exception being the 3l TD engine...
448221
Follow Up By: Member - Stephen M (NSW) - Wednesday, Aug 23, 2006 at 18:54
Ah Gaz, now you did have to mention that 3l TD didnt you, look out !!! LOL Regards Steve M
448226
Follow Up By: djm67 - Wednesday, Aug 23, 2006 at 19:52
A work Nissan ute(4.2 TD) has just done the turbo for the 2nd time, blew at 17000 km and now it has gone again at 105000 km.
Vehicle is serviced by Nissan every 5000 km as is required by Nissan because the vehicle is used off road (every 10000 km if you promise not to use it off the bitumen).
Regardless of anything else, the need to do extra
services to an off road vehicle if you use it off road and the shocking turbo record has put me off considering a Nissan.
448228
Follow Up By: joc45 - Thursday, Aug 24, 2006 at 12:07
My GU 4.2 has been thru two turbos, but both merely leaked oil, not blow-ups. Both replaced under warranty, the first at about 90,000, the other about 8 weeks later. Regularly and meticulously serviced, if you can call Nissan servicing "meticulous".
Must admit, after two turbos and a gearbox, and disappointment with servicing, I'd have to reconsider what my next vehicle would be. I'm concerned about Toyota's record as
well, tho.
448355
Follow Up By: Member - Davoe (Nullagine) - Thursday, Aug 24, 2006 at 12:14
to answer the question. no 100 series TD came out with live axles. The last td from Toyota to come out with live axles was the 80 series but with no intercooler. That applies only to station wagons. Both the current tojo ute and troopy come out with live axle and turbo but no intercooler
448359
Reply By: Trevor R (QLD) - Wednesday, Aug 23, 2006 at 19:56
Twinkles,
Short answer to your questions are, Yes there is still current live axle diesel cruisers around but all have the N/A 4.2 donk. No Turbo or I/C Turbo versions of the 100 series have been produced with live axle to my knowledge.
The 80 series did however come out with a turbo/live axle combo if that is of any interest to you.
Hope this helps,
Trevor.
190583
Follow Up By: Twinkles - Wednesday, Aug 23, 2006 at 20:10
Thanks Trevor. What was the last year they were produced?
448231
Follow Up By: Member - Nick (Kununurra) - Wednesday, Aug 23, 2006 at 20:47
100 series came out in 1998 so I guess the last 80 series T/D was 1997!!Ment to be a great buy,stronger diffs and gearboxes.
These combo's are what people are putting in their HZJ105's.
448240
Follow Up By: Trevor R (QLD) - Wednesday, Aug 23, 2006 at 20:52
You're right Nick. March 98 the 100 series was released (I think) and the turbo 80's with live axle were sold up to this date AFAIK.
I agree with what others say concerning gearbox strength in the 100 series N/A I have first hand experience with this sadly.
Cheers, Trevor.
448245
Follow Up By: Member - Andrew W (SA) - Wednesday, Aug 23, 2006 at 22:34
Me thinketh the gearbox in the 80 series TD is the same as the HZJ105
448282
Follow Up By: V8Diesel - Thursday, Aug 24, 2006 at 07:48
No. HZJ105 (N/A diesel) has the smaller R151 Prado gearbox. The FZJ105 (petrol) model has the big H151 box that the 80 series and turbo diesels had. I think the front diff is a slightly different setup in the HZJ105 standard compared to everything else.
Why Toyota would make the drivetrain weaker on the diesel 105's is beyond me.
Brunswick Diesels will fit up a 6.5 Chev V8 direct to a live axle 80 or 105 series petrol because the gearbox, clutch and radiator will handle it fine. They require a lot more mods to convert the diesel model funnily enough.
448306
Reply By: Peter 2 - Wednesday, Aug 23, 2006 at 20:28
The big downside to live axle 100 series is that they come with the 'light duty' 5 speed transmission which regularly fails behind a naturally aspirated 1HZ, so if you were to turbo it it would probably shorten the trans life even more.
The same transmission is used in the Prado.
There have been previous posts that have discussed the transmission with the actual model numbers.
190594
Follow Up By: Member - Nick (Kununurra) - Wednesday, Aug 23, 2006 at 21:08
Have heard of lots of failures but never spoken to more than a couple of people that have actually had them fail and most of them had a second failure shortly after.So were they dodgy repairs for the second rebuild or abused in the first place.
Also I wonder what the percentage of failures would be over all(there are lots of them out there).
If ours fail's Im planning on fitting a late model 80 seriesT/D after I fully rebuild it.
448253
Reply By: Member - Phil G (SA) - Wednesday, Aug 23, 2006 at 20:39
If you want a magic combination:
- Brand new vehicle
- Rigid front end
- Part Time 4wd
- Factory diff lock option
- Factory Turbo-diesel 1HD-FTE motor
- Strong H150F gearbox
- And looks, feels, smells like a real truck, inside and out
Get a current model Troopie or traytop - HDJ78 and 79series,
190602
Follow Up By: ross - Wednesday, Aug 23, 2006 at 20:59
Beat me to it .
448247
Follow Up By: Twinkles - Wednesday, Aug 23, 2006 at 21:37
Needs coils on all four corners.
448260
Follow Up By: Geoff (Newcastle, NSW) - Wednesday, Aug 23, 2006 at 22:07
Yep, Phil's got it in one.
I wanted a Landcruiser wagon with live front axle and factory turbo diesel.
The only model in the whole range with this combination is the RV specification 5 seater Troop Carrier, the HDJ78.
The bonus is you get a Troopy and the H150F gearbox.
Geoff.
| Geoff,
448269
Follow Up By: Member - Phil G (SA) - Wednesday, Aug 23, 2006 at 22:14
" Needs coils on all four corners."
Twinkles,
Go drive one. They have coil front springs, a long wheelbase and very very long rear leaf springs. The extra length makes a lot of difference. And the leaf springs handle more weight than the coils. It was a major improvement with the 78series in 1999.
448273
Follow Up By: Twinkles - Wednesday, Aug 23, 2006 at 22:18
What's the ride on the cab chasis like?
448276
Follow Up By: Geoff (Newcastle, NSW) - Wednesday, Aug 23, 2006 at 22:58
"What's the ride on the cab chasis like?"
Magic Carpet!!
The 78 and 79 Series Phil describes are streets ahead of the older all leaf Landcruisers.
I've owned a heap, an FJ40 (SWB), a HJ45 (Tabletop), a HJ47 (Troopy), HZJ105 (Base Wagon) and the pick of the crop, HDJ78 Troopy.
The HDJ78 wins on all fronts, ride, power, economy, useability, versatility and any other measure you can think of.
But hey, I'm biased Troopy's are the go for offroad touring.
Geoff.
| Geoff,
448284
Follow Up By: Member - Big Al. Gold Coast - Thursday, Aug 24, 2006 at 18:58
Magic and also scary when that turbo kicks in . Never had a turbo before.
Our new 79 has just arrived and was supprised at power and comfort of new ute
even unladen.
Now for the fitout.
Big al
448484
Reply By: 120scruiser (NSW) - Wednesday, Aug 23, 2006 at 21:55
Twinkles the last TD live axle was the 98 80 series.
The 100 came out in naturally aspirated diesel from 98 to 00.
In 00 the TD 100 was released but came with an independant front end and is still to this date.
The petrol 1FZFE 4.5 petrol is live axle in the 100 from 98 to 02. From then on it is the 1UZ 4.7 V8 IFS 100.
You can still get a live axle in the naturally aspirated diesel DX and GXL to date as has already been said.
A simple answer to your question in which others find difficult to reciprocate.
Hope this helps.
120scruiser
190632
Follow Up By: Twinkles - Wednesday, Aug 23, 2006 at 22:15
Thanks 120scruiser
448274
