Warning re Nissan Pathfinder towbars
Submitted: Thursday, Aug 24, 2006 at 22:30
ThreadID: 37086 Views:15073 Replies:15 FollowUps:11
From my posting on Overlander forum
Re Latest Model Nissan diesel Pathfinder, purchased 10/11/2005
On Tuesday, August 15, at approx 12 noon, after travelling 1200K from Townsville to St George over several days, averaging around 90-100kph on the highway, we pulled into the Caltex garage in St George to re-fuel.
After filling up, as we pulled out of the driveway, which is quite flat, the towbar broke away from the chassis and the entire assembly with the 21’ caravan, crashed off onto the highway. Fortunately, we were only creeping along at approx 5kph.
Thankfully, St. George is a flat town with no hills, as the safety breakaway brakes system is attached to the towbar, and since the entire towbar broke off, the safety brakes were not actuated. Since the safety chains are also attached to the towbar, they were also ineffectual. Had this happened anywhere on our entire 20,000K towing the van, it would have kept hurtling down the highway and only stopped when it hit something – or somebody.
On examination, it was found that 6 bolts had sheared off. Two had obviously broken off some time ago, as the exposed broken ends were covered in rust. The remaining 4 broken ends with nuts and washers were found on the road near the towbar assembly.
The towbar, with the Hayman Reese hitch still attached, was re-fitted to the vehicle by the local Ford / Nissan dealer in St George.
It is important to note that the towbar sold by Nissan with the Pathfinder, according to their published specifications, is 3000K tow capacity and 300K download ball capacity. Our caravan has a TARE 2260K, Gross loaded 2750K (current actual load approx 2620-2640k) and tow ball weight of TARE 180K and loaded about 220K, which well under the recommended weights from Nissan. These towbar weight specification figures were confirmed by the dealer when I purchased the vehicle. I also checked with the dealer if the Hayman Reese Load Levelling Hitch, which I already owned, would fit this towbar and was assured it would.
After being repaired, we towed our van with much trepidation to Narrabri, where we decided we felt very uncomfortable about towing much further. We phoned Nissan head office in Melbourne on 17 and 18 August. We had problems with the CDMA phone dropping out.
Finally, we made contact with a Nissan person named Andrew, who later I was told was an engineer. He told me that the Nissan towbar should not have a Hayman Reese Hitch, and that I was not to tow my vehicle using this hitch. I told him this was not what the Nissan specifications stated. He argued that he was correct. I told him to look on the web site and to read what it says. He did so.
The web site says:
[i]Towing capacity is subject to towbar/tow ball capacity. The capacity may be reduced if a non genuine Nissan towbar is fitted. The permitted download is directly related to the laden mass of vehicle. The maximum tow ball download is 300kg.[/i]
AND:
[i]Nissan is not able to make any recommendation on the use or suitability of load-levelling or weight distribution devices to be fitted to the vehicle. Customers should contact the manufacturers of these devices for further information.[/i]
Andrew told me that ‘this means you cant use a load levelling hitch with this towbar’.
I asked him how on earth he could read that into the above statements.
He told me that I was not to tow the vehicle with the Hayman Reese hitch applied.
I told him that all trailers over even 2000K, everybody who was conscious of safety uses a load levelling hitch. He made the statement that the Nissan Pathfinder does not need a LL hitch as he has towed trailers with loads near 3000k and didn’t use a hitch. I told him anyone who towed that sort of weight was irresponsible if they did not use some type of LL hitch..
He reiterated I was not to tow caravan without fitting a Hayman Reese towbar or taking the HR hitch off.
I then got a message from the Nissan dealer in Townsville who sold me the car, that they were willing to pay towards the cost of refitting the broken off towbar and to get a Hayman Reese towbar fitted to my vehicle. This was limited to $480. It cost me $926.
I phoned the NRMA legal department. They told me since Nissan had sold and later fitted the towbar with the Hayman Reese hitch still attached, and that their mechanic had told me it was safe to tow, The onus was on Nissan to prove otherwise.
I showed the broken bolts to one of the Reese fitters and asked him what would have caused the bolts to break. He said I will show you why. Apart from what he considered to be the poor design of the towbar, he showed me the towbar manufacturers compliance plate, which is mostly hidden from view under and behind the bumper bar. It quite clearly states tow capacity as 3000K and tow ball download 250K. Yet Nissan claim 300k ball weight. I asked Nissan about this discrepancy. I was told that they had tested the towbar themselves and had decided that it would hold 300K download so they overruled the manufacturer and increased the rating. I said would the fact mine broke overrule your tests? No – their tests were based on not using a LL hitch.
Using the industry standard of 10% tow weight as being on the tow ball, what they sold me was probably illegal for my van.
My total costs to replace this towbar with one that will tow the weight I purchased the vehicle to tow, is $926. I have demanded a total refund of my full out of pocket costs, which has now been met by the dealer. I must add the dealer has done all possible to help. I think he has been given the run araound by Nissan HO.
A friend of mine who purchased a Pathfinder on my recommendation, wanted to buy a Hayman Reese towbar when he purchased the vehicle, but he was told by the Nissan salesman that the Nissan tow bar was superior, so he bought it. He is now having that towbar replaced with a Hayman. He doubts the Nissan dealer will pay. I think they should.
I have now learned of two more cases of bolts breaking on Pathfinder towbars, however they did not lose everything – yet!
I demanded Nissan make a public notice of this. They stated that in their opinion it was quite plain from their published statement (as above, in italics) that you cannot use a hitch with their towbar. You have to phone the hitch manufacturer to check if their hitch will suit the Nissan towbar.
So I phoned Hayman Reese and asked them if their hitch was suitable to tow my 2750K van with ball weight of 230K, using a genuine Nissan towbar on my Pathfinder. I was told: “As long as the square tongue on the Reese hitch fits the Nissan towbar, you will be OK. If the towbar is rated as 300K download and 3000K, you wont have any problems. With a van that size, you definitely should be using a load levelling hitch like ours. Would you like to buy one?”
I have now found via another forum, several new Nissan Pathfinders with broken bolts holding the tow bar to the chassis. It is only a matter of time before someone is killed. Nissan stand by their published specifications as being quite plain that you cant use a hitch with their towbars. Damned if I can read that into their statement.
So be warned – if you know of anyone with a new model Pathfinder using a genuine Nissan towbar with a LL hitch such as Hayman Reese, get them to check their mounting bolts (should be 6) holding it to the chassis. And let them be aware that Nissan claim they should NOT be using their towbar with any hitch.
This shows the towbar how it is bolted to the underside of the rear chassis. There is what appears to be just a seperate metal plate (not shown in photo) that goes on top of the chassis whose sole purpose seems to be to stop the bolt heads from pulling through the chassis.
[URL= Site Link
These are the 6 broken bolts. Notice the middle two are rusty and obviously broke off some time before the bar ell off.
[URL= Site Link
This is the compliance plate that clearly shows the ball weight as 250K, not 300K as Nissan claims.
[URL= Site Link
I will aslo point out even the Overlander Magazine experts were fooled by the Nissan spec sheets - they completed a towing test last month with a Nissan Pathfinder fitted with the genuine towbar and a Hayman Reese Hitch. Yet Nissan, when I last spoke to them, insist the wording on their spec sheets clearly state a LL Hitches cannot be used with a Nissan towbar.
Reply By: Sand Man (SA) - Thursday, Aug 24, 2006 at 22:52
Bloody hell mate. That is serious. Is the first picture the full bar. My god.
Those bolts don't even look like high tensile ones, which are usually black, AFAIK and not plated like those ones appear to be.
Bill
AnswerID: 190857
Follow Up By: SA_Patrol - Friday, Aug 25, 2006 at 08:07
I agree, they are too shiny to be hi tensile.
FollowupID: 448551
Follow Up By: pelbo - Friday, Aug 25, 2006 at 08:52
The bolts are marked high tensile.
FollowupID: 448561
Follow Up By: datto311 - Friday, Aug 25, 2006 at 12:58
I'm not a mechnaical engineer, but maybe because they are high tensile, that is why they broke? I know in some suspension components, high tensile bolts are prohibited becuase they break. Much better to have bent bolt than a broken one...
Bad design of a towbar, however
Noel
FollowupID: 448625
Reply By: Member - Andrew W (SA) - Thursday, Aug 24, 2006 at 23:35
Intriguing post ... I think I'd be calling DOTARS if you can find anyone to answer the phone there - sounds like time for a recall.
For one thing, I can't see this design as possibly being capable of pulling 3000kg.
Secondly, the guy from nissan debating with you is the most rediculous thing I have heard in years - I can't believe they weren't running like mice in a wheel trying to sort the problem out.
If load levelling hitches generally caused some concern why not a big label that says not to use one - why it doesn't help rather than hinder I have no idea.
Ciao for now
Andrew.
AnswerID: 190864
Follow Up By: Member - Jerry C (WA) - Friday, Aug 25, 2006 at 00:22
I am no mechanical engineer, but this design looks like it was just looking for a good spot to fall off and you arrived there.
Just looking at it, with the hitch mounted so far below the attachment point the rotational pull on the bolts may have magnified the load by 2 to 3 times.
In the second photo the bolts appear to have stretched until they broke, not sheared of as may normally be expected.
Food for thought,
Jerry
FollowupID: 448536
Reply By: Member - Jerry C (WA) - Friday, Aug 25, 2006 at 00:33
I was under the impression that high tensile bolts all had "8.8" stamped on the heads.
Jerry
AnswerID: 190867
Follow Up By: Leroy - Friday, Aug 25, 2006 at 07:54
bolts come in different tensile strengths which are indicated by the markings on the top of the bolt.
Leroy
FollowupID: 448545
Reply By: Member - Blue (VIC) - Friday, Aug 25, 2006 at 07:19
Damn, there is no way I can look at that ans invisage putting 3000kg on it... Everything about it's design screams "box trailer" to me although I'm no engineer...
AnswerID: 190873
Reply By: Member - Bware (Tweed Valley) - Friday, Aug 25, 2006 at 07:42
Hi Pelbo,
"I demanded Nissan make a public notice of this." Good luck with that mate; They wont even do that with the 3L patrol 'exploder'. A towbar is probably further down the list.....
AnswerID: 190875
Follow Up By: pelbo - Friday, Aug 25, 2006 at 08:50
I feal it is more than just a towbar. Its a towbar towing a 3000K trailer breaking off and hurtling down the highway until it slams into an innocent mother and 3 kids coming the other way.
Don't forget, when the towbar breaks off, with it come the emergency chains and the emergency brakes, which will not activate because the activation wire is attached to the towbar.
I use the innocent mother and 3 kids scenareo because I know of that happening when a box trailer broke loose some years ago and wiped out a familly.
I think it is far more dangerous than a 3litre motor failing.
FollowupID: 448560
Follow Up By: Member - Bware (Tweed Valley) - Friday, Aug 25, 2006 at 10:03
Agreed, but will Nissan see it that way?
FollowupID: 448581
Follow Up By: Dazmit - Friday, Aug 25, 2006 at 10:28
That's probably why in the Break Safe instructions it states to attach the emergency brake wire to the chassis of the vehicle and not the towbar.
That said Nissan still has a problem they won't admit.
Darryl
Brisbane
FollowupID: 448586
Reply By: Leroy - Friday, Aug 25, 2006 at 07:56
'This is the compliance plate that clearly shows the ball weight as 250K, not 300K as Nissan claims. '
so how do you go making a claim through your insurance co. if an assor spotted that compliance plate on your tow bar? Bugger me you would have one hell of a battle between nissan and the insurance co. asking for proof of the testing they did to rerate it.
Leroy
AnswerID: 190877
Reply By: GUPatrol - Friday, Aug 25, 2006 at 09:29
Pelbo,
It was only yesterday that I was at the Nissan Dealer looking under a new Pathfinder to see how well they were built (or not) and saw the towbar...
The tow bar is ridiculous, it just bolts on the chassis, hanging down a fair distance with no triangulation!!
There is no way that those bolts even if they were high tensile would stand the leverage action that a caravan or trailer would place on it.
What does the Hayman Reese one look like??
I wouldn't town any more than about 500kgs with that genuine one...
AnswerID: 190887
Reply By: John and Lynne - Friday, Aug 25, 2006 at 09:39
Thank you Pelbo for alerting us to this problem and posting such a detailed account. What a terrible experience!
After hearing of your story we had our Pathfinder towbar checked by our dealer (who had heard nothing from Nissan about possible towbar problems) and found two loose bolts. We have travelled some 8,ooo kms towing a 2 tonne van.
When we purchased the vehicle in January we were also assured that the towbar was suitable for use with a Hayman Reese hitch.
We are now pursuing the matter with our dealer and with Nissan Australia. It will be interesting to see what happens. John and Lynne
AnswerID: 190893
Follow Up By: pelbo - Friday, Aug 25, 2006 at 11:41
John and Lynne,
I am glad you caught the problem in time. Replace the towbar with a Hayman Reese towbar - VERY MUCH stronger than that pathetic effort from Nissan.
It will cost you about $750 including re-setting the hitch. Make sure you do reset the hitch, as the Hayman bar places the towball about 2" higher. It is expensive to fit because of the design - they have to remove the rear floor, rear bumber bar, mud flaps and lights, as well as cut a section out of the bumper bar.
The genuine Nissan bar is just bolted into place - takes ten minutes. They wouldn't make the design criterea for ease (read - cheapness) of installation as opposed to expensive but safe design, would they? No.......No?
Please make sure you force the issue with your dealer to pay every cent to replace the bar with a safe one. If you want, contact me via my email.
FollowupID: 448610
Follow Up By: GUPatrol - Friday, Aug 25, 2006 at 14:34
Pelbo (and John and Lyne),
If the bolts were loose, I suspect that there is yet another problem, and that is that the bolts go straight through the chassis without a reinforcing tube where the bolt fits, if that is the case then when they tighten the bolt, the box section just deforms, when weight is applied it deforms even more and slowly starts to flex and loosen up eventually failing.
FollowupID: 448638
Reply By: Member - Boo Boo (NSW) - Friday, Aug 25, 2006 at 10:32
Pelbo
You are one lucky bugger. Go and buy a lotto ticket.
I like everyone else have had a look at the pics and have to agree with those that would not tow more than maybe a large box trailer with that setup. If the first picture was the whole to bar then heaven help any towing a van with it.
You know that sinking gut feeling you get when something goes horribly wrong,well I've got it know typing this message. If it had given way ten minutes later...........?
Coupled with a few other things I have read on our site I would really be reluvtant to buy Nissan.
Regards Bob
AnswerID: 190902
Follow Up By: pelbo - Friday, Aug 25, 2006 at 11:50
Bob - I think we used up about ten years of good luck!
If it had given way only ONE MINUTE before when we were doing 90kph!
If it had given way driving down Thunderbolts Way -one of the steepest mountain passes in Oz....
If it had given way when driving down the pass to Lithgow....
If it had given way driving through the Snowy Mountains......
If it had given way driving through Sydney....when we were stopping to let a whole lot of school children cross a pedestrian crossing.
My wife and I have nightmares about it.
FollowupID: 448611
Reply By: GaryInOz (Vic) - Friday, Aug 25, 2006 at 11:51
pelbo,
I hope you don't mind but I sent a copy of initial post to both DOTARS and Recalls.gov.au . (Don't know if you have done this already, but if enough ppl bring it to their attention something might be done.)
As you have implied, a significant safety issue that should be acted on, not just discussed and tossed between departments at Nissan.
AnswerID: 190919
Reply By: Spike me - Friday, Aug 25, 2006 at 15:18
Whaddya Expect. Its a Nissan.
AnswerID: 190955
Reply By: Member - Jeff M (WA) - Friday, Aug 25, 2006 at 16:13
Boy oh boy, that's an amazing storey!
When you look at the towbar with a measly 150kg ball weight and 1500kg capcity on the surf, it's chalk and cheese compared to the one you pictured.
I just went and had a look for a comparison. I've got no less than 10 bolts both horizontal and vertical to the chasis, plus welds, plus triagular 6mm flatbar welded to the corners for strength. 1500kg!? And that wheel barrow handle nissan are fitting is supposeed to take 3 tonne!?
I guess that other problem is recovery. Now I know technically you are not supposed to recover from a hitch reciver, but it is a pretty common practice. (I do it as rear recovery points are hard to fit to a surf, in fact if I were to fit them I'd be attaching them to the tow bar anyway!!)
But people should be aware that using a snatch strap on one of those nissan jobbies could well be a life threatening activity! Imagine having that thing comming at you like a bullet! I know I sure as bleep will be having a closer look at people's hitch receivers before I slip the end of a snatch through it from now on....
AnswerID: 190965
Reply By: Derek from Affordable Batteries & Radiators - Friday, Aug 25, 2006 at 20:50
I designed a sliding towbar for off road use about 2 years ago and when presented it to ARB and Hayman Reece they showed no interest.
I think it is time to start production of my invention and give these guys a go. I have a full demo video and will try get it up on my site.
AnswerID: 191032
Reply By: ZUKSCOOTERX90(QLD-MEMBER) - Friday, Aug 25, 2006 at 21:32
Pelbo,sorry to read of you're misfortune i am glad for you & you're wife that it happened where it did as this has saved you all a lot of anguish & heartache.One can only imagine what could have been & be thankfull that was all it turned out to be(what could have been.) My sister & hubby have just purchased the latest model also & van but have yet to tow it any great distance.
I thank you very much for you're detailed account of every thing & i emailed it to them so they too can look into it for their own peace of mind.
I also wish you both the best of luck from now on in your'e future advenure's .
Regards Bob.
AnswerID: 191045
Reply By: Technical Tom - Sunday, Aug 27, 2006 at 17:51
Hi Pelbo,
Been referred to your problem by another site reader. You are certainly lucky. As you know, you are not the first to who this happened. I've had discussions with a David (Manager, Services-Technical) at Nissan. He also told me while discussing this matter across the table that you can tow 3000kg behind a Pathfinder with 300kg vertical load on the ball without a levelling hitch. These people don't live in the real world.
While the Pathfinder is a nice car, it isn't a 3000kg tow vehicle. Have you looked at the sliding scale for the ball load? You can have 300kg if you don't have any more than two people, a tank of fuel and possibly a change of underwear and a camera. As you increase the load in the vehicle (GVM) the ball load reduces. Considering the amount the average person/family would carry in the car the ball weight limit would quickly be back to 250kg and in many cases 200kg. The same applies for a Patrol. Check out the towing info on the brochure or in the hand book.
The reason that Nissan gave the Pathfinder a 3000kg rating is that they wanted to give buyers who like to tow an impression that it is better than say a Prado or a Pajero, both with a realistic limit of 2500/250.
Sadly they are not the only manufacturer with a head-in-sand attitude.
Keep stirring them up.
Technical Tom
AnswerID: 191298
