Poly Water Tank for LC100
Submitted: Saturday, Aug 26, 2006 at 10:32
ThreadID: 37126 Views:3161 Replies:6 FollowUps:3
Does anyone make a Poly Water Tank (perhaps it needs a steel protection plate?) to go in the place of the under-rear spare of a 100 Series LC?
Looking for perhaps 80 litres - should fit in the space really easily and not make a significant dent on clearance.
I've looked at a flat one that OL sell, but it is about 100mm too wide.
Ciao for now
Andrew.
Reply By: Member - Ivan (ACT) - Saturday, Aug 26, 2006 at 12:17
Andrew,
Between the seats and the _Affordable_Storage_Drawers.aspx not an option? - a fair few advantages putting it here > Site Link
AnswerID: 191114
Follow Up By: Member - Andrew W (SA) - Saturday, Aug 26, 2006 at 12:30
Hi Ivan,
No, I don't have the "luxury" of using that space but your setup has some great ideas that would work with where I want to put my tank - I like the pressure activated pump concept a lot. Plus I have all that unused space down under.
Nice article.
Ciao for now
Andrew.
FollowupID: 448833
Reply By: Member - Doug T (W.A) - Saturday, Aug 26, 2006 at 12:26
Hi Andrew
I have one under my bed in the Troopie, 80ltr plastic , I am looking on the internet for a link but can't find one so i will go to the car and get a brand name, it is meant for Semi-Trailers , has a flat and rounded bottom but i just put it in flat to the floor and reversed the inlet and outlet and fill it by reversing the flow back through the tap so yo must have an air outlet so it can breath.be back soon with the brand name
AnswerID: 191115
Follow Up By: Member - Andrew W (SA) - Saturday, Aug 26, 2006 at 12:32
the actual dimensions of it would be good to know too Doug.
The OL one is 1070x800x120mm
I am looking for (say) 900x700x160mm.
Ciao for now
Andrew.
FollowupID: 448834
Reply By: joc45 - Saturday, Aug 26, 2006 at 12:33
Can't help on the under-car tank, but a friend fitted bladders to the cavities at the rear sides of his LC100. Seemed like a great idea at the time, but the plastic side wall trims holding the bladders in just bulged out once the water was filled in the bladders. Deemed a failure!
Perhaps a sheet of steel sheet inside the trim might have helped.
Gerry
AnswerID: 191116
Reply By: Member - Doug T (W.A) - Saturday, Aug 26, 2006 at 12:38
It had a URL on it www.dynaplas.com.au
On the left side of the webpage is a blue panel with all the links to accessories , clik on Truck Water Tanks and it will show photo's and dimensions down the page , and i just found out they have 40ltr tanks as well ,
Mudguards
Plastic
Aluminium
Stainless
Rubber
Mudguard Poles
Mudguard Brackets
Mudflaps
Truck Water Tanks
Load Restraints
Protection Angles
Product Catalogue PDF
DYNAPLAS TRUCK ACCESSORIES 80 litre WATER TANK WATER
The DYNAPLAS "TRUCK WATER TANK" is a great cost effective way to carry freash water.
It is rotational moulded in a high UV stress crack resistant polyethylene and it is very tough, so tough that it will probably out last your truck. Fitted with a 304 Stainless steel tap, with stainless steel water tank straps available.
Part # TANK - 2064
Doug
AnswerID: 191117
Follow Up By: Member - Andrew W (SA) - Saturday, Aug 26, 2006 at 13:16
They look good - the 40l is about thr right dimensions for two of them next to each other, which has other benefits as well.
Now to look at the straps and retaining ;-)
Ciao for now
Andrew.
FollowupID: 448844
Reply By: Member - Doug T (W.A) - Saturday, Aug 26, 2006 at 12:43
Mine just sits in under bed and is not tied down, just stays put,it is surrounded by ARB storage boxes and a 180 ltr fuel tank and positioned just about middle of the wheelbase
AnswerID: 191118
Reply By: Derek from Affordable Batteries & Radiators - Saturday, Aug 26, 2006 at 17:33
Hi Andrew,
I fitted 2 of the 5 gallon red plastic jerry cans from Repco under the car. (Yellow cap ones)
One on each side. They fit like a custom tank between the chassis rail and the side step. You just seal the caps onto them with silicone and drill / fit a dip tube and breather to them. I have a small sureflo pump under the bonnet that pumps them out one at a time and I pressure fill them from the same point. They hold 48L in total when full. They have been on the cruiser now for 6 years with out problems, no stone damage or leaks. I had to replace one ratchet strap the other day as it started to perish. I will do the other side before my next trip.
They are great for day trips and emergency water. I can get 3 or 4 showers from them with water to spare.
Regards Derek.
AnswerID: 191144
