Canvas Protection and stiching.
Submitted: Tuesday, Aug 29, 2006 at 16:29
ThreadID: 37235 Views:5962 Replies:7 FollowUps:4
Hi all just wondering what is the best product to put on canvas for protection water repellent/dirt/ bird crap etc and also heard of some stuff you put on the stiching. I dont have any leaks as such but want too look after it as much as possible.Also what do people put under there jerry cans/gas bottles when in the holders. My'n sit on checker plate on the sides but want to stop the paint from being rubbed off due to vibration over corrugations. Thought some rubber maybe but then how to attach as dont want water sitting between the rubber and checker plate. Thankyou. Regards Steve M
Reply By: Brian B (QLD) - Tuesday, Aug 29, 2006 at 16:58
G'day Steve,
We haven't applied any other treatments to our camper canvas or stitching since it was manufactured.
When we got it home we put it up and over a period of a few of days we wet it down and then allowed it to dry doing this several times over the few days. We were advised by the manufacturer that this was all that was required. Have had it out in some good rain since and it stays nice and dry.
Dirt and bird crap if not left on the canvas for an extended time frame seem to come off fairly easily with plain fresh water and a mild rub if required. We have done this with ours and have had no problems so far.
We use the plastic jerries and don't put anything under them and don't put anything under our gas bottles either although I like the idea of a bit of rubber underneath. I went for a fully galvanised camper as we go near sand and salt water a lot so I don't want to put anything in place that could allow salt etc to build up and get rust happening.
Have a good one.
AnswerID: 191670
Follow Up By: Member - Stephen M (NSW) - Wednesday, Aug 30, 2006 at 17:54
Hi there Brian, never thought of the plastic ones, I have 2 of the old metal jerry cans. Whats a good brand in the plastic ones or they pretty much all the same, Have to pass standards I would imagine ?? Regards Steve M
FollowupID: 449744
Reply By: Member - Alastair D (NSW) - Tuesday, Aug 29, 2006 at 17:25
Stephen,
Haven't used anything on my canvas, it doesn't leak - yet.
I bought a recycled rubber doormat from Bunnings ~$5 and cut it into appropriate pieces to sit under the metal cans and a strip along the sides. Cheap, works well and they don't jump around when empty.
alastair
AnswerID: 191672
Reply By: mfewster - Tuesday, Aug 29, 2006 at 18:19
For jerry cans. Drop in on a tyre retailer and see if they will give you a BIG used/stuffed tube (big truck/tractor size) that they were going to throw out. Cut into lengths same as height of the jerry can. Stretch this overthe can like a giant condom. It should fit tight. Stops jerrys rattling against each other/wearing through against each other etc. Very neat,light solution. Stays on the can at all times.
AnswerID: 191679
Follow Up By: Member - Stephen M (NSW) - Wednesday, Aug 30, 2006 at 17:57
Good one there mfewster, never thought of that , wonder if I could do a similar thing with gas bottles as well. Thanks for the info appreciated. Regards Steve M
FollowupID: 449747
Reply By: Member - eerfree(QLD) - Tuesday, Aug 29, 2006 at 21:15
Stephan M
Indoor/outdoor carpet works a treat for protecting Jerries.
eerfree
AnswerID: 191697
Follow Up By: Member - Stephen M (NSW) - Wednesday, Aug 30, 2006 at 17:59
Hi there eerfree, another good idea, got a fair bit of that left in the shed from retrimming the ski boat floor, maybe a bit of liquid nails on the top edge just to stop it moving about. Regards Steve M
FollowupID: 449748
Reply By: Sand Man (SA) - Wednesday, Aug 30, 2006 at 07:34
Stephen,
Give this a try.
Obtain a bit of foam rubber and cut into suitable strips. Attach these to the sides and bottom of the jerry can holders or gas bottle holder with black duct tape. This will stop the water getting underneath and give some padding to the Jerry cans and Gas bottles.
Bill
AnswerID: 191748
Reply By: Member - Stephen M (NSW) - Wednesday, Aug 30, 2006 at 18:01
Thanks all for the replys, amazing I have half this stuff stuck in the back shed thrown in a corner some where and my wife wanted to chuck it all out so the shed was clean. There you go there's always a use for some thing and she will be happy as I wont have to spend any money maybe an old rubber tube as suggested. Regards Steve M
AnswerID: 191861
Follow Up By: lost - Sunday, Sep 03, 2006 at 21:21
hi steve
i had the same problem with my camper, for the jerrys i cut up some 4.5mm thick rubber into strips. then marked their position and used gel grip to hold in place. 24 hrs later i drilled and counter sunk holes through the rubber and in2 the gaurd/mount and pop riveted them( just in case the petrel leaks and eats the gel grip. it has been orsm so far, havent lost any paint at all.
FollowupID: 450404
Reply By: Member - BBB - Sunday, Sep 03, 2006 at 22:32
Steve
You have got all the advice you need having canvas tents and campers over the past 20 years don't use anything but water if you do you will need to keep reapplying it all the time "Water is the answer"
BBB
AnswerID: 192571
