Uni Joints, Grease able, or sealed units ?
Submitted: Saturday, Aug 26, 2006 at 17:57
ThreadID: 37136 Views:2215 Replies:6 FollowUps:1
Hi.
Under the truck today . doing that most enjoyable task of greasing everything, When doing the uni joints i thought sealed units are probably a better idea as with the greaseable ones you always seem to end up pushing grease past the seals , hence allowing possible contamination dust etc to get in. Wear wise i wonder how they compare?.
Cheers Axle
Reply By: Marn - Saturday, Aug 26, 2006 at 18:31
They must not be too bad as you are flat out finding a grease nipple on most cars these days
AnswerID: 191152
Reply By: rodeonut - Saturday, Aug 26, 2006 at 18:33
gday,
i have maintained trucks with greaseable and non greaseable uni joints and have seen both types reach a million kms, the greaseable ones being greased every 10,000 kms. never seemed to have any probs with contamination either
AnswerID: 191153
Reply By: Exploder - Saturday, Aug 26, 2006 at 19:58
None of my drive shafts are grease able have got 150,000 on em now.
The tie rods get around 100,000k before they need replacing, once agene non-grease able.
My ball Joint’s did 135,000 before they were buggered, but the boots on all of them had been torn open for a wile. They were replaced with Grease able units and I put a set of aftermarket control arms in at the same time.
AnswerID: 191173
Follow Up By: Member - Axle - Saturday, Aug 26, 2006 at 20:05
Not much in it eh!, might as well have everything non grease able , leave the dirty old grease gun in the shed!. Ha Ha.
Axle.
FollowupID: 448880
Reply By: Eric Experience. - Saturday, Aug 26, 2006 at 21:59
Axle.
Greaseable uni's are not as strong as the non greaseable because they have to be made from a steel that can be drilled cheaply, some cheap units are cast iron, one of the early lessons I had when preparing vehicles for expeditions is to only use forged steel uni's. Eric.
AnswerID: 191197
Reply By: Member - Stephen M (NSW) - Sunday, Aug 27, 2006 at 18:19
Still got the original toyota's in my'n done 290k now grease every 5k and still fine. Regards Steve M
AnswerID: 191302
Reply By: Old Johno [NSW] - Monday, Aug 28, 2006 at 17:22
Axle,
One of the main benefits of greasable uni's is if you do a lot of mud & water work a regular pump of grease pushes the grit & water out of them. Non greasable do get grit & water in them after a while. We had Earthmover equipment for a lot of years & it was amazing the rubbish that would come out of joints with a small pump of grease.
Good Luck
AnswerID: 191484
