Jaycar MB3620 Battery Charger
Submitted: Saturday, Aug 26, 2006 at 08:09
Moggs
One for the battery gurus.
I need anew battery charger for my Waeco Thumper and 100ah AGM battery. Came across this one at Jaycar:
Site Link
Has anyone got one of these?? Would it be ok for the AGM??
Seems reasonably priced compared to some others, and is also weatherproof which would be a bonus.
Reply By: Member - Mike DID - Saturday, Aug 26, 2006 at 08:22
Yes, it will charge AGMs
well, despite the description.
" four stage rapid charge design to optimize the life and performance of lead acid/GEL batteries"
- this would suggest a Gel is not a LeadAcid Battery !!!
You could also use the cheaper MB3612 ($99) which will charge at 12 amps and is more compact. This is a 3-stage charger despite the manual saying it is two stage - the power light changes from red to
orange to green during the three stages.
191096
Follow Up By: Moggs - Saturday, Aug 26, 2006 at 08:24
Thanks Mike. I like the idea of it being weatherproof - might decide to add it to the trailer one day.
Do you see any benefit other than this between te 2 models mentioned that would justify paying the extra??
448785
Follow Up By: Member - Mike DID - Saturday, Aug 26, 2006 at 08:42
Moggs - the MB3612 is not weatherproof and does not do pulse charging, but there is debate as to whether this will actually put more charge into an AGM battery. It is a lot smaller than the MB3620.
I won't use chargers where they need to be weatherproof - although there are others on this
Forum who would have benefited from weatherproof chargers :-)
448787
Follow Up By: Moggs - Saturday, Aug 26, 2006 at 09:07
ok. Thanks
448789
Follow Up By: Bonz (Vic) - Saturday, Aug 26, 2006 at 09:12
Doesnt weatherproof mean it will survive a shower of rain or the like? I wouldnt want a battery charger trailer mounted and out in the real weather for very long I reckon it'd stuff it.
448792
Follow Up By: Moggs - Saturday, Aug 26, 2006 at 09:14
Hi Bonz, yeah, I agree. I was thinking more along the lines that if the outside got wet when not in use I wouldn't have to worry about whether the internals were wet next time plugged it in.
448793
Follow Up By: Bonz (Vic) - Saturday, Aug 26, 2006 at 09:16
Hey Moggs, yeer I saw that below hahahah
448795
Reply By: Derek from Affordable Batteries & Radiators - Saturday, Aug 26, 2006 at 08:58
I would be careful with
water and chargers.
The only charger I know that has a legal
water resistant cirtificate is the Ctek.
The new Ctek 15 amp chargers are now available.
191101
Follow Up By: Moggs - Saturday, Aug 26, 2006 at 09:09
Thanks Derek, not planning on using it in a wet environment, however if I have it is the trailer and it gets splashed or damp I thought it might be of benefit to get a waterproof one.
I saw the Ctek chargers - a bit more expensive than the Jaycar ones. Didn't really want to spend that much. The AGM typically stays in the Patrol hooked up to the redarc our gets charged from the solar panels when
camping. Just looking for a simple charger to ensure it is fully charged prior to heading away.
448791
Follow Up By: Derek from Affordable Batteries & Radiators - Saturday, Aug 26, 2006 at 09:14
Then the MB3620 should be O.K. for what you need.
Regards Derek.
448794
Follow Up By: Member - Mike DID - Saturday, Aug 26, 2006 at 10:40
The smaller MB3612 is NOT waterproof at all, because both ends have holes in them and a fan _Affordable_Storage_Drawers.aspx air through it to cool the internals.
If you want to achieve the same cooling in sealed case, it will have to be larger so it has a larger cooling area.
448817
Follow Up By: Moggs - Sunday, Aug 27, 2006 at 20:15
Hi Derek, Got the Jaycar MB3620today - thing didn't work, and to be honest - looked very fragile and poorly put together. Have just visited your ebay
shop. Hope the charger you sell is much better!
449068
Reply By: Eric Experience. - Saturday, Aug 26, 2006 at 11:29
Moggs.
The older style of lead acid battery can be charged to 14.2 volts but a agm must not be charged over 13.8, the reason for this is that the higher voltage breaks down the
water into hydrogen and oxygen, in the wet cells the gas can escape but in an agm the gas is captive and the oxygen causes the negative plate to oxidise and destroy the battery. The best thing to do is to get a good multimeter and monitor the voltage, I use a string of diodes as a method of dropping the voltage to avoid over charging agm's. many people on this
forum, even some claiming to be experts have destroyed there batteries by over charging, you should get about 5 years out of an agm if you don't over charge it. Eric
191112
Follow Up By: Alloy c/t - Saturday, Aug 26, 2006 at 11:36
Eric ,that is a load of bovine droppings , 5yrs ?? 13.8v ?? bovine droppings !!
448830
Follow Up By: Moggs - Saturday, Aug 26, 2006 at 16:05
hmmm... I have the AGM in the cargo area of the patrol and it charges at around 14.1 volts through the Redarc when driving. Are you saying this will stuff an AGM? I was under the impression that an AGM will handle just about any charge you throw at it???
448855
Follow Up By: Member - Mike DID - Saturday, Aug 26, 2006 at 16:32
Have a look at the Datasheet for any AGM, it will show that the Float (13.8) and Absorption voltage (14.4) for an AGM are the same as for a wetcell.
448859
Follow Up By: Eric Experience. - Saturday, Aug 26, 2006 at 21:43
Thanks Mike, that's exactly what I am saying, charge at 13.8. the 14.4 charge must stop before the gassing starts, because you can not see the bubbles you are taking a risk to run a charger at 14.4 and walk away from it. Eric.
448902
Follow Up By: Eric Experience. - Saturday, Aug 26, 2006 at 22:23
Aloy ct.
Can I suggest that you ask an auto elec to show you how to read the dates on batteries, and then have a look at some agm's that have been used in set ups that are professional installed like in ambulances or fire trucks, these batteries are changed after 2 years as a precaution, but they can work for another 3 years in private vehicles if installed correctly. Some 4x4 setups only get 1 year out of the same batttery. Eric.
448909
Follow Up By: Alloy c/t - Sunday, Aug 27, 2006 at 07:53
Eric ,as I stated previously your full of bovine droppings ,you cant even read Mikes reply correctly ,,he is telling you that 14.4 GHARGE and 13.8 FLOAT ,, two totally different processes to your crapola ,,
448935
Follow Up By: Member - Mike DID - Sunday, Aug 27, 2006 at 19:36
Here is an extract from the Optima yellow datasheet - the same voltages and times appear on the Optima Red datasheet
"Battery Charger (Constant Voltage): 13.8 to 15.0 volts; 10 amps maximum; 6-12 hours approximate"
"Rapid Recharge:Maximum voltage 15.6 volts. No current limit as long as battery temperature remains below 125°F (51.7°C). Charge until current drops below 1 amp."
"Cyclic or Series String Applications:
14.7 volts. No current limit as long as battery temperature remains below 125°F (51.7°"
"Extract from Exide Orbital Battery Technical Information
Constant Voltage Recharge: Appropriate for infrequent cycling use
o Voltage set-point: 14.6 volts (A)
o Current limit: 20% of nominal capacity (15 amps for most Orbital sizes)
o Recharge time: 8-18 hours or when current reaches < 2% of capacity (1.5 amps)"
449056
Follow Up By: Eric Experience. - Sunday, Aug 27, 2006 at 22:11
Mike.
All of the above is correct for the type of construction.
these figures assume a discharged battery, if you were to apply these voltages to an already charged battery you will damage it. that is why they give a maximum time. In the case of the orbital they spell it out, [ for infrequent cycling use] that is its ok in an application where you have several batteries in series and you want to equalize them. but in the application mogs asked about where he wants to put a charger on to ensure that the battery is fully charged before a trip, his starting point is unknown and so the only safe voltage is the float voltage. You are correct in saying it is the same as a wet cell but a wet cell can tolerate
water loss an agm can not. This is the reason a lot of 4x4 owners use starting batteries as a 2nd battery because they are cheaper and can take more abuse and therefore last longer than a dedicated storage type that is overcharged. Eric.
449106
Follow Up By: Alloy c/t - Monday, Aug 28, 2006 at 17:51
Eric ,please explain to all and sundry how an AGM ,,absorbed glass matt battery can lose
water while recharging ,try it youself ,hit it / split it with an axe ,no
water to lose ,,ABSORBED GLASS MATT ,, designed for military and space applications ,, turn it upside down ,sideways , SHOW US THE
WATER.
449279
Follow Up By: Eric Experience. - Monday, Aug 28, 2006 at 22:20
Alloy c/t.
As mentioned above the chemistry is exactly the same as a wet cell, the difference is that the acid
water mixture is captive in a glass matt, in exactly the same way if you over voltage it the
water will break down into hydrogen and oxygen but because it is captive it will damage the plates and change the s/g instead of just rising as a bubble like it does in a wet cell. You can not see the
water in your finger but it is about 90%
water. Eric
449351
Follow Up By: Alloy c/t - Tuesday, Aug 29, 2006 at 06:33
Eric ,sugest you get yourself an AGM ,cut it open , show us the
water , that bubbles at over 13.8 buckling the plates ,you cant because it does not happen in normal use ,, next you will be telling us that the AGMs used in an ambulance/ fire truck are not recharged by the vehicle altenator while underway , 14.2v + .
449384
Reply By: Moggs - Sunday, Aug 27, 2006 at 19:40
Went to Jaycar today and bought the MB-3620.
Got it
home, hooked it up - bloody thing doesn't work - just flashes "
check battery connection" on the Diagnosis panel. Hooked it up to three different batteries - same thing.
Seems to happen with a lot of the stuff I get from Jaycar. Oh
well, back to return it tomorrow!
191315
Follow Up By: Derek from Affordable Batteries & Radiators - Sunday, Aug 27, 2006 at 20:20
I could let my 10 year old daughter answer this follow up.
If I look at a Jaycar or Supercheap catalogue she says 'NO DAD !'
Regards Derek.
449069
Follow Up By: nonon - Monday, Aug 28, 2006 at 23:17
Derek, a more easily diciphered pricing system on your site would go a long way.
449367
Follow Up By: Derek from Affordable Batteries & Radiators - Tuesday, Aug 29, 2006 at 06:16
Yes, I know.
A brand new site will be uploaded in a few weeks.
I will be able to update prices and specials daily. There will also be a type of
forum.
449383
Follow Up By: nonon - Tuesday, Aug 29, 2006 at 22:47
Forum eh? that could be dangerous on a site like yours, what with people from other sites or sellers coming on incognito and running ammok!
I see some heavy moderating coming up! te he
449584
