winch brand question
Submitted: Wednesday, Aug 23, 2006 at 16:21
truckie
In the market for a winch for my GQ wagon and have shopped around a bit to find a huge variation in prices.
Warn is of course popular but am I paying for the name?
They also produce
winches such as the Magnum with a Bosch motor instead of a Warn. And of course there are other brands such as the Ironbar, Ox etc.
Now I know everyone has favorites, but if anyone has found the cheaper brands as good as the likes of the Warn
winches, or if there are any commonly terrible that I should run in the other direction from, then Id be glad to hear of your opinion and experience.
I wont be using it everyday, but when I do its gotta work.
Thanks all.
Reply By: GUPatrol - Wednesday, Aug 23, 2006 at 16:42
It all depends on what kind of winch you want and what space you have etc ie: some bars will only fit warn 9000 low mounts so you are limited to that....
However, if you are not limited to that or a high mount winch then look at other brands.
After pulling apart a warn low mount, I can't see any other winch being built any worse.
After sales
services and spares is good however and I don't know if you would be able to get spares for other less known brands.
If you go for a warn low mount, go for the XP, at least it goes somewhere towards
water proofing, the nonXP are designed to take
water and rust....
190550
Reply By: truckie - Wednesday, Aug 23, 2006 at 17:27
Have a standard ARB style steel bullbar. Bolts to the outter edge of the chassis tube so should be able to fit the bigger
winches with the wider motor such as the 9.5 XP but thats probably overkill for my needs.
The price difference between the 9000lb Magnum and the 9000lb Warn is $500 simply because it uses the Bosch motor so one wonders how much the other components are overpriced.
The problem may be in the servicing though as you say.
Thanks GU
190559
Reply By: Tim@Stratford - Wednesday, Aug 23, 2006 at 17:57
Truckie,
I had a Superwinch X9 dealer fitted to a Hilux in 2000 - it did a fair bit of work - not overkill, but it functioned flawlessly. Always in the elements etc and often got dunked - never failed. The only problem was that it had the old fashioned control box with only three wires - so it was possible to short it out to make it work - problem as other posts with the vandals.
Now got a 10000 Warn on a 100s - only been on the truck for 18mths - already had a solenoid fail - pain in the butt when you've got 30m of cable out....And as the other post says - their aren't
water or dust proof at all (there is an optional seal kit but I haven't looked at one of these)
But being a Warn it was easy to source parts and have it fixed ($45 for a solenoid). It does 'pull' harder - but it is rated for an extra 1000 pounds - and seems to be geared slightly lower than the X9 - but if I was going to get another winch for a hilux I wouldn't hesitate to go with a Superwinch.
My 2c worth,
Tim - Stratford.
190569
Reply By: Sand Man (SA) - Wednesday, Aug 23, 2006 at 18:09
truckie,
I don't know what I'm talking about because I don't have a winch and have never used one.
Having advertised my qualifications (or lack of) I have read enough on this
forum to become an instant expert.
From what I have read, it would appear the Warn, whilst being a good winch, suffers if submerged and for this reason I would suggest you take a look at the Brawn Winch which is supposedly waterproof.
Your last sentence says it all.
"I wont be using it everyday, but when I do its gotta work"
Check out the following Posts:-
Post 23001
Post 11479
190572
Reply By: Dave from P7OFFROAD Accredited Driver Training - Wednesday, Aug 23, 2006 at 20:30
I've had two OX hydraulics on three different cars and have found them to achieve all that I need of them, over and over, without fail.
190595
Follow Up By: ACDC - Wednesday, Aug 23, 2006 at 21:19
I have to agree! slow but very reliable..
448257
Reply By: Member - Fourplayfull - Wednesday, Aug 23, 2006 at 21:18
I have just finished installing my first winch which falls into same use you need . Fitted a 12000lbs Iron Man distributed by JSW Parts - pick up thru' Repco Stores .
Stripped it down to check out the internals and added Loctite 567 to gearbox end cap and lithium grease to spool selector lever base to aid waterproofing . Mounted control box on a trick waterproof foam gasket 12mm thick with underbonnet circuit switch & spool lever .
Could not find any breathe holes on elec.motor though . Iron Man are helpfull with mounting details etc. and carry spares .
Fabricated a separate mounting bracket for winch & fairlead leaving standard steel ARB bar in place .
I,ll advise the results after a trip into Vic. h/c next fortnight - if there is any tracks open ????
190614
Reply By: Rogerthatv2 - Wednesday, Aug 23, 2006 at 21:50
I picked up a TJM Ox 10000lbs winch from TJM Geebung in
Brisbane, only $1095.00. More than happy with it. Not the quietest out there but has worked when I have needed it, and also when my mates have needed it as
well. I think they have it on there site at the moment www.tjmgeebung.com.au
Hope this helps.
Roger
190628
Reply By: Bonz (Vic) - Friday, Aug 25, 2006 at 21:54
Chech out the Premier winch, they get a good rap in tests and have done me proud, not a bad price too, got
mine thru Brown Davies in Bayswater
191051
Follow Up By: truckie - Monday, Aug 28, 2006 at 11:39
Been doing a lot of follow up on all the info from everyone.
Just on the premier alone the prices range from $1499 for a 9000lb from 4wd world to $765 for a 10000 from tradesmans entrance on line.
looks like more homework for me.
Thanks for your help
449181
