Speed sensor location
Submitted: Sunday, Sep 03, 2006 at 08:06
ThreadID: 37360 Views:3473 Replies:3 FollowUps:0
I have a 1991 Nissan Terrano TD27. And I can not find the speed sensor, I know it has to be some where because there are no cables running to the dash. I don't really know where to look.
SantaAus
Reply By: Notso - Sunday, Sep 03, 2006 at 09:15
They are mostly at the back end of the gearbox and take a signal from the output shaft.
AnswerID: 192437
Reply By: cloughie - Sunday, Sep 03, 2006 at 11:41
Do you mean the speed alarm that comes on at 105 kph or something to do with the speedo? If you mean the speed alarm and how to stop it let me know and i can help.
AnswerID: 192473
Reply By: kev.h - Sunday, Sep 03, 2006 at 21:54
She sensor unit is high on right side at rear of gearbox (at least in auto) if you only need the sense wire for cruise control etc its the blue and white one coming into the dash panel on the left lower corner with a bundle of other wires
If its your speedo not working does the trip meter still work as they both use the same sensor easier than climbing under the car
P.S. Mine is a 95 assume its the same
cheers Kev
AnswerID: 192560
