another 1 for you all= turbo's
Submitted: Sunday, Sep 03, 2006 at 23:56
lost
im wanting to fit a turbo to my cruiser(110,000kms on it) and just want to know from other people that have had it done if they are happy with the set up and/or have had any dramas with them.
also which type of turbo did you get fitted.
all of your comments are welcomed
my cruiser has the 1hz, has had new injectors fitted about 10,000kms ago. will be towing a camper around this orsm state in a couple of weeks
cheers all
Reply By: Big Woody - Monday, Sep 04, 2006 at 06:21
Hi Lost,
I have an 80 series with 1HZ engine that has done 298,000km with a Mike Vine Turbo fitted.
Neither motor nor turbo have ever been touched except for ususal servicing of injectors and pump etc...so I am happy with reliability.
Your fuel consumption will go up especially when towing but it is great to be able to overtake without stressing that you won't make it. Normal running around empty I get 13L/100km with roof rack,
snorkel and other things that have affected aerodynamics. On highway towing it can go up to 18L/100km with 3000kg load on a big square tandem trailer. Before turbo was fitted it seemed to just get 11-12L/100km whatever I did.
Make sure your cooling system is 100% and consider taking extra measures such as larger capacity radiator etc. just in case.
My motor has only ever been hot once and that was 2 weeks ago when but it turned out to be the viscous fan hub working intermittently. Replaced with a new one and no problem since.
I would recommend capping the boost of your turbo at 8psi as I have heard reports of 1HZ's having problems from high boost pressures. That is also why I have not gone for the big 3" mandrel bent exhaust that everyone talks about as the exhaust itself acts a boost limiter preventing excessive boost pressures in some ways.
If i were to do it all again I would first consider the diesel/gas conversion now and see if the claimed power increase was sufficient for my needs.
Good luck with your decision,
Brett
192590
Follow Up By: lost - Monday, Sep 04, 2006 at 12:22
thanks for your comments
am i better off looking at diesel/gas conversion first.
do you know of what figures you would get with gas instead of a turbo.
thanks
450487
Follow Up By: Big Woody - Monday, Sep 04, 2006 at 17:33
Hi Lost,
Based on the research i have done it should only take me 20,000km to pay back the $2000 I would have to pay after deducting the Gov. rebate but that is using my current fuel consumption fiures of towing my yacht which weighs about 2500kg empty. As I am planning a trip from
Bundaberg to Victoria and another next year to
Cooktown towing all the way it should pay for itself in those 2 trips alone.
I think it would probably take much longer than that to recoup costs when fitted to a N/A diesel. I have also heard that the power increase is more significant on a T/D than it is on a N/A diesel.
Although i have spoken to 3 blokes now who have had the conversion including TJM in
Brisbane I guess it is still a gamble as to the amount of benefit if any as each 4wd is different and so is each driver so there are always a lot of variables that will affect figures. I think I will sit another 6 months or so and let the conversions get some k's up on them and then weigh up all the feedback. The rebate will still be around then.
At the end of the day a 1HZ Landcruiser fitted with an aftermarket turbo is a proven and I agree with the other posts saying that you will never look back. It does totally change the vehicle to drive. Toyota also don't seem to have quite the overheating issues of a Nissan when fitted with aftermarket turbo's so I wouldn't be too concerned about temperature.
Brett
450583
Reply By: Member - Ian H (NSW) - Monday, Sep 04, 2006 at 06:37
I fitted a turbo to our 1HZ at 140000 kms and it was the best $3300 I have spent on the old girl. Makes a big difference, about 40% increase in both power and torque, but leave the exhaust standard and don't fit and intercooler. The engine bay is hot enough already. I had ours fitted by the
well known diesel tuners down south of
Sydney. We get about 12 - 13 l/100kms around town and about 15/100 fully loaded on a trip. It now just keeps pulling at about 2100 RPM when before it would just die off. Go for it, you won't regret it.
192591
Follow Up By: lost - Monday, Sep 04, 2006 at 12:25
thanks
just wondering what type of turbo you had fitted, also what boost you are running and did you get a etg fitted as
have you ever had any dramas with the eng temp rising since fitting.
450488
Follow Up By: Member - Stephen M (NSW) - Monday, Sep 04, 2006 at 14:27
Sounds like it might have been turbo glide in
Wollongong very popoular but I could be wrong. Regards Steve M
450531
Follow Up By: Member - Ian H (NSW) - Monday, Sep 04, 2006 at 17:50
It was fitted by a Diesel place near Bowral and is a Mitsubishi turbo. It runs at 10 psi boost and no ETG fitted. The temp guage never moves from normal. I agree with the radiator check when you fit the turbo. Good luck.
450586
Follow Up By: Member - Stephen M (NSW) - Monday, Sep 04, 2006 at 18:50
I was wrong sorry. Regards Steve M
450600
Reply By: kayno - Monday, Sep 04, 2006 at 11:30
Hay there ,
My cruiser was a bit older than yours and i got the boys from MTQ to fit my turbo, it made her go heaps better, then only thing i could suggest is that get your engine compression tested before hand. My engine only had about 100k on the clock but found that one of my cylinders was low. I ended up just rebuilding the engine so i new that everything was going to hold together. Personally i wont go back to a 4wd without a turbo.
Cheers Kayne
192626
Reply By: Member - John L G - Monday, Sep 04, 2006 at 12:07
This would be the best money you have ever spent on your truck.
I have a Safari, no particular reason, fuel consumption the same unless you flog it and vehicle had done 150K's when I fitted it. No dramas however make sure your cooling system is ok.
Have also fitted a
snorkel and 1 a 3" exhaust, all of which helps the delivery and expulsion of air.
Enjoy your new truck.......it will feel like it!!!!!!!!!!!!!!
192641
Reply By: lost - Monday, Sep 04, 2006 at 12:28
thanks for your comments.
i will be looking in2 prices and which turbo to go in the next 2 weeks.
192646
