OT Hair, why does it grow the way it does.
Submitted: Thursday, Aug 24, 2006 at 21:53
ThreadID: 37083 Views:6290 Replies:4 FollowUps:15
Sure, this a wierd post, and I'm happy for it to be deleted soon.
If you don't get your hair cut, it will eventually grow down to your feet. As will the whiskers on a bloke's face.
I've had an operation on my arm where they shaved the hairs on my arm; the little buggers grew back vigorously until they hit the pre-determined limit and then stagnated.
I'll not even discuss the 'Brazillion"
Most of us have hairs on our arms and legs, they stop at their limit. Some neanderthals like myself have it on their chest and back. All of us have it on our nether regions. Why in these areas does it hit a border and then cease like there is a STOP sign there?
How does the body tell hairs when to stop growing?
Sorry, it fascinates me.
I'm ready for the "two bob" comedians LOL.
Reply By: Neil & Pauline - Thursday, Aug 24, 2006 at 22:36
I reckon it is the sun shining on hair root makes it grow.
Then again it could be the lack of sun that makes it grow.
Maybe it is something that just happens.
I think I will go back to fishing before some one picks holes in my "research"!!!
AnswerID: 190854
Follow Up By: A.J - Friday, Aug 25, 2006 at 20:29
Shoot holes in my therory that nuthin' grows in the shade!
LMAO
FollowupID: 448730
Reply By: Brian B (QLD) - Thursday, Aug 24, 2006 at 23:20
Jim,
The following is straight out of my clinical methods text book so please excuse some of the mumbo jumbo, but it does give a bit of an explanation
"Humans have three different types of hair:
• Lanugo, the fine hair that covers nearly the entire body of embryos
• Vellus hair, the short, fine, "peach fuzz" body hair that grows in most places on the human body in both sexes
• Terminal hair, the fully developed hair, which is generally longer, coarser, thicker, and darker than vellus hair
The most noticeable part of human hair is the hair on the head, which can grow longer than on most mammals. The other parts of the human body feature different types of hair. From childhood on vellus hair covers the entire human body regardless of sex or race. The density of the hairs (in hair follicles per square centimeter) varies from one person to another.
The rising level of male hormones (androgens) during puberty causes a transformation process of vellus hair into terminal hair on several parts of the male body. The hair follicles respond to androgens, primarily testosterone and its derivatives; the hair in these locations can be termed androgenic hair. The rate of hair growth and the weight of the hairs increase. However, different areas respond with different sensitivities. As testosterone level increases, the sequence of appearance of androgenic hair reflects the gradations of androgen sensitivity. The pubic area is most sensitive, and heavier hair usually grows there first in response to androgens.
Areas on the human body that develop terminal hair growth due to rising androgens in both sexes, men and women, are the underarms and the pubic area. In contrast, normally only men grow androgenic hair in other areas.
Individual hairs alternate periods of growth and dormancy. During the growth portion of the cycle, hair follicles are long and bulbous, and the hair advances outward at about a third of a millimeter per day. After three to six months, body hair growth stops (the pubic and armpit areas having the longest growth period). The follicle shrinks and the root of the hair grows rigid. Following a period of dormancy, another growth cycle starts, and eventually a new hair pushes the old one out of the follicle from beneath. Head hair, by comparison, grows for a long duration and to a great length before being shed. The rate of growth is approximately 1.25 centimeters, or about 0.5 inches, per month."
Have a good one.
AnswerID: 190861
Follow Up By: Member No 1- Friday, Aug 25, 2006 at 07:42
good explanation.
FollowupID: 448542
Follow Up By: cackles - Friday, Aug 25, 2006 at 08:04
Correct Brian well done,
our hair growth length and direction can be traced back to knuckle dragger days when it was used to channel water off the body.
Did you also know that hair grows in a circular pattern around your head with the centre at you crown?
You can go grey overnight, after an emotional shock only the pigmented hair falls out leaving the grey.
The curlier the hair, the flatter and more eliptical each individual hair. Explains a lot.
Did you know everytime you have sex a hair falls out?
Cackles
FollowupID: 448549
Follow Up By: Member No 1- Friday, Aug 25, 2006 at 09:12
your absolutely correct cackles
i wore mine off on the bed head
FollowupID: 448565
Follow Up By: Truckster (Vic) - Friday, Aug 25, 2006 at 09:27
long sleeps are not that good for you #1
FollowupID: 448570
Follow Up By: cackles - Friday, Aug 25, 2006 at 12:03
Hate to see the bedhead then
FollowupID: 448613
Follow Up By: Patrol22 - Friday, Aug 25, 2006 at 12:43
So that's what happend to my follicle :-)
FollowupID: 448621
Follow Up By: cackles - Friday, Aug 25, 2006 at 13:03
does that make you "follicly challenged"?
FollowupID: 448628
Reply By: Member - bushfix - Friday, Aug 25, 2006 at 07:25
this post is useless without pictures :)
AnswerID: 190874
Follow Up By: Member - Bware (Tweed Valley) - Friday, Aug 25, 2006 at 08:01
Follow Up By: Member - bushfix - Friday, Aug 25, 2006 at 08:24
safe to open at work?
FollowupID: 448554
Follow Up By: SA_Patrol - Friday, Aug 25, 2006 at 08:33
Blogger 404 - page not found
FollowupID: 448557
Reply By: Redback - Friday, Aug 25, 2006 at 09:18
AnswerID: 190886
Follow Up By: Redback - Friday, Aug 25, 2006 at 09:19
And
FollowupID: 448568
Follow Up By: Member - Bware (Tweed Valley) - Friday, Aug 25, 2006 at 10:06
Thanks Redback. Wow, I thought I had a hairy back!
FollowupID: 448582
Follow Up By: Spike me - Friday, Aug 25, 2006 at 15:21
Could you please refrain from putting pictures of Truckster on the internet.
FollowupID: 448661
Follow Up By: Luke SA - Friday, Aug 25, 2006 at 21:46
And some people say we didnt evolutionise from monkeys
FollowupID: 448745
