Air tank capacity
Submitted: Sunday, Aug 27, 2006 at 20:44
ThreadID: 37172 Views:3529 Replies:11 FollowUps:21
These are the stamped details on a bottle I have that I want to use for a compressor tank.
2.7mm 4.83kg 2.8L
P 200 PH 300 Bar
Does any know the calculation I need to do to work out how mant tires I can pump up with this?
Reply By: Member - John - Sunday, Aug 27, 2006 at 21:18
Hairy, what pressure are you going to be running it at?
John and Jan
AnswerID: 191339
Follow Up By: Hairy - Sunday, Aug 27, 2006 at 21:26
Not too sure yet? I havent made my compressor but a mid range 12 volt compressor would probably pump it up to about 140psi at a guess.
FollowupID: 449094
Reply By: Member - Roachie (SA) - Sunday, Aug 27, 2006 at 21:23
Buggar-all I would think. The tank sounds like it'd hold 2.8Litres of air......I'm guessing the 4.83kg figure is the gross weight of the tank if filled with a liquid.
As a comparison, I have 2 tanks hooked together; one is 3 L and the other 4L. With them fully pumped to 95psi (the ARB cut-off switches upper limit), the compressors cut in about 10 seconds after I hooke the hose onto the 1st tyre; to pump it from around 18psi to say 40psi.
However, a tank is good value for a quick blast of air to clean out an air filter, seeds from your radiator etc.....Just don't expect to fill your tyre/s from it without the pump going too.
Roachie
AnswerID: 191342
Follow Up By: Hairy - Sunday, Aug 27, 2006 at 21:37
Im trying to work out how much pressure I would have to put in the cylinder to pump up 4 tyres and if the cylinder could hold it.
Some of the details on the cylider lead me to think it can hold 200 or 300 bar
200 bar = 2 900.754 760 144 pound/square inch.
Does that sound right???
Suppose Id have to work out the volume of the tyre and psi needed and divide it up????
FollowupID: 449096
Follow Up By: Member - Roachie (SA) - Sunday, Aug 27, 2006 at 22:05
I can see where you're coming from Hairy, but the physical size of the tank will have more affect on it's ability to pump up tyres than what pressure it can handle IMHO. Unless you're taliking about the ridiculously high pressures used in those "Air-Up" set-ups or the likes of a diver's scuba tank etc. Those units do rely on very high pressures, but the tanks are constructed like.....well.....Tanks (as in army tanks!!!! hahaha)
If I'm correct in my assumption that your tank is about the size of a shoe box (say 5" diameter and 12" long), then even if it is capable of handling 200psi, you're still not gunna be able to re-inflate one tyre, let alone 4.
Roachie
FollowupID: 449103
Follow Up By: Member - John - Sunday, Aug 27, 2006 at 22:11
Roachie, 200 Bar = 2900 psi
John and Jan
FollowupID: 449105
Follow Up By: Member - Roachie (SA) - Monday, Aug 28, 2006 at 08:29
Cheers mate.......I didn't know what the conversion was........now all he's gotta do is buy the mutha of all compressors to get the tank to that sort of pressure and he'll be able to do as many tyres as he likes ;-)))
FollowupID: 449144
Reply By: Member - John - Sunday, Aug 27, 2006 at 21:42
Hairy, 140psi is 9.6 bar. Will give you about 27 litres of air, not a lot.
John and Jan
AnswerID: 191346
Reply By: Member - John - Sunday, Aug 27, 2006 at 21:47
200 Bar = 2900 psi, don't think your compressor will make it ???
John and Jan
AnswerID: 191351
Reply By: Kiwi Ray - Monday, Aug 28, 2006 at 08:24
Hi Hairy
I have a 90 lt dive tank, when full 2600 psi I can fill 10 Symex tyres ( 35x12.5x15 ) from 12 psi to 40 psi so this will give of how much air is required.
Most average sized compressors used in small workshops and at home will restart by the second tyre, these compressors usually have a 50 lt tank
Hope this helps
AnswerID: 191380
Reply By: Member - Oldplodder (QLD) - Monday, Aug 28, 2006 at 08:27
Rough calc.
2.8l tank.
normal atmospheric air pressure is roughly 14 psi.
So 140 psi is 10 times atmospheric pressure (atmo), so about 28 litres in the tank.
Tyre at atmo is about 50 litres, depending on size.
Tyre at 35 psi (2.5 times atmo) takes about 125 litres of air.
Now you should be able to play with the maths yourself :-).
AnswerID: 191381
Follow Up By: Member No 1- Monday, Aug 28, 2006 at 09:28
Oldplodder you shouldnt confuse the issue with citing atmospheric pressure unless you want to talk about PSIA as to the difference of PSIG
even if the tyre is flat it is at atmospheric pressure... and thats 14.5psia approx or zero psig
PSIA is pounds per square inch absolute where-as psig is pounds per square inch gauge.
just using your figures of psig is suaitable..ie your calcs have nothing to do with atmospheric pressure unless we compare a tyre here on earth to one on a LRV...(Lunar Roving Vehicle) on the moon..the moon is a almost perfect vacuum or 0 psia.....get the idea...
no offence meant matey
FollowupID: 449153
Follow Up By: Member - Oldplodder (QLD) - Monday, Aug 28, 2006 at 16:57
Thanks numero uno.
Hard to keep it simple and still get the idea across that you can fit more air in than the actual atmospheric volume :-)
Always found it confusing gauge and absolute, been too many places where I have seen both used.
But a point worth raising.
FollowupID: 449263
Reply By: Hairy - Monday, Aug 28, 2006 at 09:10
Mmmm scary!!
My calcs say... a 1.5 litre cylinder would need 5120psi of air pressure to fill 4x50 litre tyres to 40 psi !!! Is that right?
AnswerID: 191388
Follow Up By: Member No 1- Monday, Aug 28, 2006 at 09:31
you didnt forget to add in the 40psig that you cant get out of the cylinder after inflating the tyres did you?...ie you cant get that last little but out out once the tyre pressures match the cylinder pressure..
FollowupID: 449154
Reply By: Member No 1- Monday, Aug 28, 2006 at 09:36
hahaha...I hope all the calculations shown above have allowed for tyre expansion as it inflates to whatever psig figure they are using.....
if not go back and start your calculations again cos your wrong
AnswerID: 191395
Follow Up By: Hairy - Monday, Aug 28, 2006 at 11:11
So legend! Why dont you just tell some of us dumb a r s e s the answer instead of just saying were all wrong.
FollowupID: 449175
Follow Up By: Member No 1- Monday, Aug 28, 2006 at 11:52
as i dont have a use for it, there is no need for me to know, so what can I tell ya
FollowupID: 449182
Follow Up By: Hairy - Monday, Aug 28, 2006 at 11:59
Not so clever after all hey!
FollowupID: 449184
Follow Up By: Member No 1- Monday, Aug 28, 2006 at 12:21
assumption: Cylinder pressure 100 psig
from my experince of working with gases and volumes of pipework and pressure storage vessels the peesy little 2.8l cylinder will not pump the tyre to 10 psig let alone to 40 psig.
Forgetting about expansion rates etc, Its all a matter of volume and with out all the Correct volumes one cant work it out...the figures bandied about above are at best a guess of a tyre volume
FollowupID: 449190
Follow Up By: Member No 1- Monday, Aug 28, 2006 at 12:26
also,
no and never said I was smart
but it does appear i might have a lot more knowledge on the subject than you so it would be appreciated if you'd accept the title of "dumb a r s e"
FollowupID: 449191
Follow Up By: Hairy - Monday, Aug 28, 2006 at 15:13
Yep... I can tell that. All the intelligent info you have passed on has been fantastic!
Just one thing still doesn't make sense to me (As a Dumb A R S E) .... From your advice, and Ill put it in another scenario, your saying its all volume. So... If iI got an empty cylinder( atmospheric pressure of 14psi as you have called it) and put a balloon over the end and opened the valve it would do the same as it would to the same size cylinder with 2000psi in it? mmm I like you knowledge!!!
I think I might go with everyone else's helpful but not as knowledgeable advice.
FollowupID: 449218
Follow Up By: Member No 1- Monday, Aug 28, 2006 at 16:38
another jerk...bloody hell
cant you read?
if you had an empty cylinder of 14.5psia, which is atmospheric pressure it wont inflate a deflated balooon...cos they'll both be at the same pressure!
read what was said Hairy....try to understand that 14 psia is atmospheric pressure or in other words zero psig....psia and psig are not the same readings when shown on a gauge...theres is a difference of 14.5 psi....look no a or g after psi
if your still confused let me know
"So... If iI got an empty cylinder( atmospheric pressure of 14psi as you have called it) and put a balloon over the end and opened the valve it would do the same as it would to the same size cylinder with 2000psi in it?"...i said nothing of the sort....it certainly is another scenario..one i have no idea of what your trying to say.....
FollowupID: 449257
Follow Up By: Member - Oldplodder (QLD) - Monday, Aug 28, 2006 at 17:02
If it is an empty cylinder, and you put a balloon over the end, wouldn't the balloon get pushed inot the cylinder?
Empty cynlinder to me means no gas or anything in there, so air pressure would push the balloon into the cylinder?
I know splitting hairs, or atoms in this case, since you can not have an empty cylinder at 14.5psia :o)
See, i am learning quick from numero uno. Don't argue the facts, stir instead, it is more fun :o.
FollowupID: 449265
Follow Up By: Member No 1- Monday, Aug 28, 2006 at 17:58
yep if the cylinder has nothing...not even air, then then yes oldplodder
it would be zero psia eh...or approximate 28 inches of vacuum.....now dont start on this oldPlodder...just forget i said anything about inches of vacuum.......hahaha
FollowupID: 449280
Follow Up By: Hairy - Monday, Aug 28, 2006 at 21:08
No. 1,
Im starting to think a few of my simple questions must of put you on some sort of pedestal ,I realy was looking at some sort of advice from a variety of people with different backgrounds and different trade areas. Apparently Ive seemed to have crossed some sort of line with you.
Being called a jerk when im actually looking for sound advice doesnt sit very well with me so Ill leave this forum with a few ideas I have from the decent people who commented. I cant understand why a simple question has to be so hard.
Remember the question???
(These are the stamped details on a bottle I have that I want to use for a compressor tank.
2.7mm 4.83kg 2.8L
P 200 PH 300 Bar
Does anyone know the calculation I need to do to work out how many tyres I can pump up with this)
If there wasnt enough info or you or think its not possible say so but dont try to get personal and critical about others comments!
If you ever happen to come through Alice, need somewhere to do an oil change, borrow a shed, or generally need someone to pull you out of the s h i T give me a call, Id love to meet ya!
FollowupID: 449324
Follow Up By: Member No 1- Monday, Aug 28, 2006 at 21:36
but you gave us no info Hairy...only the fact you had a 2.8litre cylinder
Tell me the tyre and wheel volume and I will tell you what you what to know
I do question the 300 bar bit...no idea what the 200 is though
and thanks for the offer
ps I thought had deleted that jerk bit...but thats life
FollowupID: 449334
Reply By: the outlaws - Monday, Aug 28, 2006 at 12:05
Gday Hairy,
I dont have the answer for your question but i think you will be able to work it out on this calculator
Johno !!
Site Link
AnswerID: 191432
Follow Up By: Hairy - Monday, Aug 28, 2006 at 12:09
Cheers Mate, thanks all
FollowupID: 449185
Reply By: Witchdoctor - Monday, Aug 28, 2006 at 17:21
Roachie FYI,
Dive tanks have a working pressure of around 4000psi. NOW liquid CO2 systems have a working between 800psi & 1000psi. Hope this proves useful in the future.
The CO2 set ups have identical pressures as your CO2 fire extinguishers.
Cheers Dave
AnswerID: 191483
Follow Up By: Member No 1- Monday, Aug 28, 2006 at 18:02
not all dive tanks are 4000 psig..most are well below that, especially the alloy tanks
FollowupID: 449281
Reply By: Witchdoctor - Monday, Aug 28, 2006 at 20:11
As a diver i can supply more detailed info, in my first post i stated that dive tank pressures at around 4000psi.
The actual pressures are as follows.
Old Steel - 2205 psi
New Alloy - 3234 psi
New Steel - 4410 psi
The point i was getting at was liquid CO2 is nowhere near the pressures of a dive tank (very safe) as are fire extinguishers.
AnswerID: 191527
