Airbags for Cruiser
Submitted: Sunday, Aug 27, 2006 at 22:40
Dazz78
G'day all
I will soon be heading on a trip to the Gulf country and will be heavily loaded and towing a camper with a 79 series landcruiser. I would like to keep the vehicle as level as possible and consider airbag assist a possible option on my standard
suspension. I am unsure how suitable airbags are in offroad situations and which option is best, ie.belows or bag and coil.
Any information would be greatly appreciated.
Darren.
Reply By: Member - Keith B (QLD) - Monday, Aug 28, 2006 at 12:33
Darren,
I fitted bellows to my 2005 78 series a few months ago and have had several trips including
Hay River, fully laden. I fitted better shockies but retained the standard springs. The set up has worked very
well. I like the ability to be able to level the vehicle with different loads. The nuts on the retaiing bolts need to be doubled up, and wired on !!!
191437
Reply By: Max - Sydney - Monday, Aug 28, 2006 at 20:38
Darren
I just took off a pair of Polyairs out of the back of my 80 series after over 200,000 km of heavy loads and bad roads.
They had not failed - just seemed prudent when l changed from lifted back to standard springs. I have put a new pair in to help with caravan loads. Had them on a Jackaroo before that - it had leaf springs, and they did about 70,000 km from memory.
I reckon they are great in the rough stuff.
Max
191530
Reply By: Member - Phil G (SA) - Monday, Aug 28, 2006 at 23:09
In the rough stuff, I prefer to keep it simple, so prefer to upgrade the leaf springs rather than fit extra airbags. 79series can hold a lot of weight and the ride is pretty good anyway.
191566
Reply By: Alloy c/t - Tuesday, Aug 29, 2006 at 07:11
Bellows or polyair or firestone either way you an get them 30/50% cheaper from trucksprings in the US of A ,
191581
Follow Up By: Dazz78 - Tuesday, Aug 29, 2006 at 19:58
Thanks for the replies everybody. I have received information today about a relatively new product called aussie super springs and I think they may be an ideal solution. They are a very simple single leaf addition to standard springs that only come into play as load is applied. Their website is www.aussiesupersprings.com.au
Price including fitting is about $500.00 which is a bit steep for a single leaf but not much dearer than airbags and there are definately some advantages over the airbag system.
Darren.
449524
