My own compressor comparo.........
Submitted: Saturday, Aug 26, 2006 at 15:49
Member - Roachie (SA)
I said some time ago that I would eventually get around to doing a comparison between the MaxAir (3 years old) and the several month old Mega Grunt (which looks identical to the Maxair). I have the 2 units coupled together side by side on a sheet of plywood. They feed air into 2 tanks mounted on the cargo barrier. One is 3 litre (I swear it's the only 3L thing I'll ever have in my Patrol!!! hahaha) and the other is a 4L gas bottle. There is also a fair amount of air hose/tube front front to back and up onto the roof; but as this is only the 6mm "Festo" type stuff, that wouldn't add much to the capacity.
I started by totally bleeding the tanks/system. Then, using the switches on the compressors themselves (which are both normally left in the "ON" position), I filled the system to the ARB's pressure switch's cut-off point (around 95psi indicated on my "A" pillar-mounted gauge). The Mega Grunt was done first and took 1m27s with a terminal temperature of 42.5oC. I bled the system again and did the same proceedure with the Maxair; 1m12s and 41.3oC.
The 2 units combined managed to do the job in 37seconds and the temps were 32.5 for MegaGrunt and 34.6 for the Maxair.
Not much in it at all. Probably of little interest to the gallery anyway, but hey, I was bored, okay!? Also, just checked out the Load compensation arm/spring on the rear axle of the Patrol too. It had never been altered despite having had 2" then 5" raised coils since purchase. I made up a steel bar with 4 holes in it to raise the bracket, so that the piston on the device is not constantly forced inwards. I'm assuming this is what others have done?
Roachie
Reply By: Alloy c/t - Saturday, Aug 26, 2006 at 16:13
So all up 15 seconds slower for the cheaper version , " holy airpressure Batman ,that could just about ruin my lazy weekend or holidays ,,
a whole 15 seconds wasted " LOL.
191135
Follow Up By: Notso - Saturday, Aug 26, 2006 at 16:15
Yeah, but just stop making jokes about the 3.00. You're not a closet Toy Yota driver are you?
448857
Follow Up By: Bonz (Vic) - Saturday, Aug 26, 2006 at 21:41
Same time saving as the billion dollar "fast" train to
Ballarat
448900
Reply By: nonon - Saturday, Aug 26, 2006 at 16:20
That's only 15 seconds difference Roachie, and only a short burst. The problem I have with my Max air "clone" is after pumping up 4 tyres, I am way behind my mate who has same size tyres but has the ridgy didge Max air. And
mine gets damn hot too!
Maybe your clone is of a better quality than the POC I have! But I am nervous about doing it again and finding I've spent the same on two cheapies as I would have on one Max air.
191136
Follow Up By: Member - Roachie (SA) - Saturday, Aug 26, 2006 at 16:44
Yep, it's only 15 seconds; but that's after only a very short burst of use. The real test would be to pump up 4 tyres from 16psi to 40psi to replicate the real world.
I agree with Alloy C/T too.....so what if it takes a bit longer etc etc.......who's in a hurray to air up just to get bloody HOME!!! hahahaha It's just that I had previously said I'd be interested to see what the difference would be. Also, as I said before, it doesn't worry me anyway, as I use them both together for a faster result overall.
There are a few different clones.....this one has the air filter in the same place as the Maxair (up high)....some of the others have the air cleaner down low, but I don't know if that makes any difference.
448863
Reply By: Davo_60 - Saturday, Aug 26, 2006 at 18:39
Air max available on Ebay $295 buy it now + $25 delivery, brand new.
191155
Reply By: Willem - Saturday, Aug 26, 2006 at 19:48
G'day Bloke
Arn't there more things to test? You seem to have 2 of a lot of things....LOL
191167
Follow Up By: Member - Roachie (SA) - Saturday, Aug 26, 2006 at 20:34
G'day ol' mate,
I like to have a redundancy factor built in when I get "remote"....... batteries, fridges, compressors, jacks (3 off) etc ;-)))
448885
Follow Up By: Bonz (Vic) - Saturday, Aug 26, 2006 at 21:42
testicles?
448901
Follow Up By: Member - 'Lucy' - Sunday, Aug 27, 2006 at 14:23
He has six of those BONZ.
Two 'on board' for the extra tool he had attached. (just couldn't be that silly playing with one)
and two spares - just in case when remote
449004
Follow Up By: Bonz (Vic) - Sunday, Aug 27, 2006 at 16:14
thats rood Lucy, good to have u back
449015
