trailer brakes
Submitted: Wednesday, Aug 30, 2006 at 13:31
ThreadID: 37259 Views:3881 Replies:8 FollowUps:5
I have recently puchased an off road trailer and need electric brakes for my 4WD. There seems to be 2 main types. The first needs to be manually leveled and the second type is self leveling and adjusts as you drive along. Can anyone give me advice on what is which is the best option?
Reply By: Michael ( Moss Vale NSW) - Wednesday, Aug 30, 2006 at 13:45
I had two Tekonsha unit failures although there are plenty of guys that have had no problems. I now have a Hayman Reese unit and it is simpler. The Tekonsha unit needs to be mounted at a certain angle because of the active self adjusting unit and in some vehicles this is not achievable if you mount it in the normal position adjacent to your left knee because of the shape of the lower intsrument panel. My thoughts only. Michael
AnswerID: 191815
Reply By: D-Jack - Wednesday, Aug 30, 2006 at 14:15
From what I understood when looking around, the Teshonka Prodigy is the bees knees of controllers, I picked mine up for about $160 on the net and installed itmyself. As for angle, it can not be mounted with face pointing down, but can pe pointing up to 70 degrees which is a huge angle, and I shouldn't think too many 4wds can't accomodate that type of angle. Mine just replaced the ash tray.
As for failures, there were problems with earlier models (of the voyager) all seem to have been sorted - as for the Prodigy, no problems I have heard of except for certain Fords with cruise control which requires slightly different wiring. Haven't had mine for long, but works a treat, and I can adjust it to boost when on dirt so if I get out of shape, i can hit the brakes lightly and the trailer brakes come on full bore and help straighten me up (only through practice, not necessity)
Installation of any brake controller (except those mounted on drawbar but not adjustable from inside vehicle) is generally easy but fiddly. I was quoted from $380 up to $500 just for installation, but did the job in a day with my very limited electronic experience.
Good Luck
D-Jack
AnswerID: 191822
Follow Up By: itsdave - Wednesday, Aug 30, 2006 at 14:39
I'm having my Prodigy installed tomorrow. Was quoted $130 and $170 somewhere else so I think $380 $500 is a bit steep unless it includes the unit as well
Cheers Dave
FollowupID: 449698
Follow Up By: SA_Patrol - Wednesday, Aug 30, 2006 at 20:22
Repco's had them on special not long ago for $150 Electric brake people at Holden Hill quoted me $100 for installation, it only takes an hour or less to fit.
FollowupID: 449779
Follow Up By: otrom - Wednesday, Aug 30, 2006 at 23:06
Prodigy is the way to go.
I had mine installed last week in my Pajero. Arrow Caravans & Towbars (Brisbane) came on-site to my work, supplied and installed it for $360. Took the guy around 1.5 hours to install.
Don't forget, for those that are connecting to a van (with on board 12v fridge), for an extra $20 he put a relay connected to the accessories. Therefore when I turn the car off, it disconnects the power supplied to the fridge in the van. This allows you to stop and not worry about the fridge draining the starter battery.
FollowupID: 449809
Reply By: Darian (SA) - Wednesday, Aug 30, 2006 at 15:07
I've had the Tekonsha Prodigy in my Jack for 2 years now - drives the brakes on the Campomatic trailer - been very good to date - I've only ever heard good about the Prodigy - plus it has the ability to work while reversing - not all do that. Very easy to manually throw the brakes on while motoring, plus adjust the power and boost levels - all digital readout - I played safe (in my terms) and paid $450 for supply and pro install at an electric brake specialist.
AnswerID: 191833
Reply By: Member - Vincent A M (NSW) - Wednesday, Aug 30, 2006 at 18:03
i have a Hayman Reese type & is still working great, 3 4wd's later (800,000.00klms) & is used every week (work) but i do find it hard to set when towing some thing light (empty trailer eg) as the setting slide is small
good luck
Vince
AnswerID: 191862
Reply By: Member - Ian W (NSW) - Wednesday, Aug 30, 2006 at 18:55
I have run a Hayze Lemir controller for the last five years. Can mount at any angle and a simple adjustment to set how quickly/savagely you want the braking to come on.
Ian
AnswerID: 191870
Reply By: Derek from Affordable Batteries & Radiators - Wednesday, Aug 30, 2006 at 20:31
Hi dnielsen,
You won't go wrong with the Prodigy. They are one of the best products on the market. I have never had a unit returned faulty.
If your trailer has Hydro-Electric brakes you will need the Voyager. The Prodigy won't work on them.
You can do a DIY fit in around 2 hours. Remember there is a 25 % price increase on the 1st of September.
Regards Derek.
AnswerID: 191887
Follow Up By: Ray Bates - Thursday, Aug 31, 2006 at 08:25
Darian states that his brake unit works in revearse. How does that work? I have drum brakes on my caravan and the actuating arm cannot go in the revearse direction
FollowupID: 449825
Follow Up By: Derek from Affordable Batteries & Radiators - Thursday, Aug 31, 2006 at 08:31
Most electric brakes will work in reverse.
There is no left and right wheel assembly. They work on both wheels so in other words will work no matter which way the wheel is turning.
Regards Derek.
FollowupID: 449828
Reply By: Max - Sydney - Thursday, Aug 31, 2006 at 18:15
While you are setting up - just make sure that the magnets in the brakes are the "off road" type. Mine predated them, and wore out enough to lock a wheel at 80 kph on the way to the Bungles. Much smoke!
Max
AnswerID: 192018
Reply By: Grandpa joe - Thursday, Aug 31, 2006 at 19:08
Have been using a Hayman & Reece type solid state controller for the last four years and works a dream, It can be dialled up a notch on the fly (after just picking up a ton of topsoil for example) and is unaffected by heavy corrugations and offroad use (extreme angles) The manual over-ride button to trigger the brakes is especially usefull when crawling off ledges to turn the trailer into an anchor" so to speak. One of the cheaper units available on the market too!
AnswerID: 192032
